Warranty on a carrier 38 ckc060 - Heating & Cooling
Is it correct that Carrier had 5 year waranty back in 2007?
Try looking up your own warranty. Check carrier warranty on your model and serial number located on data plate on machine
Dec 10, 2016 | Carrier Heating & Cooling
Model 38 AQS012. What is capacity?
The 12 in the model number would make it a 1 ton system.
Apr 03, 2016 | Carrier Heating & Cooling
How long is the warranty for the carrier outdoor compressor unit - model CAR-AC-42/38KCV?
Carrier gives 5 years warranty period on the compressor, and one year on all other parts.
Aug 27, 2014 | Heating & Cooling
now your only option is to unlock your phone a use it with different carrier.
Nov 21, 2013 | Cell Phones
What is the warranty for a Carrier Model # 38CKC036350 Air Conditioner unti ?
Most warranty's are for 5 years parts only unless you opted for an extended labor warranty.
Jul 14, 2011 | Carrier 38CKC036 Air Conditioner
Air conditioner model # 38ckc 42..350 not working, keeps tripping the breakers, had electrician check out and stated it was the fan or the compressor, i bought the house in 2009, was built in 2005, what do...
Hi, if that is a 2005 carrier condenser, it may still have a warranty on the compressor. You need to copy down model and serial #, call the local Carrier rep and ask. That is your right to do so. The fan is probably not in warranty, but it is definitely worth replacing if it is bad. I sold carrier for 15 years, and sold many with 10 year parts warranty. First thing you need to do if you haven't done so is check on your warranty! If you can explain what it is doing a little more in detail I could probably tell you exactly what is wrong. Hope this helps.
Jun 23, 2011 | Carrier 38CKC042 Air Conditioner
Looking for a parts list/owners manual for an old carrier AC unit. Model #38 REO 36 300. Any idea?
Follow this link to the search page for the Unit need need literature on. If you want to change models (i.e. from the 38BR to the 38RE, both of which you list in your question), just enter the 1st 3-4 characters in the search box. this link is for the 38RE. Good luck!
http://www.commercial.carrier.com/commercial/hvac/technical_literature/1,3063,CLI1_CNT1_DIV12_ETI9039_MID4442_QRYY,00.html
May 27, 2010 | Carrier 38BRC036 Air Conditioner
Carrier Condensor Control Board Status Light
See page 33 here - http://www.docs.hvacpartners.com/idc/groups/public/documents/techlit/38-10sm.pdf
It lists a problem with freon level, mechanical issue with compressor or dirty coils. I would eleminate the easier items first by cleaning both coils, and then have someone get some test gages on the unit too make sure the compressor is ok.
May 17, 2010 | Carrier 38BRC036 Air Conditioner
Fan not running properly
Probably need a new fan motor, sounds like it is overheating. This can happen if the bearings are too tight. Not something you can fix just replace. Need an amp meter to check the amp draw on the motor
Jun 10, 2008 | Carrier 38BRC048 Air Conditioner
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
