Question about Humax Dtr-T1000 Youview Digital Tv Recorder
YVM105 Why are my internet channels not available?
How do I find a video to hook up my Samsung TV? Model BN68-04027A-03 The TV was a Xmas gift and did find a video and now I can't find it Tx. Wanda
The English owner's manual for the part number listed is available at...
http://www.manualslib.com/manual/146620/Samsung-Bn68-01171b-03.html#manual
Page six (6) indicates the back panel of your Plasma TV has two HDMI inputs, one component (RGB) and a specialized AV input/output connector. The latter requires a cable that is popular in Europe. Adapters to use it with US standard S-Video and RCA composite video are difficult to locate.
HDMI and component cables are available at big box stores (Best Buy, WalMart etch) but are much cheaper from generic internet sellers.
I am not sure about the second half of your question concerning "get to channel 3 to get to all other channels).
I must assume you have told the TV to "scan" for other channels (cable or over the air (OTA) with the black antenna/RF cable connected directly to the back of the TV.
If you have done so I am guessing you have connected the antenna cable first to a RECORDER or CABLE BOX. In many cases, these will only output channel 3 or 4 and block all other channels when turned on. In order to see other channels, you will need to buy a 2-way RF splitter so that both the recorder or Cable box can be connected at the antenna cable at the same time. Please note, doing so will mean you cannot see the output of the recorder or cable box on channel 3 or 4 but must use its the video/audio (HDMI, component, composite, S-Video) outputs from it to the TV. Again, this splitter is available from big box stores or the internet.
Jan 05, 2015 | Samsung Televison & Video
Channel no. of netflix
Netflix is not available as a channel and therefor will not have a channel number. You will need to access Netflix using an internet connected device, such as a computer, internet connected television, or video game console.
Visit http://www.netflix.com to get all the info you need to stream the availble movies and shows.
Hope that helps!
Mar 02, 2014 | Computers & Internet
How do I get local channels when my Roku is connected to my TV
The roku is a one way streaming device and cannot see channels that your cable tv can see. It streams online content to your tv.
However if you live in a major metropolitan area 1 or more of your local channels may be available online, you can set those up in your private channels area then searching for local channels in your area to add as private channels.
Jan 27, 2013 | Computers & Internet
I try to open websites through my wii system and it says i needs flash player. please help
Important Notes about the Internet Channel and Opera Browser
  • The information on this page describes the features found in the latest version of the Internet Channel (ver. 9.30). You can identify the version number of your Internet Channel by selecting the Opera/Home icon in the tool bar of the browser, then clicking on the "Opera Powered" icon at the top of the screen.
  • USB keyboard support is only available for version 9.30. Visit the Wii Channels section of the Wii Shop Channel to obtain the latest version.
  • The Internet Channel supports http and https. It is not compatible with other types of protocols, such as ftp, mailto, etc.
  • The Internet Channel is compatible with Flash, up to version 8. It is compatible with all earlier versions, but versions higher than 8 will not be compatible. There is currently no way to download and install higher versions of the Flash Player to the Wii console.
  • You can allow access to the Internet Channel through the Parental Controls of the Wii. If the controls are enabled, access to the Internet Channel will require the PIN to be entereed.
  • When entering website address, you do not need to type in "http://"; however, websites that begin with "https://" will need to be entered in full.
  • The Classic Controller, Nintendo GameCube Controller, and Nunchuk are not used with the Internet Channel. In addition, only one Wii Remote will work with the Internet Channel at a time. USB keyboard support is available for versions 9.30 and higher. Visit the Wii Channels section of the Wii Shop Channel to obtain the latest version.
  • Many types of video playback, such as QuickTime (.avi) and Windows Media Video (.wmv) are not compatible with the Opera Browser and will not play.
  • The Internet Channel costs 0 Wii Points to download, and is available in the Wii Shop Channel, in the Wii Channels section.
  • The Wii console supports cookies. At this time, there is no way to delete cookies without deleting the Internet Channel's saved data from the system memory
  • This information comes from: http://www.nintendo.com/consumer/systems/wii/en_na/channelsInternet.jsp
    Jan 09, 2011 | Computers & Internet
    Trying to connect my wii to internet but getting error code 32007 how can i fix
    Error Code: 32007 There was a problem downloading the latest Wii update.
    Please check the following:
    1. Our servers may be down temporarily or experiencing a high amount of network traffic, especially after a new update has become available. Wait a few hours and try again. If you are still receiving this error after waiting, check the next steps.
    2. Satellite Internet often causes this Error Code. You must have a cable or DSL internet connection. Other connection types, such as dial-up and satellite, are typically not compatible. Contact your Internet Service Provider if you are not sure what type of internet connection you have.
    3. Does your internet service provider (ISP) require that you log in whenever you wish to use the internet? If so, your ISP may not be compatible with the Wii console. Please contact your ISP for additional information.
    If you are still unable to connect, and have waited a few hours, please try the following:
    How are you attempting to connect your Wii console online?
      Wireless Router:
    1. Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. Be sure to try both channels if the first one you try does not work. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available). (The "Channel" setting is typically found in the "Wireless" section of your router's setup utility.)
    2. If adjusting the "Channel" did not work, please review our "Slow Download Times or Errors Received While Connecting" troubleshooting tips by clicking here.
    3. Are you using a Netgear brand wireless router? Our expeirence shows disabling the "SPI Firewall" of the router may help the connection. The "SPI Firewall" option is typically found under the "WAN Setup" tab of the router's settings. For information on accessing your router's settings, please click here and select the model of the Netgear router you own (if available).
    May 09, 2010 | Nintendo Wii Console
    I can't get Channel 4, E4, More4 etc. on freesat
    Channel Four is available on Freesat as follows:
    Channel 4 Freq 10729 Vertical 22000 5/6 -
    Enter these figures on your 'Search for Channels' menu, and it should turn up Channel Four.
    Mar 10, 2010 | Grundig GUFSAT02SD
    Trying to run wii systems update through the new BT home hub connections fine but I get an error code of 32004 can you help. Many thanks
    Error Code: 32004Please check the following:
    1. Satellite Internet often causes this Error Code. You must have a cable or DSL internet connection. Other connection types, such as dial-up and satellite, are typically not compatible. Contact your Internet Service Provider if you are not sure what type of internet connection you have.
    2. Ours servers may be trying to handle an unusually high amount of traffic (especially if a new Wii update is available). Please wait a few hours and try the connection again later.
      Wireless Router:
    1. Adjust the Wii's manual settings. Click here for more information.
    2. Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. Be sure to try both channels if the first one you try does not work. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available). (The "Channel" setting is typically found in the "Wireless" section of your router's setup utility.)
    3. If adjusting the "Channel" did not work, please review our "Slow Download Times or Errors Received While Connecting" troubleshooting tips by clicking here.
    4. Try temporarily disabling your router's firewall.* Are you using a Netgear brand wireless router? Our expeirence shows disabling the "SPI Firewall" of the router may help the connection. The "SPI Firewall" option is typically found under the "WAN Setup" tab of the router's settings. For information on accessing your router's settings, please click here and select the model of the Netgear router you own (if available).
    Nov 12, 2009 | Nintendo Wii Console
    Wireless internet dell inspiron 6400
    Things you can do to try and improve the connectivity are:
    1. Update the system BIOS to the latest version
    2. Update the wireless driver to the latest version (Both are available at support.dell.com)
    3. Try a different channel for wireless on your router (Most default to channel 6, so try 1 or 11)
    Jan 24, 2009 | Dell Inspiron 6400 Notebook
    Netgear WPNT834 wireless not working
    Hi Ashdan
    channel 6 is very common with 2.4ghz wireless phones. Try changing the channel to a different one ie. 2 to -5 is rarely used so i suggest one of those. Also WEP is very insecure and easily hacked. If the only risk is people stealing your internet then i suggest you use MAC filter as the most secure way and turn off wep. This will make your router and internet surfing experience even faster.
    good luck
    smeags.
    Jan 02, 2008 | Gateway 802.11g Wireless DSL/Cable Router...
    Humax Dtr-T1000 Youview Digital Tv Recorder Logo
    138 people viewed this question
    Top Humax Audio Players & Recorders Experts
    Jay Plesset
    Are you a Humax Audio Player and Recorder Expert? Answer questions, earn points and help others
