Home | Denon | AVR-4800 5.1 Channels Receiver | AVR-487 won't power up,...
Denon AVR-4800 5.1 Channels Receiver
Problem for Denon AVR-4800 5.1 Channels Receiver
AVR-487 won't power up, "standby" light flashes
By auntieginnie on Jun 23, 2009
Checked connections, everything fine; what should I try next?
Solution #1
posted on Jun 23, 2009
Not Rated)
smarthome2
Rank: Guru
Rating: 88%, 333 votes
Pull the top on the receiver; it's usually 7 or 8 small phillips screws. Once you pull the top, look where the AC cord enters the unit. (make sure it's unplugged) and there should be one or two fuses. If they are coated fuses, you need a meter to tell you if they are good or bad. Put a meter on resistance/tone and your probes on either side of the fuse, if you hear a tone, the fuse is good, if you don't touch the two probes together to test your tone and check again, if still no tone, you have a bad fuse. You should be able to get a replacement at Radio Shack or any Electronics Parts store. If your fuses are good, you've got a service issue and it needs to go out for repair. Hope this helps
Was this helpful?
Yes
No
Popular Solutions for Denon AVR-4800 5.1 Channels
Questions and Unsolved Problems for Denon AVR-4800 5.1 Channels
Do you recommend Denon AVR-4800 5.1 Channels Receiver?
Answer
Answer
I have Denon AVR 4500, unit works fine but I change function knob it makes loud poping or thump in... (More)
Answer
the unit was fine yesterday morning...now no sound out on any level or function..ie... (More)
Answer
I don't get any sound output from my Denon 4800 receiver. It intermittently comes but have been... (More)
Answer
Hi, I have a Denon AVR-4800 to which I have connected a pair of Sony ES series CD decks. I'm using... (More)
Answer
Occasionally, it switches rapidly from "HP-on" to "HP-off" but still no sound... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Denon AVR-4800 5.1 Channels...:
Top Receiver Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Receiver Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
