Question about HP PhotoSmart Office Equipment & Supplies
Why does my printer say incompatible ink cartridge
  • 59 Answers
SOURCE: Dell 810 All-In-One InkJet Incompatible Ink Cartridge error message
Well, first off ,it's dell's fault, not yours. Even Official Dell cartridges are temperamental at best. The cartridge error you are explaining is common with Dells. They even have what's called a marriage issue, meaning the cartridge will work in only one single printer. However, I'm not sure how to fix it. Sometimes, you can install a new one and the other cartridge you never touched gives you fits, and goofs up. I'd say get a new printer. Dell is increasingly getting more stingy with their ink, and truth be told, I don't think their quality (*lexmark makes dell, so stay away from them too) matches HP or canon. If you want the best cost per page, get a canon that has individual ink cartridges. They are easy to refill, and print a great picture. You pay more $$ up front, but you'll save a ton in the long run
Posted on Jan 07, 2008
  • 5 Answers
SOURCE: Hp deskjet D2560,incompatible cartridge
pls check your cartridge carrrier.
Posted on May 29, 2009
SOURCE: problem of incompatible cartridge occure in my new J 4580
i had the same problem with the hp 4580. i needed to replace the black ink which i did. then the error message appeared "incompatible print cartridge tri color"...chatted with hp customer support, wasted a hour. claimed its a hardware problem need to have it fixed. i asked would i be charge he said yes but the printer was under warranty. he asked other questions...bottom line i left the chat box....bought another hp 4580, used same cartridges, same message...THEN finally i replaced the color cartridge...and BAM! it worked on both printers. solution...replace the color cartridge...cons..if this happens again its a waste of money to keep buying the colored ink...
Posted on Jun 10, 2009
  • 685 Answers
SOURCE: my hp officejet J4680 printer is giving an error
Try this...
Posted on Oct 26, 2009
SOURCE: Incompatible print cartridge
Take out the print cartridge. Clean the points on the cartridge with cotton swab and try using it again.
Posted on Nov 04, 2009
What is a incompatible print cartridge? Its coming up with a warning exclamation mark and it wont print?
What is a incompatible print cartridge? The printer "Thinks" that the print cartridge, is NOT an original HP PhotoSmart one. Even print cartridge have chips.
Mar 28, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Changed black ink cartridge for epson stylus d120 but not working
Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
i.                     Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii.                   The Cartridge electronic panel  is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning.  This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Mar 24, 2010 | Epson Stylus cx7450 All-In-One InkJet...
I just put new cartridges in my printer, won't print
“All lights blinking and printer not responding” is indicative of serious ink cartridge issue. Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
Dec 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Will not print
Dec 09, 2009 | HP DeskJet 920c InkJet Printer
Canon MP460- printer head slams end limits and alarms out
This could be indicative of serious ink issue. This could be as a result of a number of scenarios. But firstly, make sure you have replace he right cartridge.
i. Ink has developed incompatibility. Solution is try an older/another cartridge (doesn’t matter if ink is finished). If it stops blinking it confirms that your cartridge has become incompatible. Also if your printer is the type that can work with only one cartridge, remove one after the other to determine which in the set (black or color) has become incompatible. Just replace the incompatible one and start printing again.
ii. The electronic panel on the cartridge that contact with the cartridge carrier inside the printer is dirty and needs cleaning. Solution is try to clean with a piece of folded tissue paper soaked in a bit of methylated spirit. Also clean where the cartridge carrier where it makes contact.
Dec 04, 2009 | Office Equipment & Supplies
"incompatible cartridges"
Usually if you leave the printer off for sometime the ink get dry on the heads or some ink may leake to the sensores so take the cartrage out clean it and clean the heads with cotton swaps...see if the help and let me know
Sep 13, 2009 | Office Equipment & Supplies
Problem of incompatible cartridge occure in my new J 4580
Feb 03, 2009 | HP J4680 Office Jet All-In-One Printer
Cannon Incompatible Ink Cartridge Issue
I refilled my ink cartridge and you have to reset the chip on the cartridge,go back where you refilled your ink and ask them to reset the chip.Thats if you refilled the ink or you baught a canon one return it to the store.
Dan
Sep 10, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
14 people viewed this question
Seeker5211
Seeker5211
