Question about Nortel Lands Phones
How can i connect my ntab9893 phone to radio
How can i connect my phone model number ntab9893 to the radio
Connecting Mobile Phone to Ford Sony Radio?
Go the menu of the Radio, see the user manual
and follow the step, and see how to Edit the Mobile phone
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Nov 03, 2017 | Sony Cell Phones
Please i need to unlock my radio my vin number is IHGCM56887A141984
Mate check this web site out, It's FREE to unlock your radio. You need three things * Vehicle VIN Number * Phone Number and Zip Code matching those on file* Device Serial Number...CHEERS...
http://www.nairaland.com/616468/unlock-car-stereo-free-here
Mar 12, 2016 | Cars & Trucks
How to get it connected to the internet
phone a local internet service provider tell them you wish to connect to the internet they will then advise you that you need a modem. Either a cable modem , ADSL modem or a Radio Modem depends on if Broadband Radio available or needed. Then the router is connected either via the modem or has a built in modem in it.
Tell them what make model number of router you have and they should advise you on how to connect it to their internet network.
Oct 10, 2015 | Computers & Internet
How do I connect to Ford Sync?
To use any of the phone features for SYNC such as making a call, receiving a text message, or using SYNC Services, you must first connect, or "pair" your Bluetooth-enabled phone. Pairing is what allows Bluetooth devices to communicate securely with each other.
Please note that SYNC can make and receive calls using only one paired phone at a time.
Before you start
There are a few things you should do before starting step 1:
blobserver?blobkey=id&blobwhere=1309207543643&blobcol=urldata&blobtable=mungoblobs&b=91
Turn on your
  • Mobile phone
  • Vehicle
  • Radio/SYNC
blobserver?blobkey=id&blobwhere=1309207543650&blobcol=urldata&blobtable=mungoblobs&b=91
Enable your phone's Bluetooth feature and make your phone discoverable.
Press the Phone button to access the Phone Menu. Press OK. Add a Device displays. Press OK.
SYNC prompts, "Press OK to begin pairing device." Press OK.
SYNC prompts, "Search for SYNC on your device and enter the PIN provided by SYNC." Press OK.
A six-digit number displays on the screen for three minutes, during which time SYNC actively seeks for the same number from your phone.
Type the number displayed by SYNC on your phone key pad.
Upon successful pairing, a message displays confirming the phone is connected.
Exit the phone pairing process by pressing the Arrows to select the Exit message and press OK to leave the Phone menu.
Aug 25, 2014 | Cell Phones
Hi, I have a Clarion PU-1525B Saab radio casstte from my original Saab VIN Number YS3237X2024319, and I would like to transfer this into the same model but with a different Vin Number. Unfortunately, I do...
This is a tough one, i do this all the time for customer cars but you would need to prove ownership of the radio. the only way to get the code is through the dealer, you can try on the phone but most times they want proof, you will need the serail # off the radio you need the code for and some id and then heres the bad part, you need the registration for the car the radio came out of or title, or again try over the phone and tell them you need the code for radio just have the serail # also depending on the radio it may need to by connected as some radios they have you push andd hold two buttons to get a diffrent code they use to cross into the correct code. give it a try, good day.
Aug 06, 2011 | Saab 9 3 Cars & Trucks
KDC-W7537U model number Code for bluetooth
most of the default codes are 1234, 0000, 1111 unless changed by the user. if this doesn't work, you can always do a hard rest of your radio by pressing the small pin hole button on the face of the radio.
hope this helps
Oct 04, 2009 | Kenwood KDC-W7537U CD Player
Mitsubishi Montero Sport Radio Code
Call your local MItsubishi dealership and ask for the service department.
<BR>They have a computer program where they punch in the serial number from your radio (you have to supply the number) and it will tell them the UNLOCK CODE for your radio. My dealership offered to give it to me free over the phone, if I knew my radio serial number. Enter the code using the buttons on your radio. And write the code down, this will show up everytime your radio looses connection to its power source - the car battery.
Mar 14, 2009 | 2001 Mitsubishi Montero
I have a nextel phone and it has direct connect
have you tried using that phone to call another phone that has caller ID?
Nov 18, 2008 | Radio Communications
Radio Code
RADIO SAYS "UNLOCK CODE:" <BR>Call your local MItsubishi dealership and ask for the service department.
<BR>They have a computer program where they punch in the serial number from your radio (you have to supply the number) and it will tell them the UNLOCK CODE for your radio. My dealership offered to give it to me free over the phone, if I knew my radio serial number. Enter the code using the buttons on your radio. And write the code down, this will show up everytime your radio looses connection to its power source - the car battery. <BR> <BR>
If you need it - I called 360-696-2277 which is the local Mitsubishi Dealership for me here in Washington State. They were the ones who offered to give it to me over the phone..
Oct 27, 2008 | 1995 Mitsubishi 3000GT
I need my radio code for 1986 bmw 325 es
Go the dealer ad they will reset it for you and/or find the right allen wrench and take it the radio read the radio serial/model number to the dealer they can give ti to you over the phone
Oct 04, 2008 | Car Audio & Video
Lands Phones Logo
14 people viewed this question
Top Nortel Lands Phones Experts
george  peters
george peters
Shehu Pro
Shehu Pro
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
