I cannot see the Caller ID until I pick up the phone. What can I do to be able to see who is calling before I answer the phone?
SOURCE: Caller ID not working
This is a Definity system phone. The phones themselves have nothing to do with caller ID, it's the system that handles it. The phone line has to have the caller ID service AND the phone system needs to collect the information and then display it on your phone. If you are sure caller ID service is available on the phone line you are using than this is a programming issue. Definity is a huge system and you cannot program it yourself. Someone in your building is either in charge of making simple changes in the phone system or contacting the company that makes these changes for you.
SOURCE: how do i record the main greeting on a comdial edge 120
I just went thru this.
Push the Voicemail button, hit # until it asks for mailbox #, then hit 70 for password. Wait for main menu, then hit 3 for options. Then hit 2 to record your greeting. Now the tricky part,,, I don't know if these are all programmed the same way, but it will ask for the number of the box you wish to change, ours is 800, then follow along.
good luck!
What I'm trying to find out is how you can import a prerecorded message (mp3) as your greeting.
SOURCE: Uniden CXA15198 not showing caller id
Had a similar issue with a brand new DECT2035 uniden phone, displaying incoming call not caller ID.
Checked my old uniden phone, and it was receiving CID. So I connected my DECT2035 to that line and then lo and behold I got my CID.
After further investigation I found that CID on my dect phone wont work if its using a shared filter (ie. adsl/phone splitter). Had to find an unfiltered splitter and then just put a phone filter (that I got with my adsl modem) onto the line that is directly connecting the phone. and then WOOHOO I have caller ID.
Hope this helps you... I got my wife a little cranky over this one cos it took me over an hour and a half to try and sus this one out =)
SOURCE: CALLER ID ONLY SHOWS "INCOMING CALL"
I was using this site while trouble shooting this in the US...
If the customer has DSL with filters in the same system go back to the NID and Isolate the DSL,
test the caller id and call waiting caller id. If this works you have Data Bleed coming from the DSL.
Make sure there are not two sets of filters on the line. Tjis customer had a filter with the DSL modem.
Doing this we just fixed an on going problem for a field tech who was the second callout on a customer issue.
SOURCE: Caller ID not working on my t7316 phone
You can copy and paste this link below to go to a site where you can download your entire manual:
http://www.alphatelecom.ca/meridian_norstar_manuals.htm
If this does not fix your problem, contact your authorized Service Center.*
