Question about GE JVM1790 1000 Watts Convection / Microwave Oven
Power receptacle ok. All functions not working.Dead-internal fuse? jvm1790wk01
Sounds like the fuse. I recently replaced it. Remove the grill (look on top of your microwave for two screws) and you'll see the fuse to the right side of the microwave. You can get the fuse at Home Depot.
Posted on Dec 17, 2010
Microwave ovens does not work, ooven is plugged up and electrical power is check at the receptacle. No power .
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Mar 22, 2011 | Amana ALD10D Microwave Oven
No power to oven. Receptacle it is plugged into shows power
Hope this helps.
Feb 27, 2011 | Hotpoint RVM1635 Microwave Oven
I have model RCS10DA two and a half years old and gets considerable use. Stopped working. Has power at receptacle. Are there any internal fuses. what should I check first.
Hope this helps.
Feb 16, 2011 | Amana Microwave Ovens
Problem with the Bosch HME9760 / HME9750 800 Watts Microwave Oven Small pop when i went to open door, and now looks dead. 13amp main fuse all ok, so i assume its an internal thermal fuse or something...
Hope this helps.
Jan 06, 2011 | Bosch HME9760 Microwave Oven
No lights - no power - DEAD! Worked fine an hour earlier now ... nothing. Check fuse in mains box - all OK - tried it plugged into another outlet... nothing.
Your unit is dead, mains are good, tried in other receptacles, still no power. You have a bad fuse inside the unit. Unplug. Remove the cover. Generally this requires removing all the screws on the back perimeter and lifting the cover up. Sometimes they stick due to old grease, etc. Somewhere in the area of where the power cord comes in or near the transformer there should be a small fuse in a holder. It is not a glass fuse and should be replaced with the same kind (ceramic) and value. This is important for future protection. You can get the fuse at www.mcmelectronics.com . Get a box of five for future problems. If this was the only problem your microwave should work. If it blows the new fuse you could have a shorted power transformer, bad high voltage diode, or a bad magnatron in that order. There could also be a short in the board with the display but that would be unusual. Let me know if you need anymore helpl
hardrocko
Thanks for using FixYa
Feb 26, 2010 | GE Microwave Ovens
Dead Microwave
Check your plug and change the fuse there also.
You might need to rechange the 20 amp 250v fuse behind the control panel again due to the recent spark.
If none of this works then i'm afraid a certified technician needs to check the power packs and boards
May 22, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave doesn't have any power, ** Display, **thing...
Nice touch with the diagram. Thanks!
The neutral line passes through the cavity thermostat, which may be open. In the schematic, it's left of the center bottom.
In the pictorial diagram, it's located just below where you added the note "120V OK". Its top half is cut off in the picture and it has blue and white wires attached.
Also, the low voltage (LV) transformer shows fuses in its primary and secondary, although one or both may be internal and inaccessible.
It may also be a problem on the control board, which we repair nationwide for only $39.95 postpaid. Feel free to reply back if you need further assistance.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 09, 2008 | Microwave Ovens
GE JVM1790 1000 Watts Convection / Microwave Oven Logo
210 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
