Question about Uniwell EX-560 Electronic Cash Register
Calibration utility sharp - Uniwell EX-560 Electronic Cash Register
I want to sharp 5015 toner calibration plzzzz tell me
Hello there is no calibration of toner in sharp....what is your problem why you want that?
can you explain more the problem you have?
Nov 01, 2014 | Office Equipment & Supplies
I have a 60 Inc LCD led 120 hertz . sharp aquos . And I want to know what is the best settings for the picture? I tried adjusting it but it looks like a normal tv want to know the beat settings for picture...
The best way to set up a TV such as yours without a calibration device is to get a high definition picture of someone's face on the screen and adjust the color, brightness and contrast until the face looks as life like as possible.
Feb 16, 2012 | Sharp Televison & Video
Calibration issue
Hi Eli,
I suggest you to run the clear calibration utility from the devellopers:
http://www.wingmanteam.com/latest_software/gadgets.htm#Clear Calibration Utility:
Thanks and have a nice day !
J -
Mar 27, 2010 | Logitech Cordless USB Freedom 2.4GHz...
I have copier in the name of Olivetu 16 cpm like sharp AR 5316, My machine toner finished so we are not available olivetty toner in this market, if i put sharp AR 5316 copier toner, then F2 signel is...
If that machine is not made by Sharp you can't interchange toners with other machines. On Sharps If you get a F2 code it means the toner ratio and sensors are not calibrated correctly probably due to the toner not being compatible. If it is compatible the sensor could be dirty and it needs to be calibrated again.
Mar 19, 2010 | Office Equipment & Supplies
Armada E500 notebook Power button not responding.
Unless you took the batteries to a service center, I am dubious about your ability to confirm the main battery is holding a charge. The average lifespan of these kinds of batteries range between 3-5 years and is likely at the end of its lifespan. This would explain the diminishing performance over the last year if there were significant power or power circuit issues, they would likely be observed on AC power as well. This model of laptop requires the battery calibration utility be run in order for the laptop use the battery. In fact, the battery can show a full charge and still not function if the utility and battery have not been properly configured.. . . instructions on HOW TO do this below. If this doesn't FixYa then the battery will need to be replaced (links to replacement sources) www.BatteriesOvernight.com/HP-Batteries,----- OR --- www.new-laptop-battery.com/Compaq/?Compaq-Armada-E500-battery.htm. You will still have to run the configuration utility when you receive your new battery.
Link to Armada e500 manuals:http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01124216/c01124216.pdf
How to run config utility: Standby and hibernation must be disabled for the battery to discharge completely and shut off. To use the Battery Calibration utility, first identify whether the battery requires calibration by launching the Power Management applet as described above. On the Battery Calibration tab, all installed batteries will be displayed in the primary list box. Next to each battery name will be an indication of whether calibration is required for that battery. If calibration is necessary, the phrase “Needs Calibration” will be displayed. Select the battery to be calibrated, and click the Start Calibration button. During calibration, the utility will display an icon on the Windows System Tray to indicate that calibration is in progress. Each phase of calibration (charging or discharging) will also be displayed. Calibration is complete when the icon is no longer displayed in the System Tray. Battery calibration requires several hours for completion. If you choose to continue using the computer during the calibration process, it must be connected to AC power. The calibration process must be allowed to finish without interruption. Performing any of the following actions will prematurely terminate calibration:  Clicking the Stop Calibrating button in the Compaq Power tab.  Unplugging AC power from the computer.  Unplugging the calibrating battery. (This action may result in data loss if a second battery is not installed.)  Undocking the computer.  Pressing the power or standby button.  Powering down or suspending the machine by using the Windows menu. IMPORTANT: If the calibration process is interrupted, it cannot be resumed. You must restart the computer and start the process again.
CALIBRATING WITHOUT THE UTILITY To calibrate a battery on computers without the battery calibration utility, complete the following steps: 1. Remove the second battery, if present, so that only the battery needing calibration remains in the computer. 2. Dock the computer or connect the computer to AC power. 3. Turn on the computer. 4. Check the current battery capacity level by positioning the cursor over the battery icon in the system tray. 5. Allow the battery to charge to 100%. You may use the computer, but the recharging process will require more time. 6. Set the system to “drain” mode on the battery conservation settings by pressing Fn+F7, or select Start > Settings > Control Panel > Power (or Compaq Power in Windows NT). 7. Undock the computer or disconnect the computer from AC power. 8. Restart the computer in MS-DOS mode by clicking Start > Shut Down > Restart the Computer in MS-DOS Mode > OK. 9. Allow the computer to discharge until it shuts off. 10. Dock the computer or reconnect AC power. 11. Allow the computer to charge again to 100% as in Step 5.
Feb 19, 2010 | Compaq Armada E500 Notebook
Joy stick will only work on the left side .when you try the right side it will not work
Have you run it through its built in calibration utility. If not it is available through the control panel>game controls> calibrate
Or the games you play may have a calibration utility in the options menu.
Aug 27, 2009 | Logitech Wingman Extreme 3D Pro Twist...
Logitech zero calibration reset method
Have you tried using the Logitech calibration uninstall tool that erasers all joystick calibration from windows.
Download and run the Logitech Clear calibration (LWS_CLRC.EXE).
The Clear calibration Utility was developed by Logitech to resolve calibration problems with Logitech digital gaming devices.
NOTE: This utility strips all calibration information in the Windows Registry for all gaming devices. This includes any non-Logitech gaming devices that have been installed.
You may also want to uninstall and reinstall the Joystick Software as well. In some cases, if the calibration issue is within a game, you could try uninstalling and reinstall the game.
Please refer to your game manufacturer for instructions on uninstalling or configuring the game.
Note:
This calibration tool specifically mentions the Wingman Joystick, However, it works for ALL Logitech and NON logitech Gaming Joysticks and Gamepads.
Jun 06, 2009 | Apple Logitech Freedom 2.4 Cordless...
I bought a sharp 46" lcd hdtv,love it.When I bought it at Best Buy the told me I would need to have it calibrated after about 100 hours or about 2 months of use.I paid for the calibration and when the...
Unless you have noticed a decrease in picture quality, I would not worry. LCDs do not need routine adjustments. Best Buy may have fibbed a little. If your picture has declined, then you have an electronic parts failure and I would pursue a service call for that.
www.classtorations.com
Jun 08, 2008 | Sharp Televison & Video
Uniwell EX-560 Electronic Cash Register Logo
27 people viewed this question
Top Uniwell Retail Supplies Experts
richie46
Electroboy
Electroboy
Tom Chichester
Are you an Uniwell Retail Supply Expert? Answer questions, earn points and help others
