Question about Sharp Televison & Video
Sharp LC26SH12U Please Wait - Sharp Televison & Video
Need Sharp LC26SH12U manuel
Try Googling (sharp)(LC26SH12U)(manual) without parens.
Sep 30, 2017 | Sharp Televison & Video
When i power up the tv , it say please wait . that is all
Sounds like a firmware corruption. It might have to be updated. Contact the authorized service centre for Sharp. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 16, 2014 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
From 1 to 10 ten been the best how good are this tv 55PP9363H/17 1 TOSHIBA 6211M15 1 SONY KFSOWE620 1 MAXENT MX26X3 1 SAMSUNG LN32BS40P8D 1 MAXENT MX26X3 1 MAXENT MX42XM11 1 SONY KDLS2VLISO...
The Samsung LN40B540P8F I would rate a 9. Only God is 10.
All the DLP sets, you can throw out
All the Older Projection sets you can throw out
I would take the rest for scrap parts.
I hope this is helpful.
Dec 18, 2010 | Philips Magnavox 51MP392H Rear Projection...
My sharp tv displays 'please wait' but no picture. and my source input display menu will not come up. model sharp acquos 32 inch.
You will have to replace DIGITAL PCB ASSEMBLY to correct the problem, I assume, that your TV is lc32d40u?
Sep 26, 2009 | Sharp AQUOS LC-45D40U 45 in. LCD...
Sharp OZ-630
Do an ALL RESET. The only way i know of to do it is to hold the ON and Reset at the same time. Then select yes at the promt. Then wait 2 mins and take out batteries. Reinsert and turn on. it will re-format. This is the only way i know of how to ressurect it, but it deletes ALL you data.
Thanks
Aug 18, 2008 | Sharp Wizard OZ-630
When i turn my tv on i have a " please wait " message on the screen.
see the link below but first make sure here is no dvd in the drive
because a bad dvd can cause this problem
working on sharp lcd tv dvd combo LC 26DV20UPLEASE WAIT
Jan 02, 2018 | Sharp LC26DV20U 26 in. LCD HDTV/DVD Combo
LC-32d40U Sharp Aquos Screen shows "please wait" controls do not respond
Hi.
Im not familiar with your TV set as it is made for USA but here in the UK some sharp models suffer with similar problem & this is the remedy.
As I said I cant gtee it will sort your problem but give it A try.
  1. Unplug the AC power cord of TV set to force power off.
  2. While holding down the “VOL (–)” and “INPUT” keys on the set at once, plug in the AC power cord to turn on the set. This should hopefully clear the problem.
  3. http://dysonmanuals.llc.nu/
Apr 03, 2008 | Televison & Video
Sharp aquos lc26sh12u no menu screen appears
as you have a good screen, I would check ebay for the display controllers as there are so many available after shipment drops and kids with hard toys.
what you have been troubleshooting so far is analog , now its likely a digital issue , all you can look for is the the cpu is running,
is it getting the 5v + and the say 20 or so volts.
Feb 04, 2008 | Televison & Video
LC32SH20U Please wait screen
I have had many problems with these unit with internal cables being loose or not seated properly. This is most likely the case, or the unit has a bad main. BD. If is new you can probably exchange the unit where you bought it, or contact Sharp and they will set you up with an auth. service center to correct the problem.
Jan 13, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
20 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
