Question about Car Audio & Video
Keltic TWT SR630-200 power amplifier - Car Audio & Video
I'm trying to program a magnavox converter box with a universal remote model UR5U-8780L-TWT. I need the code for this please.
Hi Jerry, This is from the link below.........
The Time Warner Cable CLIKR-5 is designed to offer complete control for all digital, HD and DVR set-top boxes. The UR5U-8780L is factory programmed to operate Scientific Atlanta/Cisco and Samsung set-top boxes while the UR5U-8790L is factory programmed for Motorola set-top boxes.
Time Warner Cable CLIKR 5 Universal Remote Control
May 01, 2016 | Magnavox Televison & Video
I need a cord for it, can't find the one I had?
google .commake model,and parts .you might find one
Mar 16, 2015 | Toastess Cordless Warming Tray Twt-30
Toastess warming tray Model # TWT-40 power cord replacement
Contact a local small appliance repair shop in your area and they should be able to fix you up with new cord. This site doesn't sell parts just advise on repair problems.
Dec 26, 2012 | Toastess TWT-40 Classic Cordless Warming...
Ice builds up in between the doors on the metal jam and all around the doors
It sounds like there is a problem with the air flow of the unit. Either the fan may not be working or if it is, something may be blocking the airflow of the fan. Its usually a good idea not to store any product directly in front of the evaporator fan inside of unit.
Nov 29, 2011 | True TWT-60 Stainless Steel Commercial...
Our true freezer won't shut off. we purchased a new cold control and it didn't help either. Is there a schematic or instructions for installation ?
Do you have a GE Thermostat or a Danfoss. It is important because the Danfoss uses a Temperature Control Relay if this is the case the relay contacts maybe stuck closed.
Nov 20, 2010 | True 12 cu. ft. Commercial Freezer TWT-48F
Does the munion heater wire into the thermostat or in back of unit??
the munion heater needs to be hot all the time to prevent sweating so it should go to main power terminal strip if it has one ,or just to the main constant power box
Sep 30, 2010 | True 12 cu. ft. Commercial Freezer TWT-48F
No evaperater fan run,compressor running,coil is frosting but no voltage to inside fan.
Look to the fan delay/defrost terminator that is located inside to the evap. It is usually attached to the evap coil. check there first.
Aug 25, 2010 | True 206 cu. ft. Freezer TWT-67F
Toastess warming tray, not geting hot
time for new one, they are made to brake now days:(
Oct 25, 2009 | Toastess TWT-40 Classic Cordless Warming...
Water in cabinet of new TWT-60
The drain hole is at the bottom of the evaporater coils probably behind a cover inside. Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 30, 2009 | True TWT-60 Stainless Steel Commercial...
GE XL1800 will not heat
sounds like the twt is bad (the traveling wave tube) that is quite expensive. Unfortunately your solution is probably to buy a new one.
Jan 22, 2009 | GE XL1800 1100 Watts Microwave Oven
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
