Question about Intuit QuickBooks Pro Edition 2009 Full Version for PC
WHAT IS NEWEST VERSION OF QUICKBOOKS FOR WINDOWS XP
    Champion:
  • Intuit Expert
  • 237 Answers
The current version 2014 will run on XP, but it may be very slow.
Posted on Jun 24, 2014
3 Suggested Answers
SOURCE: Quickbooks Pro 2008 Payroll problem
Same thing here when attempting to "send payroll data", though mine's with pro 2009. I found this KB item which indicated that I should update:
http://payroll.intuit.com/support/kb/kbitem/1009052.html
I followed the update instructions here:
http://support.quickbooks.intuit.com/support/productupdates.aspx
Even though my update status was "nothing new" for each category, I hit the "Update Now" button anyway (it was enabled, why not?). It went through the motions of updating (even though there was nothing to update). When it finished, I closed and re-opened QB, then I was able to send the payroll data. This software is far from the gold standard I thought it was going to be.
Posted on Mar 20, 2009
  • 66 Answers
SOURCE: QB pro 2005 and Internet Explorer 8
As with all evolving software (as the well written ones are), as you update one you'll invariable need to update others. If you want QB Pro 2005 to work properly, you'll have to contact Intuit for any patches to their software to make it compatible with IE8. I suspect that Intuit would rather sell you an upgrade to their most recent version of QB Pro (hence lightening your wallet substantially). If there's functionality in IE8 that you absolutely HAVE to have, you'll probably be stuck paying for the QB Pro upgrade. Otherwise, you can simply stick with IE6 or 7 (as you've already reverted back to). Sorry there's not a better answer.
Posted on Aug 13, 2009
Can't install quickbooks 2005 on windows 8
Correct. That version was made well before Win xp. It does not understand the folder arrangements for Win 7 or 8. You would need a newer version.
Jan 24, 2013 | Intuit QuickBooks: Pro 2005 for PC
Cannot receive new password on 2009 Quickbooks
Intuit has an automated recovery tool to remove passwords. search the QuickBooks support site for Password Removal
Nov 07, 2012 | Intuit QuickBooks Pro 2009
I get an error when I'm closing Quickbooks Simple Start, The instruction at "0x56461f49" referenced memory at "0x036c4360". The memory could not be "read". Do you know what this means and how to fix it?
Assuming you have Windows XP, please follow these steps:
1. update QB . To update QB,launch Quickbooks and then go to Help>Update QuickBooks. In the windows, click UPDATE NOW.
2. Then go to Start>Control Panel>Add/Remove Programs. Then check mark SHOW UPDATES.
Then find Microsoft .NET framework 2.0 SP1 or SP2. Find update KB976576 or KB576976 and remove it.
3. Restart your computer and then launch and close QB.
ISSUE WILL GET FIXED
In any situation, this issue will never ever effect your QB data file.
If issue remains, reply with QB version and Windows Version?
Jul 10, 2010 | Intuit QuickBooks Simple Start Edition...
Aug 13, 2009 | Intuit QuickBooks: Pro 2005 for PC
Cannot open Quik Books 2007
Windows XP:
  1. Uninstall QuickBooks, Microsoft .NET Framework, and Microsoft Visual C++ 2005 Redistributable:
    1. Close QuickBooks.
    2. Click the Windows Start button and select Run.
    3. Enter control in the Open field and click OK.
    4. Double-click Add or Remove Programs.
    5. Right-click your QuickBooks program version and click Change/Remove.
    6. Follow the instructions to Uninstall QuickBooks.
    7. Repeat steps d through f to uninstall Microsoft Visual C++ 2005 Redistributable.
    8. Repeat steps d through f to uninstall Microsoft .NET Framework for your version of QuickBooks:
      • QuickBooks 2008 and 8.0 and later:Microsoft .NET Framework 2.0
      • QuickBooks 2007 and 7.0 and earlier:Microsoft .NET Framework 1.1
  2. Rename the QuickBooks program folder:
    1. Right-click the Windows Start button and select Explore.
    2. Browse to C:\Program Files\Intuit.
    3. Right-click the QuickBooks folder for the version you just uninstalled (for example, QuickBooks 2008) and select Rename.
    4. Enter OLD_ at the beginning of the folder name and press Enter (for example, OLD_QuickBooks2008).
  3. Insert the QuickBooks CD in your CD drive, and follow the instructions to install the program.
  4. Open QuickBooks.
Jul 09, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Cant get rid of Error 15103 Document Viewer
Error 15103 error symptoms can include program lock-ups, slow PC performance, system freezes, shut down and startup problems, and installation errors
uninstall regcure uninstall quickbooks.....run ccleaner and then cold start the pc ...now reinstall quickbooks .....reboot
www.ccleaner.com
good luck
Apr 05, 2009 | Intuit QuickBooks Premier Accountant...
Is quick books 2003 Vista compatabile?
QuickBooks Pro 2003 can run on Windows Vista. Right-click a shortcut to open Quickbooks (or qbw32.exe directly) and click on Properties. Select the Compatibility tab. Under Compatibility Mode, check the box and select Windows XP (Service Pack 2) from the list. Under privilege level, select "Run this program as an administrator." Select OK and everything will work.
Feb 14, 2008 | Intuit QuickBooks Pro 2003 Single User...
Intuit QuickBooks Pro Edition 2009 Full Version for PC  Logo
22 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
