Question about liftmaster Garage Door 1/2 Hp
How do I cut a glass piece that is going to fit the size of the garage door window? When it is cut, how do I get it to stick in the slot? Is this a simple fix? bryanflake1984|
I need replacement glass for my musical clock it fell,off the wall siring building construction how do I get the glass replaced.
flat glass --go to a local glass supplier , ( window, door manufacturer) and have a piece cut to size
Apr 04, 2017 | Home
I bought the Living Accents Corona Wicker Bar set the glass top shattered I dont know why but it is a million pieces, can I order another one through living accents
go on line and see if one is available
the glass would have been toughened glass so that there are no sharps to cause injury if broken
glass supply shops ( windows and door manufacturers ) can supply glass cut to size and then toughened
This will save on freight costs to you as you can pick up the new top locally in your vehicle
Apr 30, 2015 | Computers & Internet
How to put solar tint at home
Do you mean use solar tint at home on a window? If so here is how its done. Go to Home Depot or Lowes, where ever you can find large rools of film. I got mine at Home Depot, get correct size to fit window or glass door you want to cover. It comes on different shades from real dark to almost clear. Clean glass an follow instructions about which cleaners not to use. Cut film over size an lay on glass, use squeeie to press out bubbles. Its not as hard as you think but it does take practice to do correctly. I had some bubbles but not real large ones so I left it alone. Door glass came out fine windows not as good. Hope this helps.
Jan 29, 2015 | Cars & Trucks
Windows fixya
Go to your local Lowe's store with the size measurements of the window. they will cut you the size you need. Probably better to replace it with a plastic window. it's as clear as glass and will not shatter.
May 08, 2014 | Home
Simpson fabulous 400 oven
best to measure the the hole size and then go and see a glazier for him to cut you a new heat treated piece.
Jan 18, 2014 | Jenn-Air Cooktops
Iv brooken the white glass on my grill door can it be replaced by a glass provider or will i need to purchase a part from a apliance store.what is my cheapest option?
Yes, you can put a piece of tempered glass from a glass dealer in place of the original piece. The advantage is that you can use a heavier piece, if it'll fit. It might cost more to go that route, because it's a custom piece- they have to cut the glass before tempering it. Just call a couple of glass people and a couple of appliance people and go whichever route you find you prefer.
lp
Jan 11, 2011 | Magic Chef 9122 Gas Single Oven
How do you replace the glass in the driver side mirro?
Try Pep Boys or Autozone for a replacement mirror glass. They come in many different sizes cut to fit many different mirrors. Get one that is the same size as your old one, peal off the back sticky tape, and stick it onto the broken mirror glass if it's still there. No need to replace the entire mirror.
May 17, 2010 | 2005 Chevrolet TrailBlazer
Reassembling thermador Thermatronic II lower oven door cmt21
you can use some of the glass of the old oven just need the size of the glass if you order from the manufacturing it very exp
Jan 03, 2010 | Thermador SMW272 Electric Double Oven
Broke the glass front to my Dacor CPO230B wall oven. the manufacturer no longer makes the part. What would the solution be to this problem.
If you dig deep enough on Google, you'll find someone who has the part. As with all manufacturers, none of them make the entire product. Bic makes pens for "off brands", Staples products come from a myriad of manufacturers, Kirkland, the house brand for Costco, all come from various sources. Hopefully, the part that's ordered will fit. We've also located the entire door. So just in case the front glass is not available, the door is, and that's an expensive alternative. I've also considered going to a glass company to have a piece of tempered black glass cut to size. My entire dilemma stemmed from changing the interior bulb in the bottom oven, when putting the door back on, it slipped in my hands and the rest is now history.
Dec 01, 2009 | Ovens
Tinting the rear door glass geting to the edges
usually make cut out template of window then cut tint to template then fit and work into tight spots while fitting.New sharp razor blades and a steady hand.
May 31, 2009 | 2005 Ford Focus
liftmaster Garage Door 1/2 Hp Logo
35 people viewed this question
Top liftmaster Building Materials Experts
David Payne
David Payne
Mike
Are you a liftmaster Building Material Expert? Answer questions, earn points and help others
