Question about Jet 3 Ultra Power Chair
How to get batteries out
Wont to change batt in Jet 3 power chair
    Master:
  • 876 Answers
Posted on Feb 05, 2015
dromtonpa
  • 40 Answers
SOURCE: JET 3 POWER CHAIR SEAT REMOVAL
Sometimes it just takes some real elbow grease to remove those. Try two people one on each side.
Posted on Mar 31, 2009
SOURCE: All six lights blink on my Jet 3
I just had the same problem with my uncle's power chair. The number of "blinks" indicates a problem code to the technicians. My chair needed the joystick control assembly replaced. Once replaced, evrything was back to normal. 'Not a cheap fix but much needed. Good luck my friend!!
Posted on May 06, 2009
arrius
  • 3 Answers
SOURCE: need to remove the bad batteries Jet 3 power chair
Hello Donald ,
You may have solved this problem by now ,but just in case you have not, here goes.
Make sure the chair is turned off and engauged in the drive mode meaning not in the free wheeling mode. This way it will not roll around on you during the battery change out.
Go to the rear of the chair and slightly turn the two black plastic lock pins,one on each side they actually lock the small )) shaped cover in place. Turn these with your fingers or you can also insert a dime in the slot on top of each pin to turn them . You will be able to tell when they have unlocked as the )) shaped cover will be loose. Lift the cover up and under it you will find the battery connector, unplug it and leave the cover off for now.
Next ,move to the front of the chair and just to the rear of the footplate you will find a locking pin that runs through the lower rear bar of the footplate as well as the chair frame itself . Pull this pin completely out. Once done you should be able to pull the entire footplate assembly out torward you, Black plastic front cover included. Once you have it pulled outward lift it upward and it should lift completely off the chair. This done , you should actually be looking at the front battery which is sitting in a black plastic tray. Gently but with a firm grip grab the tray anyplace you can and slowy begin to slide it out from under the chair torward you taking care not to tangle the battery connector at the rear with any other wiring on its way out. Once you have the tray slid out into the open ,you will be looking at both batteries after which you will need to unhook the straps that secure the Batteries to the tray after which you will need grab your wrenches and remove the battery harness itself from each battery. You may want to do just one battery at a time this way you'll have less wiring to keep track of when wiring in the new Batteries. The Batteries in your Jet 3 are a size known as U-1 deep cycle sealed maint. free batts, You can use either Gel Cell or seale3d LA replacements . Though they are much cheaper, you cannot use lawn tractor batteries. Though they look the same the internal technology between medical powered mobility batteries and tractor batteries are entirely different. The latter would only run your chair for maybe a half hour or so before needing charge.
Take great care to make sure your wiring hookups are correct and that you position the rear connector plug to the rear of the tray. This way you will be able to locate it easier once you have slid the tray back in under the chair and it is time to go to the rear of the chair and reconnect that plug. As for everything else ,reattach it in reverse of the way you removed it including remembering to slide the lockpin back into the front footplate frame. Give a tug on the footplate when done to make sure it is locked and secure.
In closing I offer this valuable advice : When working with any of these batteries, always were safety glasses or goggle and gloves (terminals are lead). I also advise removal of metal rings ,watches, bracelets etc that could create a short when reaching in and around the battery terminal. Take great care with your tools and wrenches in making sure you keep and eye on both ends of the tools at all times. This way you will not accidentally cross the posts of the battery. Take your time ,use proper safety technique and you'll do fine. The following is Pride Mobility's step by step for battery change out and is basically the same as I have sent . Can never have to much info but can always find yourself with not enough. Take Care
To replace the batteries:
1. Turn off the power to the controller.
2. Make sure that the power chair is in drive mode. See III. "Your Power Chair."
3. Turn the rear shroud fasteners one-quarter turn in any direction. See figure 6.
4. Remove the rear shroud.
5. Unplug the battery connector. See figure 26.
6. Remove the retaining pin from the foot platform and lift the platform up and away from the power base. See figure 19.
7. Slide the battery tray forward.
8. Unfasten the reusable strap around the front battery.
9. Disconnect the wiring harness from the front battery.
10. Remove the front battery.
11. Unfasten the reusable strap around the rear battery.
12. Disconnect the wiring harness from the rear battery.
13. Remove the rear battery.
14. Place a new rear battery on the battery tray. Make sure that the terminals are facing forward.
15. Fasten the reusable strap around the rear battery.
16. Connect the wiring harnesses to the rear battery.
Posted on May 14, 2009
  • 29 Answers
SOURCE: pride mobility Jet 3 Ultra Power Chair 7 flashing
a 7 Flashe code. There is a joystick fault. Make sure the joystick is in the center position and then power off and on again. Check all your couplings. make sure when turning on the unit you only mash the power button for 1 sec. 2-3 sec will put the unit in "Lock out mode".
This ierror will also be present if the joystick is off center when powered up. If you experience these symptoms, you must first make sure there is no physical damage to the joystick preventing it from returning to the center position. Then turn the power off and back on again (making sure the joystick is not depressed in any direction. If the joystick repeats this error, the controler much be replaced. smithrmrm70@hotmail.com
Posted on Sep 07, 2009
  • 175 Answers
SOURCE: HOW DO I REMOVE THE SEAT FROM A JET 3 POWER CHAIR
It has a lock lever on the side. Push the lever and turn the seat slightly while lifting up with both hands. Sometimes, they need a pretty hard **** to get it to release, but it will come right off.
Posted on Jan 08, 2010
I changed the batteries in the jet 3 ultra. Chair will work but batteries will not charge
Wall outlet bad? Charger not turned on/plugged in right? Something disconnected? Bad battery connection? Blown fuse in chair or charger? Bad battery or batteries?
Aug 09, 2014 | Jet 3 Ultra Power Chair
Do yall repair a jet 3 power chair
Fixya does not repair power chairs.
Jul 14, 2014 | Jet 3 Ultra Power Chair
Batt. were left uncharged for a year. how do I recharge them. they don,t charge with the charger on the wheelchair.
You can't recharge them. they are dead and if you could they wouldn't last. You will have to spring for 2 new batteries. Check with an Interstate battery outlet and purchase 2 U1 sealed batteries for your chair charge before use and charge daily for 20 days to break them in. If you don't use the chair daily charge at least once a week Hope this helps
Jan 27, 2011 | Jet 3 Ultra Power Chair
Jet 3 Ultra, batteries 1 yr old, charge voltage only 26.3 volts output from onboard charger when batts drained after extended use. After charging overnight, batts are 12 volts each, but chair goes 1.5...
Mark Batteries your charger is putting our enuf 13.15 volts for each battery so after charging all night you should be reading about 13 volts on each. If your batts are only 12 volts after all night charge then batteries are weak Hope this helps
Oct 30, 2010 | Jet 3 Ultra Power Chair
Flashing red light batt. fully charged
Flashing red light usually means low batteries. Check the batteries after charging all night with a volt meter through the charger port you should read 26-24 volts dc. If you get a lower reading and you are sure the charger is working correctly then you will need to replace both batteries Hope this helps
Aug 21, 2010 | Jet 3 Ultra Power Chair
Battery will not fully charge but will run with partial charge
Two things can be wrong, first your batts may be old and need new ones. Have them load tested at an auto part store. Most powerchairs use two 12 volt batts. If you batts are good you should have between 12.5 and 13.5 volts on a surface charge and 11.5 to 12.5 on a load test charge. Second, if you had your chair stored away for a couple of months then your batts died and need to be replaced. If you are luck a "boost charge" might work. If you are planing to keep it stored for months at a time, you must charge the chair once every couple of weeks to keep batts fresh.
Mar 21, 2009 | Jet 3 Ultra Power Chair
WHAT MAKES THE CHAIR NOT MOVE WHEN CHARGING?
You cannot make a powerchair operate while it is charging. For safety purposes the power cuts out when charging batts. The only power is going to the batteries.
Feb 26, 2009 | Jet 3 Ultra Power Chair
Jet 3 Ultra Power Chair Logo
120 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
MobilityRepairSpecia...
Level 1 Expert
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
