Question about Telex Airman 750 aviation headset
How to connect telex 750 airman to pc - Telex Airman 750 aviation headset
Sound became muffled(only lower frequencies) in both ears
An equalizer circuit or filter? No idea where this would as you only give the result not total environment.
Apr 01, 2014 | Telex Airman 850 Aviation Pilot Anr...
Hi, I am Kush Agarwal and I have been using the telex airman 850 for a while now. Just a couple of days back I noticed that the right side speaker of my headset is not working properly. The sound and the...
Old question, but may be somebody else is experiencing the same issue. The earcup without the boom has a noise cancelling board, so it could be one of the wires that goes from one board to the other one. Gently take the earcup off and look at the 4 wires that are soldered on top (red, black, shield and white). If one of these is cut, the speaker/anr won't work. You will need a very small soldering iron to repair it (no more than 15 - 20 watts). Good luck, hope this helps ;)
Aug 02, 2010 | Telex Radio Communications
CD driver problem for Telex SpinWise 4-52NH
Assuming you've used the 'eject' function in the software already.
Generic answer: Look for pin-hole size hole on front or back of CD drive (may have to open PC case to get at it) and push into it with the end of an unwound paperclip. Meant to release the disk. Hope this works for your drive.
Aug 04, 2009 | Telex SpinWise 4-52NH (301869000) CD-R...
Telex 56 to cobra 4 pin
Hi there!!
the yellw wire is not used on the microphone conector most of them are just cut and left in there loose as long as its not shorting out on anything!! The wiring for the telex 56 for your radio Cobra 29 LTD is as follows: PIN #1 Shield & Red, PIN #2 White, PIN #3 Blue, PIN #4 Black, Yellow wire not connected!!
If you notice when you have the connector apart on the back of the pins where the wires get soldered to the pins are numbered so you will know which pins they are or on the front side of the connector the pins are also marked wich numbers they are!! If you have any other questions please feel free to e-mail us at: bigdscbshop@hughes.net
Apr 18, 2009 | Telex M-560 Consumer Microphone
Telex ProStar VR12 VHF needs repair
I've been in contact with Telex and although the Prostar is obsolete they still maintain some repair parts. I would contact them:
http://www.telex.com/Support/
Jan 07, 2009 | Telex FMR-200H Professional Microphone
Telex prostar wireless mic.  leads came off of mic element.  One green wire and one black.  Which one connects to center of element and which connects to rim.
Hi..
The rim is "ground" or the (-) side of the mic.
Find out which wire goes to ground or a (-) on a battery.
Solder that one back to the rim
Dec 11, 2008 | Telex FMR-200H Professional Microphone
Telex BTR-500 Instruction Manual
I have a manual I can fax to you if you are interested. Email me your fax number, or e-mail address and I'll scan it. Send to: diann_sells_slah@yahoo.com.
Jul 26, 2008 | Telex Btr-500 set (71208000sp) Wireless...
Telex Airman 750 aviation headset Logo
22 people viewed this question
Top Telex Radio Communications Experts
Mike Charette
Andrew Taylor
Andrew Taylor
Are you a Telex Radio Communication Expert? Answer questions, earn points and help others
