Http www lgservice com
I need a manual for a WD3243RHD 7.5kg Intellowash washing machine
  • 58 Answers
Please visit LG Product Support (http://www.lg.com/ca_en/support-product/lg-WD-3243RHD) and click on Manuals
Posted on May 14, 2014
  • 172 Answers
SOURCE: Maytag Atlantis Washing Machine Button or loose item stuck in
Try a magnet to fish around, if your lucky it might be a coin.
Posted on Aug 11, 2009
blueextc3221
  • 15935 Answers
SOURCE: For printable (pdf) appliance manuals go to:
Thanks for that advice.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
blueextc3221
  • 15935 Answers
SOURCE: http://www.fixya.com/support/r823955-replacing_agi...
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Posted on Sep 18, 2010
blueextc3221
  • 15935 Answers
SOURCE: Causes of washing machine smell. What will remove the stink?
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Posted on Sep 28, 2010
kvhappliance
  • 218 Answers
SOURCE: http://www.youtube.com/watch?v=4PiCHrZ0d50&fea...
your brake/clutch assembly is malfunctioning... Replace the basket drive assembly it also comes with a new clutch/brake pad.
Posted on Nov 13, 2010
Need manual
we know that it is for a washer machine, cause your question is in that category, but wish is the one that you need? Brand? Model No.?
any way here you have some links to manuals
http://www.repairclinic.com/Shop-For-Parts/a11c52/Washing-Machine-Manuals-Care-Guides-Literature-Parts
you can see it on line or buy it
http://laundry.manualsonline.com/manuals/device/washer.html
repair manuals
http://www.appliancerepair.net/washing-machine-contents.html
LG
http://www.lg.com/za/support/washing-machines
Apr 30, 2016 | Washing Machines
Operating manual for LG intellowash 5kg WD80180N
you can go to appliancerepairplanet.vstore.ca to get a sevice manual on that model.
Dec 21, 2010 | Washing Machines
What is the stain cycle do?
http://us.lgservice.com/index_b2c.jsp click service click owners manual and put in that it is an appliance, dryer and your model # click on the pdf owners manual you can copy this if you like or just read it and save it to the computer
Feb 16, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Users manual
The LG Canada website has it.
http://ca.lgservice.com/index_b2c.jsp
Click on "Owner's Manuals" on the left hand menu and fill in the details, model number WF-T8016TP. You'll need IE, not Firefox...
Jan 24, 2009 | LG WFT1071TP Top Load Washer
Need owners manual for LG Reveal
http://www.lge.com/support/manual.jsp
or
Click on owner's manual button when you get there.
Dec 30, 2008 | Cell Phones
Lg privilege 1,96ft3, washer&dryer combo model:WD3243RHD. Start working but dosen't take wather. I belive drain pump is gonne. Where to buy part. I'm from Canada.
Find nearest service center @ http://ca.lgservice.com/index_b2c.jsp BUT FIRST,.... if your LG WD-3243RHD (note dash is part of this model number) is not pumping out check the filter. Filter is located behind the small access door at the lower left on front of the machine. (There will be some water in the pump area)
Sep 20, 2008 | Washing Machines
Child lock on - needs de-activating
hi..    here is the pdf user manual lin has been give . please download it..:
  1. Washing Machine. OWNER'S MANUAL. WD-3243RHD. WD-3245RHD. website : http://www.LGservice.com ..... To deactivate Child lock system, press and hold ...
    www.oasisappliance.com/products/lg/LGComboOwnersManual.pdf -
Sep 13, 2008 | Washing Machines
Washing Machines Logo
123 people viewed this question
Top Washing Machines Experts
