Question about Ryobi Saw. 4.8 Amp Variable-Speed JS481L
How to replace blade on ryobi js481l jig saw - Ryobi Saw. 4.8 Amp Variable-Speed JS481L
SOURCE: changing the saw blade on a Ryobi Mitre saw
There may be a push button type blade lock, and on many of these saws the retaining bolt for the blade is backwards threads, e.i., looking at the top of blade retaining bolt, turn it clockwise to loosen. This would normally tighten, but in the case of many of these saws, it loosens it.
Posted on Feb 09, 2009
Editor925
  • 285 Answers
SOURCE: How do I replace my mitre saw blade?
It should still easily fit a 5/8" blade. The arbor shape shouldnt have any effect on the type of arbor hole needed on the saw blade (only round arbor holes are made on saw blades. You will probably find the arbor securing nut has a shape that fits into the flat gaps between the saw blade and the arbor when fixed. So grab a 5/8" round arbor saw blade and give it a go. It should work fine.
It is the arbor nut that secures the blade onto the arbor via friction which holds it on.
Please rate this solution on FixYa!
Posted on May 29, 2009
  • 11 Answers
SOURCE: loose replacement blade
I completely removed the blade and put it back on, tightening the locknut, and now it works perfectly. The blade has not come loose and have used the machine for the last 3 months. The only thing I can think of is that somehow I didn't have the blade correctly installed in the first place, although it didn't wobble or anything.
Posted on Jun 05, 2009
  • 5603 Answers
SOURCE: ryobi 18v circular saw owners manual - blade is loose!
Usually there is a button to press that locks the shaft arbor and then you use a wrench to tighten OFTEN is a left hand thread!
Check for lock button behind the blade guard toward the motor.
Posted on Sep 28, 2009
Testimonial: "Thanks; that's the advice I got when I tracked down the number to call Ryobi. However, it doesn't seem to be working. Now sure what is wrong :("
  • 10865 Answers
SOURCE: To get the blade guard on a Ryobi circular saw to stay up.
Hello. The blade guard is specifically designed to not stay up but instead to only come up as the wood pushes it up. This is a problem when you are trying to do a plunge cut but it is a safety feature. Joe
Posted on May 05, 2010
Testimonial: "Your feedback is very much appreciated. Thanks."
What type of blade do I need for a jigsaw ryobi js500qeo
Any type of jig saw blade will work, the are universal....
Feb 25, 2015 | Ryobi Saws
I need a manual for CJ500 jig saw. I can't work out how to change the blade.
Ryobi has a customer support questionnaire that you can fill in to ask a question http://ryobi.custhelp.com/app/support/ask/incidents.c$enquiry_type/11
I suggest that because their database of instruction manuals seems to be having problems. I did find a picture of one of those saws and it appears that there are 2 hex screws that hold the blade in. it's the hex caps in FRONT of the top of the blade. Loosen those hex cap screws and the old blade should fall out.
Jan 16, 2015 | Saws
How do I change blade on Ryobi compact saw please
Which exact saw are you talking about? Jig saw, circular saw, plug-in, or battery? It does make a difference, you know...
Jan 07, 2015 | Ryobi Garden
Extracting broken blade not sticking out of blade holder
Spray with WD 40 and insert Needle nosed pliers to grab and pull it.
Nov 30, 2013 | Ryobi Js550l Jig Saws
Jig saw b4300 blade replacement
This tool has no mechanism for the fixating ot the saw but only a short ***** part 53 its a fault in the manual , it simply replace the saw with a screwdriver. or simply the clamp ***** to release turn it loose and from the top you can replace the clamp *****
Bosch B4300 0601582535 Jig Saw Parts
Sep 05, 2013 | Bosch 1581AVSK Top Handle Jig Saw Kit
Hi I have a Black and Decker Jig Saw 7588 Type One that works fine but I can not find replacement blades for it here in San Diego, California. Where can I find the blades?
I have the blades and the 7588 jigsaw. thinking about selling on ebay. search for black & decker jigsaw w/ blades in next couple days if interested in buying saw with 6 blades. thankyou, makthriftsales
Jan 14, 2013 | Black & Decker Single Speed Jig Saw
Trying to change blade in Ryobi P520 Jigsaw
Go to this LINK and find the part/diagram that can help you.
Please thumbs or post back,thanks
Nov 02, 2010 | Ryobi 18 V Orbital Jig Saw P520
I am trying to replace the blade in my scroll saw because the other blade broke and I can't seem to figure it out. Any suggestions?
Manking an assumption that yours looks like this one below?
If so, you'll need to flip up the yellow catch to release the jig blade. Sometimes they get a bit stiff, so wearing gloves try and waggle the blade free. There is normally a tensioner at the back that guides the jig blade (like a roller) that can also be loostened off to get the blade out
Install is reverse of removal
If this helps, pls leave feedback, if not let me know and I'll try and help some more!
Jan 27, 2010 | Ryobi Saws
Ryobi Saw. 4.8 Amp Variable-Speed JS481L Logo
177 people viewed this question
Top Ryobi Saws Experts
JOHN LAPIER
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
