Question about Troy Bilt Tb20cs 2 Cycle 31cc Gas String Trimmer 17" Cs
Cs 20 how do I get it back to where it will crank the unit
It seems to be off track troy-bilt 2-cycle tb20cs weed eater
SOURCE: belts slippin on troy bilt horse
Have you adjusted the locking cam for forward. This cam is held in place with one bolt. The further you move it down the tighter it will make the belt
Posted on May 05, 2009
SOURCE: how do i put a troy-bilt tiller 3 hp.into free
The way to move without the motor running...
1.on each wheel pull pin in center of hub
2.push wheel closer to motor.
3.put pin back in to axle but not though hub
4.do the same steps to other wheel
now you can push tiller
Posted on Aug 05, 2009
  • 65 Answers
SOURCE: troy built weed eater won't feed line
Check the size of the line,(OD), make sure you are using the correct size, sometimes cheap line will be problematic, also, you said you are re-stringing it, try a new batch of string, the old string inside the hub can get chaffed and will stick to itself...
Posted on Aug 22, 2009
SOURCE: lost manual for troy bilt weed eater mod#tb514cs 4cycle
I didn't find that exact one either, but recently had to work on my Yard Man 4-Cycle Straight Shaft and used a Troy-Bilt manual for a similar trimmer - worked great.
If you don't find yours at this site, maybe a similar one will work. It looks like the difference is the TB525 receives attachments. If you're trying to fix something right now, here's the manual for that one until you find yours:
http://lawnandgarden.manualsonline.com/manuals/mfg/troybilt/big_red_tb575ss.html
Posted on Sep 08, 2009
  • 10865 Answers
SOURCE: I have a Troy-bilt 2-cycle trimmer
Begin by changing the spark plug, and checking to be sure that the fuel is fresh [less than a month old]. The best way to check for sure to see if you have spark is to unscrew the spark plug, hook it up to the wire and then pull on the cord. You should see spark. This works best with an assistant to pull while you hold the spark plug 1/2 inch from the metal on the machine.
Posted on Nov 03, 2009
String trimmer tb20cs doesnt seem to be getting spark
hi
that is your ignition wire
along the ignition wire (sometimes called the lead wire)
there is a diode this diode is braking down
and is not repairable
just replace the complete ignition wire
that should sort out your problem
regards
Apr 17, 2014 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Troy bilt trimmer idle problem position 2 shut off
try fresh fuel fuel is only good for 30 days in small engines if not the carb needs a good cleaning
Jul 25, 2012 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Pull string comes out 1/2 to 3/4 of the way and stops...doesnt crank the engine. What needs to be done?
pull off the recoil housing and see if the motor turns fully with out it if ok pull the rope off the engine does it pull all the way out
Mar 29, 2012 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Whats the gap on the spark plug on troy bilt tb20cs
Hello, Johnny -
The correct gap is .020" (0.5mm).
Link to specification page in owner's manual attached.
Troy Bilt TB20CS Operator Manual Specifications
Mar 06, 2012 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
I nee help rebiulding the carb on a troy bilt weed eater model TB20CS
Go to smalleng.com they have great rebuild videos. Good Luck
Aug 30, 2010 | Garden
Only used my trimmer 5 times since I had, trimmed my hedges 2 times last year & twice this year. After done doing my hedges, I put on my weed trimmer when finished & holding my trimmer in idle it...
Some disassembly may be required to get to the starter/recoil unit to fix this. The unit has Torx head fasteners and some level of mechanical skill is involved. Check your warranty?
Aug 13, 2010 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Troy Bilt 4 cycle weed eater - trimmer head doesn't spin
rotate attatchment head slightly while inserting driveshaft
Jul 30, 2009 | Garden
Tryingto replace my troy built weed eater's head
Replacement head can be purchased from amazon, here Amazon com troy built head. I hope this helped you. Have a nice day. Vince
Jul 12, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy Bilt Tb20cs 2 Cycle 31cc Gas String Trimmer 17" Cs Logo
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
