Question about ASUS p4p8x-uay Motherboard
In desperation, please help - MAJOR USB port problems
I doubt it's this easy to get help, but I will just try anyway. I have an Asus Motherboard (P4P8X with an Intel 865P Chipset), and I am running Windows XP Home with every update imaginable installed. I have two problems:
1) Often when booting up it says there is some kind of error and to use Windows "r" repair to fix it. Rebooting generally bypasses the message and loads Windows.
2) REAL PROBLEM - I have an external drive, however it is really an internal IDE hard drive with an external case. It only hooks up via USB. The instructions say that if running Windows XP it will work when just plugged in since XP already has the USB 2.0 drivers. THE DRIVE HAS BEEN WORKING FOR YEARS, but I just noticed yesterday it isn't showing up in Windows anyway. I did some troubleshooting and it doesn't even show up in the BIOS ANYMORE!!! Occasionally when booting up it will say the drive is detected, but it still doesn't show up in the BIOS.
This drive contains ALL MY BACKUP FOR EVERYTHING!!!!
Question about possible solution: In my BIOS, it asks under IDE CONFIGURATION whether the setting should be "SATA", "PATA", or "PATA + SATA". The internal drive is a SATA connection, and the default setting is "SATA" (even according to the manual). What should this be set as?
  • 143 Answers
Ok well your settings should be sata as for your usb external drive on the drive it self the jumpers for slave master pull it out connect it back to your pc then turn on the power to the external drive see if this helps k
Posted on Nov 04, 2007
Good day i have mother board asus p5800-mx the usb port cannot work theirs no 5 volts in the port, pleas help me to resolve my problem thanks.
A) There are two USB headers on the motherboard.
They are rectangular in shape, and Blue in color.
One is to the immediate Right of the 3 white PCI slots.
Has 4 pins across the Top row, and 5 pins across the Bottom row.
May have USB56 printed on the motherboard next to it.
The second one is at the Bottom of the motherboard, below the Intel 82801EB southbridge chip; which is to the left of the CMOS battery.
May have USB78 printed next to it
(Turn motherboard photo 90 degrees to the Left, to be as it sits in your computer case)
EACH USB header supports TWO USB ports.
A Card Reader uses ONE USB header, with it's two cables.
Front Panel USB ports, are connected to one of those blue USB headers.
This USB header you know to be bad.
If the other USB header is not being used, connect to it.
The front of your computer is the Front Panel.
The USB ports in the Front Panel, should be connected by one common cable, and it ends in a plug on connector.
No? Not feasible?
Then suggest using a USB adapter card, in an open white PCI slot,
Product details indicate it has two internal USB headers.
This way you can connect the Front Panel USB ports to it.
Choose ANY O/S, and then download the manual.
Or, here is the direct link to the motherboard manual (PDF file),
For additional questions please post in a Comment.
Apr 03, 2013 | ASUS P5V800-MX Motherboard
Asus p5kpl-am in USB and Sound not detectiing
try to make an adjustment on your bios i think usb is disable try to enable it and sure all your usb will work.
Oct 12, 2009 | ASUS P5KPL-AM SE Motherboard
Problem with USB port on Asus P5KPL-AM SE Motherboard
Older motherboards have USB 1.1 ports;
newer motherboards have USB 2.0 ports,
which are over 10 times as fast.
It is Windows (not your motherboard) that should do the "Plug-and-Play" thing for devices connected to your USB port(s).
Note that some devices are USB 2.0, and will *NOT* work when plugged-in to a USB 1.1 port.
Either get a newer motherboard, or get a PCI add-on card that adds USB 2.0 ports.
Sep 10, 2009 | ASUS P5KPL-AM SE Motherboard
On board USB ports not working
Right click the mouse on My computer located on desktop- select Manage- select device manager- find universal serial bus controllers - click on universal serial bus controllers - u find some devices there - right click the mouse on each and select uninstall - after uninstalling restarting the computer.
note : ensure usb controllers are enabled in BIOS setup for this , u should press delete key  at the startup of PC and locate it in Intergrated peripherals
Dec 20, 2008 | ASUS M2N-MX Motherboard
Onboard USB prrs malfuntion
Try re-installing the motherboard drivers. Here's a link:
Hope this helps
Chris (ziraffa)
How to upgrade to hi-speed USB ports?
you answered it yourself.
"how can i upgrade my motherboard!"
add a pci sub 2 controller.
Nov 29, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Hello there.
It sounds like you do not have the additinal USB patch which you can download and install from here
The article for the patch is here, which addresses the problem with USB failing to work.
Please run this fix and your USB should be working, if not then please get back to us and we can try additional steps.
Hope this helps.
Jun 28, 2008 | ASUS P4S8X-MX Motherboard
USB ports setting
Do you have them setup according to your motherboard diagram?
Apr 30, 2008 | ASUS P4S800D-X Motherboard
Usb problems
Though this motherboard is not fully VISTA capable, you may still be able to try it out using either VISTA built in drivers or their native Windows XP device drivers.
Please kindly refer to the page below for a list of "VISTA installable" non-VISTA compatible motherboard:
Nov 25, 2007 | ASUS A8N-SLI Deluxe Motherboard
ASUS p4p8x-uay Motherboard Logo
98 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
