Question about Tablets & eReaders
How do I reset my Proscan PLT8015-K Tablet back to factory without any outside volume controls
3 Suggested Answers
  • 18 Answers
SOURCE: How to do hard reset on tablet without volume
If it can boot, use Backup & reset option on the latest versions of Android or Privacy under older versions
Posted on Apr 22, 2014
newfie_todd
SOURCE: Proscan PLT8235G stuck on blue screen. Reset button just shuts tablet off, and problem still remains.
I have had the same issue with this tablet. After weeks of looking around on the net i have found a way to reset the tablet to factory settings when the power and vol down button will not work.
1. Download the firmware from the proscan website. http://www.proscanvideo.com/item.asp?itemnmbr=PLT8235G.
2. unzip the file and copy the files update.zip recovery.img and factory_update_param.aml to an external micro sd card.
3. Plug the tablet in and insert the sd card. Press the power button to see the battery icon then press the power button 5 times. Then let it run for 4 minutes and it should be set back to factory settings.
****NOTE***** If it fails to update then you still have the access to the recovery menu where you can do the factory wipe and still reset it.
Hope this helps.
Posted on Apr 27, 2014
My proscan tablet is locket and ican't unlocket it what can i do???
Since I don't know which exact Proscan Tablet you have, here is how to restore the PLT9045K.
1) Make sure the tablet is powered down.
2) Press and hold VOLUME UP(+) and DOWN(-) buttons, plus POWER button all at the same time.
3) Insert a metal pin in the RESET hole at the back of the tablet, then push and hold it for 2 seconds, while still holding the VOLUME and POWER buttons. Make sure the pin is pushed. It seems like nothing happened, but just keep on going to the next step.
4) Power ON the tablet and immediately, PRESS and RELEASE continuously the VOLUME UP(+) button in order to get the display as showing dead tablet (dead robot).
5) This is the critical part. Make sure you do the right sequence or you will start again from the beginning. Press and hold the POWER button, then press and release VOLUME UP(+), and the display will give you a screen showing different options.
6) Choose the option wipe data/factory reset, by clicking POWER button to scroll down. To execute the selected option, press VOLUME UP(+) button. The tablet will reboot back to its factory setting.
Jul 12, 2014 | Proscan 7-Inch Android Internet Tablet,...
How to unlock proscan android tablet plt8015-k-b
To perform a factory reset, you will need to do the following: -turn of the tablet -press the following and hold: power button reset hole -hold until you see android logo screen -poke the reset hole to navigate to `wipe data` or `factory reset` -select using the power button -select delete all user data -restart the device -choose restart/reboot after reset This procedure will delete all apps and data on your table
Jun 30, 2014 | Proscan Recertified - PLT7035 4GB NAND...
Proscan tablet support
Unfortunately, your tablet manufacturer maintains a "walled garden" of applications. That is, you can only install applications from a list of applications that they provide. Not all of the Android applications that are available through Google Play are available to this device.
The only way you'll be able to get around this limitation is to hack the tablet (if such a hack is available) to allow installation of either a full Android OS or other hack to allow Google Play. Doing this will void your warranty at least or could "brick" your tablet.
May 07, 2014 | Tablets & eReaders
Hope this helps.
Apr 02, 2014 | Proscan 8 4GB Android 4.1 Tablet
I have locked myself out of my tablet
You will need to do a factory reset:
Oct 29, 2013 | Proscan Recertified - PLT7035 4GB NAND...
Help how do hard reset my proscan tablet plt7035 i for got my pattern to unlock it
1. Power the Tablet off.
2. Press and hold the Volume Down button of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
5. Navigate to Erase content.
All info on tablet will be deleted but not the info in the SD card
The tablet will complete the hard reset process and reboot into a factory default state.
Oct 19, 2013 | Proscan Recertified - PLT7035 4GB NAND...
I have a Proscan PLT7223GK6 Android tablet, and I can't seem to get it unlocked. I am not using a pattern to unlock the device. Is there a way to reset the password without resetting the whole device?
Tablet PLT7223GK6-B ((Solution)) Funtional
1. Power off the Tablet.
2. Press and hold the Volume Down button of the device, then a press and hold the Power button.
3- when you leave proscan logo, you can release the botton
4- leaving snowman Android, Press and hold the Volume up button, then Press and hold the power button.
Until you see the menu.
up / down- escojen the option to make
power button- the selecionan
5- Wipe Data / Factory Reset
6- Reboot System now
May 17, 2013 | Tablets & eReaders
Tablets & eReaders Logo
77 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
