Question about Maytag Washing Machines
How do you reset MayTag Washing machine error F26
  • 16 Answers
SOURCE: F26 Error - Door Switch?
when you hear clicked can you open the door?its should be locked...
Posted on Oct 13, 2008
TheMobilian
  • 8220 Answers
SOURCE: I am getting an F26 error when I am trying to
F26 Door switch error
Posted on Sep 14, 2011
emissionwiz
  • 79865 Answers
SOURCE: my maytag commercial washer display a code F26
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and the condition above has been checked, call for service.
Posted on Oct 23, 2012
caroldon
  • 17130 Answers
SOURCE: Whirlpool 3LCHW9100WQ Semi-Professional 9kg Washing Machine
Possible fault with the door switch or the control panel but you can try to open and close the door few times to reset after removing power.
click this link: error code F26
Posted on Oct 03, 2013
  • 790 Answers
SOURCE: F26 washing machine Siemens s1272
The F26 error code on the Duet washer is a door switch error.
Disconnect the unit for 10 minutes and plug back in to power.
Check the display for any kind of power indication.
If you have any leds of power indication, try adjusting the door switch.
Posted on May 07, 2014
What fauit code f26 mean
For a more thorough explanation, check out member Yadayada's explanation here -
My maytag commercial washer display code F26
Sep 20, 2017 | Washing Machines
Codes f26 and then f27 for maytag model MFH 0710
  3. Re-select the cycle and press Start. unsure of f27
Dec 23, 2016 | Maytag Washing Machines
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
What does f26 mean for siemens washing machine
F26 come up This error code indicates that the door needs to be opened and closed.The F26 code may appear the first time you try to use the washer. Open and ...
Jan 03, 2016 | Siemens Washing Machines
May 07, 2014 | Washing Machines
Oct 03, 2013 | Washing Machines
My maytag commercial washer display a code F26
Oct 23, 2012 | Washing Machines
Fault code f26
Jul 30, 2011 | Maytag Washing Machines
Oct 12, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
15 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
