Question about Scotsman Kitchen Appliances - Others
I have a scotsman prodigy cu2026sa-1a that is dumping ice but not going out of harvest mode. Have replaced harvest pin and also replaced the curtian switches on the unit. Still having the same problem. Just wanted to see if anyone else has any idea on what else i can try to do to fix this problem. Thank you.
SOURCE: Scotsman CM250AE Ice Machine tech help
Check the bridge size adjustment at the top of the metal grid that the ice forms on. This determines the size of the cubes. Whenever you make a repair on the water system, especially on an older unit. make sure the unit is clean. A little bit of calcium deposits (or that other nasty looking stuff) getting into the passage ways will make it run erratically, and can drive you nuts.
Posted on Nov 07, 2007
SOURCE: harvest cycle on ice machines
My ice machine Hoshizaki km-500 mah is cycling to fast. Causing poor production of ice it's real small and it doesn't produce enough ice aswell. Wha seems to be the problem.
Posted on Nov 30, 2008
farfield
  • 462 Answers
SOURCE: Scotsman ice machine(sce 275g)
The older cubers were opperated by a cube size thermostat. when the temp reached the cube size tstat setting it would energize a harvest timer motor and this timer would continue running through a holding switch on the timer. when the cam comes around and the micro switch drops the water is introduced (it would be warm) and the hot gas from the refrigerant would be introduced to the evaporator causing the cubes to drop. at the end of the cycle the cam pushes op in the holding switch and finally open it and because the cube size tstat is now warm the timer motor stops.
The timer had a white plastic stem with a 1/4" D shaft. It would only turn clockwise. Try looking for this and advancing it to see if your sol valve will open or get voltage to the valve.
Posted on Jun 02, 2009
  • 102 Answers
SOURCE: Brand new Scotsman DCE33 ice maker melts ice
Check that the condenser is clean, the plastic sheet is hanging over the opening and trhat both spray nozzles are in place.
Posted on Aug 06, 2009
SOURCE: hi.my scotsman mv 450 ice machine harvest cycle is
ir_ah77@yahoo.com
Posted on Feb 22, 2010
Model C0330SA-1A sump temp sensor failure
Sump temp sensor is not reading water temperature of water running over evaporator plate.This sensor is located in the water supply tube that runs up to the top of the evaporator plate. just pull the sensor out of the tube and replace it.
Jul 10, 2014 | Scotsman C0330SA-1A 350 Lb Half Size Cube...
Why won't Ice maker make ice?
Scotsman Prodigy - bad Ice thickness probe
May 10, 2014 | Prodigy Scotsman CU1526MA-1A Ice Maker...
Scotsman prodigy leaking water
How to work on Scotsman Prodigy Ice Machine
Jan 16, 2014 | Scotsman Kitchen Appliances - Others
MY SCOTSMAN ICE MACHINE IS MAKING ICE, BUT ITS TOO HARD AND CHUNKY HOW CAN I FIX THE PROBLEM
First is the ice to thick coming off of the evaporator plate? If so then you need to adjust the ice thickness probe located at the top of the evaporator plate it is white with a 1/4" screw going through it, turn if left an 1/8" at a time let it make ice and check each batch. Now for chunky ice is it melted together? If so then make sure the machine is not dumping water into the bin during harvest if it is then check the dump valve to make sure it is opening during harvest cycle.
Oct 31, 2013 | Scotsman Cooled Modular Contour Cuber Air...
Scotsman ICE MACHINE SHOWS NUMBER 6 IN DISPLAY
does it look like "6" or "b" , the "b" just indicates the ice bin is full. If the unit is not making ice, check the curtain on the outlet of the ice making coil to see that it is not stuck open. There is no listed "6" error code in the service manual.
Oct 09, 2012 | Scotsman Prodigy Air Cooled Cuber C0530SA...
Scottsman prodigy icemaker max harvest time codes-common causes.
my prodigy periodically flashes 2 which indicates slow harvest what does this mean?, is it common for time to time to flash 2, how do I correct it
Mar 14, 2012 | Scotsman Prodigy Air Cooled Cuber C0330SA...
Scotsman cme 506ae-1a harvest to soon. Where is the adjustment timer the harvest is also too long?
The water float rod in front of the unit serves as the fill stop as well as the harvest initiate. Difficult to remove to clean really well but not impossible. Harvest time is handled by the controller. First two or three harvests are long as the controller times out the harvests based on the blinking light of the bin full indication. After that is should get shorter.
Jul 04, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Kitchen Appliances - Others Logo
62 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
