Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Are there known faults with whirlpool fridge freezeer model number arc 5566 nfw
Freezer icing up fridge compartment warm
  • 87 Answers
SOURCE: warm Fridge side
Defrost the fridge freezer overnight. Restart unit. If it starts working you have either had a door ajar or a defrost problem. If it fails to cool down at all then you may still have a defrost problem or a evap fan motor faulty. Most likely outcome is that the unit will work once defrosted for approx three weeks after which the freezer will freeze back up. Most likely cause will be the defrost heaters. Any good tech should be able to help on second failure. Hope this helps.
Posted on Sep 06, 2007
  • 57 Answers
SOURCE: WHIRLPOOL CB18M FRIDGE FREEZER
3 things to check. If you didn't adjust the damer from the freezer to the refrigerator, like closed it off. Is the freezer fan running? The fan blows air from the freezer to the refrigerator section. Some fans shut off when the door is open so you may have to push in the door switch to check this out.
Look for ice on the back wall, of the freezer section, If present then the defrost cycle is not working. The evap. coil is icing up and there is no air blowing into the refrigerator. Set the thermostat back to the normal setting it just causes a longer run time on the freezer section.
Posted on Oct 20, 2008
jumptrout51
  • 3361 Answers
SOURCE: Whirpool fridge is warm, freezer is working
Check the back wall of the freezer compartment for ice buildup. Sounds like you have a defrost issue.
Posted on Feb 22, 2009
bobicehouse
  • 1524 Answers
SOURCE: My whirlpool refrigerator 21TFA is leaking water
The drain is clogged. Remove freezer plate and pour a mixture of baking soda and warm water down drain.
Posted on Nov 02, 2010
SOURCE: Where can i find the
open fridge door and pull out second from bottom draw - the sticker is on the righthand side
Posted on Jan 09, 2011
Whirlpool model ED5JHEXT00 My fridge is warm but my freezer is cold
Check for build up of ice on the back of the freezer if so you have a fault in the defrost system
Apr 04, 2017 | Whirlpool Refrigerators
Can you tell me why please?
All the big cooling happens inside freezer compartment. Freezer gives little cool air to fridge compartment. Now when the vent blocks that little cold air cannot go into fridge compartment. Thus your freezer works good but not fridge compartment. Milk goes bad but frozen meet keeps good.....
Vent freeze up either due to defrost problemt, defrost drain line problem, Evaporator fan problem or even can be your damper motor not opening due to unit failure or frozen damper door.
Sep 19, 2014 | Whirlpool GX2FHDXVY Gold Stainless Steel...
Why do freezer coils ice up on my Stainless Steel Whirlpool refrigerator (model GB2SHDXTS)?
On your model your cntrl board has a relay that can stick causing the compressor to always run even when the unit is turned off or in defrost. turn the fridge off, move the temp of the freezer to it's warmest setting and it should display a line in the freezer and fridge temp display. listen to hear if the compressor is running in back of the unit. if it is you need part number: 12868513
Mar 15, 2013 | Whirlpool Refrigerators
Water is dripping into fridge compartment from section separating fridge and freezer compartments, otherwise, both seem to be working fine. unit was new in 2001, model ET21PK.
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Gene
Aug 09, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer cold fridge warm
sounds like the evaporator in the freezer section is iced up and you need to see if the defrost section is working correctly,then as for the warm refrige side,it sound as if the vent damper door is frozen shut or the cold control in the refrige isn't opening it to let cold air into the refrige from the freezer,if its frozen take a hand held hair dryer and remove the vent grille over it and defrost it and then check to make sure the control opens and closes it as you adjust its control in the refrige
Apr 26, 2010 | Hoover HCA391FFK Bottom Freezer...
Freezer froze,ice and frost,freezer door froze, warm in fridge
change thermostat sensors in fridge and freezer easy
Feb 04, 2010 | Refrigerators
How do I defrost my whirlpool ARC 5070 fridge/freezer? (I lost the guide when I moved) Thanks to anyone who can help me
My whirlpool Fridge/freezer powers up but both fridge and freezer notworking,have defrosted the freezer but noluck,have turned on foran hourand then back again,as per user guide still no luck.
Jul 27, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Feb 22, 2009 | Whirlpool GB2SHDXP Bottom Freezer...
Snows inside freezeer compartment of side by side
You actually have 2 problems here.
One the ice maker shutoff is defective. REPAIR is to replace the ice maker.
Two (snow) is a loose door seal, Outside air entering the freezer.
Feb 20, 2009 | Kenmore Refrigerators
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
56 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
