Question about Sanyo DP26649 26 in. TV
HOW DO I CHANGE CHANNELS WITHOUT A REMOTE FOR A SANYO DP 26649
    Master:
  • Sanyo Master
  • 505 Answers
Check for the manual panel of buttons at the side or bottom of the TV. This can be used to do manual changes without a remote.
Posted on Jan 02, 2015
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: I do not have sound on 3 to 4 channels on my Sanyo DP 26649-04. All the other TVS in the house has sound on all channels. How can I fix this?
If this check both the set and a box if used to see if SAP etc is engaged--some cable / sat boxes have the option to mute or kill sound on selected channels.
Posted on May 06, 2012
Sanyo tv ds25030 how to program chanals 48-96
Your TV must be set in cable mode for channels higher than 69, and your cable provider must allow those channels to be received without a cable box. Menu, Channels, switch air to cable, run auto scan. If it receiving those channels unencrypted, it will find those channels.
Mar 10, 2015 | Sanyo Televison & Video
May 06, 2012 | Sanyo DP26649 26 in. TV
I have a Sanyo tv ( model #DS19330 ) and using a Sony remote to operate it. I am trying to restore channels 14-69 by scrolling through the channels with the remote. I can punch all channels in by...
It sounds like that the TV was set to skip certain channels. You need to rescan for channels or manually edit the channel list. To manually add channels, press Menu on the TV (or the equivalent key on the Sony remote if you found a code that works). Then use the Up/Down arrows (channel change keys) to select Ch Scan Memory + . Then enter the number of the channel (numerically or up and down arrows). Press + (volume + key) to change the setting from Deleted to Added or vice versa. Since you do not have the original remote, I'm not sure if the Sony remote will match the Reset key of the original remote. Unfortunately without that key being pressed twice, you can't reset the entire channel list and cause the channel search to begin automatically.
The manual for the DS19330 TV is here: http://www.sanyotv.com/DS19330%20%28ESF%29%203764--.pdf . (I'm assuming you haven't recently added cable after only receiving only OTA signals. If you have changed inputs like that, you need to go through the menu and change the source.) Menu > Cable or Air .
I hope this helps.
Jul 27, 2011 | Sanyo Televison & Video
My sanyo 26 inch model 26649 bought 09/09 has no sound on most channels but a few channels do
hi, it sieams like you should go into the menu and change the sound system, at the same channels that with out sound. to the system of your country. good luck!
Feb 14, 2011 | Televison & Video
Describe your sanyo moddel number DS27590Problem, I am trying to get the T.V off Video to go into a T.V channel without a remote and i need assisstance into how to do it. How do u Change the channel off of...
Hi there
Check the set to see if it has a source or A/V button. If not, the only thing that you can try is to scroll with the channel buttons up down buttons to see if you can get to the TV channels.
It is likely that you have already tred that:) If that has failed you, then you WILL need to remote to do this. I am sorry to say that this is the only way to get there. You can purchase a remote online from here
Not the only solution you have, in light of the impending change from analogue to digital... you could put your money towards a digital set top box and solve the remote issue at the same time. Check out what you can get from here. They start at less than $50, and could plug into the set you have eliminating the need to change it out of AV mode. You also get extra channels :)
Happy to answer any questions that you may have about it. Cheers
regards
robotek
Jun 19, 2010 | Sanyo DS27590 TV
Lost the remote and need to change from tv to video
try going through the menu keys and if this does not work try changing channels.
Feb 20, 2010 | Sanyo DS31590 31" TV
THREE BRIGHT BLUE SPOTS ON THE BOTTOM AND ONE ON THE TOP OF SCREE
Sorry, pero tu problema no tiene solucion, solo por garantia......
but I have something for you....
1. unplug the TV.
2. press and hold ch -
3. conect the plug again (green ligth on)
4. release ch - (service manu apear)
5. with remocon press down two or three times (find something like mp3) and change value from 0 to 1.
6. press exit
7. connect USB with pics and mp3 music.
8. check the pictures and.... the music start...
note. the USB slot must be empty before unplugged the cord.
Jul 04, 2009 | Sanyo Televison & Video
Sanyo TV is stuck on Video screen
Universal Remote should do it.
Sep 08, 2007 | Sanyo DS24205 24" TV
Re: Can't change from Video
You will need the remote to do this. If you can't find the remote get a universal remote with a video or input button on it. The other set may not be the same model and has different features.
Sep 06, 2007 | Sanyo DS13204 TV
Cant change channels
Your in the video mode so you have to change the input. On the original remote, its the button left of the power button. A universal may not work for this. If you need the original remote, Its available at http://www.remotes.com Good Luck
Aug 18, 2006 | Sanyo DS31520 31" TV
Sanyo DP26649 26 in. TV Logo
173 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
