Question about Vacuums
How to replace belt on Hoover c1403 - Vacuums
How to replace hoover nano belt
Hoover Flat Vacuum Belt UH20020 Nano Upright 562633001
this is the belt you need
take off bootom plate and replace
Jun 20, 2016 | Hoover Vacuums
Why does my hoover belt keep snapping?
Hello! Your belt will need to be replaced about twice a year. If your belt is breaking within a couple uses of you changing it, you may not have the correct belt for your vacuum. Double check the owner's manual or Hoover.com to verify the belt number for your vacuum. Always replace the belt with a genuine Hoover belt. Hope this helped!
Aug 25, 2014 | Hoover Vacuums
Where do I find the bags for this old c1403 one?
Were these generic bags or Hoove brand? Also, I believe that some bags have a rubber seal on the inside of the hole to attach. I hope this helps. Type A is the correct one.
Apr 21, 2010 | Hoover Commercial C1403 Bagged Upright...
The bag was full, it has been changed - still no power when plugged in
It sounds like you have carpet fibers and lint that are stuck in the motor carbon brushes. That is common on this machine. You will have to take the motor out and have it thoroughly blown out will an air compressor.
Dec 11, 2009 | Hoover Commercial C1403 Bagged Upright...
How do I change the belt on my Hoover Elite Dual Purpose Vacuum cleaner? The belt part # is 38528-027. Where is the motor pulley?
The hoover belt number you listed (38528027) has been changed by Hoover to 38528040. Below I have listed a link to the manual that has instructions and a link to the belt you need. Hope this helps!
Hoover Elite Manual
Hoover Elite Replacement Belts
Nov 02, 2009 | Hoover Elite U5061-900 Bagged Upright...
The belt on my hoover cordless is not spinning when I turn it on
You need to replace the belt. Even though the belt may look fine it can be stretched and therefore it won' t turn the roller brush against the resistance of the carpet. You can get Hoover replacement belts here:
Hoover Replacement Belts
Oct 29, 2009 | Hoover Vacuums
How do I replace the drive belt in the hoover u6401?
Remove the plate from the vacuum's underside. You will see fourscrews or two clips that attach the plate to the vacuum. Removingthe plate will give you access to where the belts are running. Remove the old belts and replace with new belts. The hoover self-propelled models use two different belts. One is a flat belt Hoover #38528035 and the other is a V belt Hoover #38528034. You can find these belts at www.vacbelts.com on these pages:
http://www.vacbelts.com/hoover-38528035-belt.htm
http://www.vacbelts.com/hoover-38528034-belt.htm
Oct 14, 2009 | Hoover Vacuums
Chaning the belt
there is a plate on the underside covering belt and beater roller
2-3 screws to secure the plate
then withdraw the roller
put new belt round roller
insert roller
pull belt around motor pulley
reinstall plate
Oct 05, 2008 | Hoover Commercial C1403 Bagged Upright...
Belt
You need to take the top cover off to get to motor shaft. Some had a couple of screws from the bottom, others had tabs, use a flat blade screwdriver to fit into the slots at the bottom edge of the top, pry out and up to pop the cover off.
Mar 08, 2008 | Hoover Commercial C1403 Bagged Upright...
Vacuums Logo
41 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
