I am printing from a Zebra TLP 2844-Z, using Polypro 3000t labels (thermal transfer) and a wax/resin ribbon. The labels are used for employee badges. Once printed and applied, the ink is smearing almost immediately. I called Zebra and they said these two products are compatible and should be working. I have not heard back from Zebra since. Anyone have any suggestions?
This is a compatible ribbon/label combination as Zebra says. The only thing you can try is to turn up the darkness setting. The 5586 ribbon you are using requires a fairly high darkness setting ~ maybe around 25. If this still doesn't work then the best solution would be to use a Zebra card printer that prints right on the plastic card. These are made for exactly what you are trying to do. If you don't want to buy the printer then we can print them for you when you need them. I can give you my email if you want us to help.
Was this helpful?
Yes
No
Popular Solutions for Zebra TLP 2844-Z Thermal Label
printer keeps stopping halfway though run of labels. Red light comes on and when pressed goes green...
(More)
printer keeps stopping halfway though run of labels. Red light comes on and when pressed goes green reprints last label then a few more then stops again.
Hi, I am having Zebra TLP 2844 barcode printer.I have installed the printer in my machine. I have...
(More)
Hi, I am having Zebra TLP 2844 barcode printer.I have installed the printer in my machine. I have tried to take barcode labels.From application, for each and every label i need to generate the label in PDF and the i need to take print. I need to take print directly from the application. Kindly assistance me. Regards, Ramesh ramesh.perumal@csscorp.com
i have installed a zebra printer drivers correctly.. but once i send a test page its starts to blink...
(More)
i have installed a zebra printer drivers correctly.. but once i send a test page its starts to blink red light am currently running windows xpsp2
My ZPL2 command is: ^FO230,250^AF^FD&wz_descr&^FS where wz_descr is a variable with...
(More)
My ZPL2 command is: ^FO230,250^AF^FD&wz_descr&^FS where wz_descr is a variable with value of 'RUBBER POLYCHLOROPRENE POLYMER' what gets printed on the label is 'RUBBER POLYCHLOROPRENE PO' Why does it print 6 spaces between the word RUBBER and the next word POLYCHLOROPRENE
