Question about Car Audio & Video
Sony XK-R100 car audio preamp troubles
My Sony preamp started acting funny awhile ago, would turn off by itself after I would turn it on. It didn't matter if I was listening to a cd or the radio, the result would be the same. It was installed in a BMW325 with external amp and eq....have replaced with old Blaupunkd which works just fine so I've eliminated my wiring job as a possible culprit. Have searched google and there seems to be a site called Euras (?) that will give out info but you need to be an organization...they list a possible problem with the faceplate and bad onoff button...can you enlighten me? Don't want to trash player cause I've had it since new/great shape, would like to fix if possible.
Thanks
Bruce
  • mrorvis Nov 06, 2007
    Will try your solution tommorrow and see what gives...just to see it power up would be a help!
    Bruce
    New Friend:
  • 53 Answers
Ok, so you ruled out the wiring....that would have been my first suggestion. Even now, it wouldn't hurt to wire it directly to your battery (red and yellow wire on +POS and black on -NEG). You can also try putting some tape on the face plate to make sure it's not loose, let it run for awhile with a little tape on it and the car off and sitting still and see if it still shuts off.
If you have already tried these things and are still having problems, I believe the culprit could be a dirty or blocked intake fan. Make sure there is not a mess of wires blocking the fan, causing it to overheat. I hope this is a help to you.
Posted on Nov 05, 2007
Have a 2006 Land Rover LR3 I just bought and sometimes it won't start and just hear a click when turn key but will eventually start(assume it's the starter) and today it came up with a transmission...
Get an obd tool and scan the fault codes will save u heaps of money u can pi k one up on ebay for under 30 dollars .my personal opinion is i think ur ecu is playing up or possibly ur bcm
Aug 28, 2017 | Land Rover Cars & Trucks
I have a 1997 gmc Yukon that won't start...I just
It might be the cam or crank shaft senser.They do act like that when going bad
Dec 14, 2011 | GMC Yukon Cars & Trucks
1992 Honda Accord sometimes won't start wait awhile and then starts
I have the same problem few days ago, and still didn't find any solution. Can any one please help?????5
Jul 28, 2011 | 1991 Honda Accord
Nikon D70 won't take pics, R19
Try to take the batteries off for awhile then try to reset it .
Jun 29, 2010 | Nikon D70s Digital Camera
We are having trouble with our jeep shifting..we have bled the clutch several times and it will work better for awhile but then will start acting up again..we just had the transmission forks replaced about...
You haver a small leak in the seal in the slave cylinder, I believe they sell and aftermarket kit to put ther slave cylinder on the outside, a better system. I believe they changed the design in the early 90's
Apr 20, 2010 | 1988 Jeep Wrangler
I need the installation manual (how to connect the wires) for Sony XK-R100 RDS car audio system.
this is simple the stereo has wires that are already labled and if you get a adapter for your car to connect it allso the wires are labled already so just connect them first remove you car stereo and just connect
Oct 26, 2009 | Car Audio & Video
Face gets stuck & can't use controls
i was told by manufacturer that is called a cable ribbon and cost about $30.00 thru dual electronics.
Sep 04, 2008 | Dual XD7600 CD Player
IQ 3600 Data card and frozen screen
I had the same problem awhile ago, the SD card was too large for the unit. I had lots of trouble and did everything under the sun. Then one day, just for the heck of it, I pulled the SD card out and whatdoyaknow?! It started up! I installed the same card again, and just like that it quite again. Sooooo I replaced the SD card with a smaller card, and have not had any trouble since, after I got my original problem fixed. Try this solution and see how it acts for you. Jeff.
Jul 15, 2008 | Garmin iQue 3600 GPS Receiver
Trouble with car stereo
Hoang00, to change the time on JVC's i believe you hold down "source" for a while and a menu pops up.
SSwaim, sounds like a grounding problem. Check the connections behind the dash, possibly a couple came loose. I would say possibly a bad car battery but the headlights thing points to a grounding issue to me.
May 10, 2008 | JVC KD-G310 CD Player
Car Audio & Video Logo
277 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
