Question about Kodak Carousel 4400 Slide Projector
Where can I purchase a FHS bulb for my kodak projector?
Bulb needs to be replaced
    President:
  • Kodak Master
  • 412 Answers
You can find FHS bulbs online (Amazon, Ebay or Bulbman are great places to start). If you have a "Batteries+ Bulbs" store in your area, they usually have them in stock. Good Luck !!
Posted on Sep 24, 2014
  • 33 Answers
SOURCE: How do you replace the bulb on a Kodak Carousel 600?
This post is a few months old but in case this come sup again: Assuming you have a 4000 series projector, withdraw the lamp housing after unplugging the projector. THe kind of clasp will vary a bit but it's more or less in the centre of the lamp housing which is located at the rear, right of the projector. The housing will stop just before you pull it out entirely. If you must, pull it gently but firmly some more, but it's not theoretically required. If you pull it all the way out you'll need to be careful re-inserting it so check out how it slides in and out before removing the whole lamp module.
Over the top of the lamp you will see a metal , bent "spring" that pushes down on the rear of the bulb.The spring terminates over and beside the bulb, hooked into the lamp housing. Press down on it a bit and outward to unhook it. Now don't yank it up but gently and firmly pull it so that the back of the lamp rises with it. You may not see it at this point but there is a corresponding bit of metal spring under the bulb, pushing up on the back of the bulb (where the electrical contacts are). In theory this will bring the bulb up enough to clear the socket and you should see the two electrical contacts (prongs) of the bulb. In practice, sometimes the bulbs stick inside the socket. Replacements sockets are hard to get and can be expensive so if it sticks, easy off a bit on the upward pressure, gently press down a bit on the (cooled) bulb a the back, and try it again.
You may or may not need to put a small finger under the bulb to ease it out of the holder. These weren't the easiest to operate lamp holders!
When inserting a new bulb, just reverse the above, You may want to gently press (too hard may crack the socket!) on the back of the new bulb as it goes into the socket. You want that bulb in there firmly so it doesn't arc electricity, which will corrode the lamp sockets and the bulb's prongs. Be careful to keep the lamp as even (level) as possible when reinserting it so the bulb doesn't crack. On the off chance it does, most times it will still operate satisfactorily as long as the prongs are firlmy in the socket.
Posted on Aug 17, 2009
SOURCE: replacement bulb for Kodak Carousel 4400 Projector
Search for FHS lamp on Amazon or ebay.
Posted on Feb 03, 2010
  • 412 Answers
SOURCE: Projector light does not shine. (Power is on, bulb
I will assume from your description that the projector is powered on and you can look in the rear vents and see the lamp illuminated, yet the light does not shine on the screen.
The Ektapro 9020 and most of the Ektagraphic line of projectors are equipped with a "dark shutter". What that does is keep the screen dark unless a slide drops into the gate. At that time the sensing circuits trigger and open the shutter, allowing light through the slide & onto the screen.
Posted on Nov 04, 2010
  • 412 Answers
SOURCE: Kodak 410 Projector/Viewer - no lite through projector or viewer
These projectors were designed & made by Telex for Kodak.
If the screen stays black when you push a slide down into the "gate" (in either viewer or projector mode), then the trip mechanism that opens the shutters when a slide is detected has a problem. It could be an adjustment, a broken or out of position spring or hardened lubrication.
There is no good way to proceed unless you are trained in the service of these projectors. Contact a factory-trained repair dealer. Happy New Year!
Posted on Dec 30, 2010
  • 412 Answers
SOURCE: Light won't come on, replaced old light bulb.
First, check to see if the lamp lights at all (spill light coming out of the projector near the fan). If it does, then the problem could be just the "dark shutter" not opening. If the lamp does not light, it could be a couple of things: it could be the lamp thermal fuse has opened or it could be a bad lamp socket.
Sounds like you need to seek out a factory-trained repair dealer for this one, to narrow down the possibilities!
Posted on Jan 04, 2011
I have a Kodak Ektagraphic with no model listed on it at all. How can I find a replacement bulb, all I can find look wrong.
Supplied with 82V, 300W EXR lamp Projection Lamps Quartz-halogen 82 V projection lamps- Here is service manual link http://resources.kodak.com/support/pdf/en/manuals/slideProj/manual/ektagraphic_sm.pdf Several different Models all say EXR 300W As CORRECT Bulb : EXR, 300 W (35-hour lamp life at full lamp/medium-brightness) Sampling of other lamps: EXY (200 hours/less brightness) EXW (15 hours/maximum brightness) FHS (70 hours/medium brightness) Use combinations of lamp brightness, plus half- and full-lamp settings to approximate image brightness in multi-projector presentations. Lamp Tips • Projector operation on line voltages above 125 volts greatly reduces the lamp life. • Unplug the projector before changing the lamp. • Allow for unrestricted flow of air to the exhaust vent to prolong lamp life. • Gently wipe off any fingerprints with a soft cloth moistened with rubbing alcohol.
Jun 27, 2016 | Kodak ATS Ektagraphic Slide Projector
Why won't the bulb work on the kodak carousel 750H
Those bulbs do burn out eventually, and need to be replaced.
Oct 26, 2015 | Kodak CAROUSEL 750HAR ELH Light Bulb Lamp...
Where can I purchase a bulb for my Kodak Carousel 4400 Projector
FHS Bulbs can be found online (Amazon, Ebay, Bulbman etc) or if you have a "Batteries + Bulbs" outlet in your community, you can find it there. Good Luck !! Jim
May 13, 2014 | Kodak Carousel 5600 Slide Projector
Need a replacement dek lamp with a asa code
DEK Lamps for Kodak Slide Projectors are almost always in stock at "Batteries PLUS Bulbs" retail outlets. If you don't have one of these stores in your area, try: www.bulbman.com
Jan 28, 2013 | Kodak Carousel 600 Slide Projector
It hasnot been used in 12 years. it was working for afew days then it wasnt. the power was on but the big light in the back is out.is it the bulb or something else? Is it worth fixing? can I get an...
Chances are that if the cooling fan is running, then you burned out the lamp. Contact Bulbman.com or Bulbs.com for a quote on the lamp. If your projector is a Carousel 4400, then you will need to replace the lamp with an ANSI Code "FHS" lamp. If that's all that is wrong with the projector the lamp will cost you about $40 (best guess).
Dec 08, 2010 | Kodak Carousel 4400 Slide Projector
Need to purchase a new bulb assembly. where can I do that
Bulbs for Kodak (and many other brands) projectors can be ordered on line at: www.bulbman.com I hope this helps!!
Oct 25, 2010 | Kodak Carousel 4400 Slide Projector
Whats another of makin a kodak 4200 work without a 300w 82v bulb
Contact www.bulbman.com and ask for an ANSI code EXR, FHS or ENH lamp. Any of the 3 should work in your projector.
Nov 11, 2009 | Kodak Open Box BC-4601 Slide Projector
Does bulb need replacement?
I had same problem.
You have to load the slides so there is something to be projected.
Dec 15, 2008 | Kodak Ektagraphic III ATS Slide Projector
New lamp
http://slideprojector.kodak.com/plugins/acrobat/faqs_lamps.pdf
This link tells you the lamp type you can use. EXY, EXR or FHS. http://www.bulb-source.com has the FHS for around $10.00. Seems like a good price for the lamp. Other suppliers range from $8 to $25.
Dec 31, 2007 | Kodak 4200 Slide Projector
Kodak Carousel 4400 Slide Projector Logo
78 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
