Question about Dishwashers
Dishwasher CID45B10 problems
Button 3 flashing
Cid45b10 dishwasher not pumping water out and trips electrical supply when unit is switched on
If motor is jammed and not allowed to turn, current to it can result in popping breaker. Could be a gear issue, or something in drive that prevents it from turning. Open and check out all drive components.
Sep 01, 2017 | Dishwashers
Lighted "3" shows, dishwasher won't start
PRESS AND HOLD THE BUTTON NEXT THE LOCK3 LIGHT FOR 3 SECONDS TO UNLOCK THE CONTROL PANEL. TO RELOCK THE CONTROL PANEL PRESS THE SAME BUTTON FOR 3 SECONDS. THANKS AGAIN
Apr 20, 2014 | Maytag MDB7100AWB Dishwasher
I have a Bosch dishwasher model # shx4ap05uc/06 and I want to silence the alarm for when it is done. It goes off every 10 minutes until you open the door
Yes, you can switch the cycle completion signal off (or raise/lower the volume)
1. Switch the dishwasher off using the ON/OFF button
2. Open the door
3. Switch the dishwasher on again. (One of the wash cycle LEDs will flash.)
4. Hold the > button in. Continue holding it and press and release the Start/Reset button once, then release the > button.
"Clean" and one other LED should now be flashing. This indicates that the dishwasher is in the options/settings mode. If they are not flashing, start over at step 1.
5. Press > repeatedly, until the LEDs for "Clean", "Sanitized" and "Rinse Agent" are all flashing.
6. Press repeatedly until none of the LEDs are flashing.
The number of flashing LEDs indicate the volume setting . . .
0 = Silent
1 = Volume level 1
2 = Volume level 2
3 = Volume level 3
7. Press the Start/Reset button once to save the setting and exit the options mode
8. Close the door
9. Switch the dishwasher off.
Hope this helps. Please let me know if you need further assistance.
Regards,
BElectric
May 27, 2011 | Bosch Dishwashers
I have connected my new cid45b10 currys dishwasher, however it is not working. Makes attempt to go however no water is getting through.
Check all the valves in the line to assure they are fully open. Check the input of the machine, there may be a strainer incorporated with the washer. It may be there is debris from the installation blocking the water.
Thanks for your question at FixYa.com
Jan 30, 2011 | Dishwashers
Flashing start button, beeps, no other button functions
does it flash say 8 times then a little break then flash again 8 times or 9 or 10 . The flashes are giving the type of fault you have. Say 3 flashes then a tiny break then 3 flashes and a tiny break so on...
Mar 20, 2010 | Whirlpool Dishwashers
My maytag 200 quiet series dishwasher has a button with the number 3 next to the start/cancel button and will not start. The 3 flashes but won't start? Any idea what that means?
The control panel has bee locked. Press and hold the heated dry button for 3 seconds until the light next to the lock "3" button goes off. This feature is to prevent small children from starting it. Locking the controls works the same way, hold the heated dry button for 3 seconds will turn it back on.
Dec 13, 2009 | Maytag 24 in. MDB5651A Built-in Dishwasher
Dishwasher light flashes 7 times
although i dont have a lookup for your particular model number. if you remove the lower access panel you will find techsheet/troubleshooter. in it there will be section on "clen light blinking 7x" foplloe direction to put into test mode to clear the fault. belive its,,, heated dry/ sani rinse / heated dry/sani rinse. pushing htese buttons is what gets into test mode
Dec 11, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Dec 29, 2007 | Dishwashers
"3 second" light flashing
Pard, does your serial number end with either WS or WU? If so, Maytag had a issue with the main board, triac shorting and possibley damaging the motor windings. If your serial numbers fall under this, you are probably covered under the service flash. Im not really sure what you mean by the 3 second button flashing. Check the numbers first and post back. Catriver.
Apr 21, 2007 | Maytag MDB7100AWB Dishwasher
Dishwashers Logo
Top Dishwashers Experts
