Question about Blenders
Krups blender/food processor model type 243, I can't attach the mini food processor to the main motor that works the blender.
  • 79 Answers
SOURCE: Krups 243 blender clutch wheel
These little jewels are threaded onto the motor shaft so they tighten up when in operation. To remove, you will have to immobilize the motor shaft. See if you can insert an icepick or screwdriver into the blades of the motor fan on the bottom. Then using a punch and hammer, gently tap the clutch disk in the direction opposite from its normal rotation.
BE CAREFUL not to use so much force that you break either the clutch disk or the motor fan blade.
Posted on Mar 15, 2008
SOURCE: Krups blender drive gear
Ed,
The problem I had was removing the grey rubber drive. The solution is that it screws off not pops off. The trick is to use narrow needle nose pliers to grab the post that attaches to the motor and turn the rubber drive counter clockwise. Removing the motor becomes easy. Pull out the 4 rubber feet under the base and the screws will be exposed. However my situation was the grey drive gear was stripped and would bottom out. My solution was to use a same size lock washer as the washer between the post and the drive. So far so good! If it fails I will need to buy another grey drive. Myron
Posted on Feb 01, 2009
SOURCE: parts for cuisinart blender trio model bc-56
GO TO:
http://www.smallappliance.com/department.asp?cur=USD&sid=18954&mid=8&shopBy=Brand&cam=cuisinart_parts&gclid=CJTy7Om5qZoCFRk_awod9Gjw1Q
FOR CREDITS MAIL BACK TO: NEFIUINC@MSN.COM
Posted on May 07, 2009
SOURCE: need to order parts for food processor for stainless steel blende
I neede a new blade unit for my phillips smoothie maker, I just googeld the model number + spare part and was redirected to the websites! Eventually you fine it!!
Posted on Sep 23, 2009
  • 78 Answers
SOURCE: how can I obtain a user manual for blender-foodprocessor
Try contacting them for parts. This is a relatively simple problem that you have solved yourself! So, now it seems the unit is making a noise that the mfg should want to remedy.
Posted on Nov 09, 2009
How do I replace the knife unit in a krups type 243 blender?
Take the blade assembly out of the jug, hold the blades with a towel and turn the driving clutch on the other end. Whichever way the motor turns those blades when operating, you need to turn the drive the opposite way to undo it. If the nut is seized up and wrecks the drive the parts list shows all parts as being available EXCEPT the white bearing housing AND the complete assembled blade and housing.
May 16, 2014 | Blenders
My ninja base single serve button is always on, even with nothing attached and it can run with no attachment. I cannot use anything but the single serve.
read your owner manual section troubleshooting. However you must test the control board fro defective, but test the main switch for defective use the multimeter for continuity and replace it
God bless you
Nov 04, 2013 | Euro-Pro Ninja Kitchen System 1200...
Krups 239 blender drive gear.
Like you, I am all for repairing and keeping the world free of blenders that only need one part replaced. The rubber coupling was easily ordered online, the challenge I later found was to remove it without losing my sanity. After messing up the side grill of the blender pretty good, I realized there is an opening on the motor casing that allows access to a "gear" that is firmly attached to the axle where our little friend will hopefully screw on and restore the contraption to a working state. In order for you to see (which I must warn you, it's not much of a view) through the grill you will need a flashlight or book light. Towards the top of the aforementioned gear (not the rubber part) there is a groove in which a flat screwdriver can easily fit immobilizing the axle and allowing you to easily unscrew it. Oh, but wait, I forgot this is the faulty part and it will spin without the slightest torque on the axle thus never loosening or getting it unscrewed. My solution to this problem was to surgically remove as much rubber as possible to allow me to attach my vise grip to the nut and finally put this thing out of its misery. Using the same procedure of inserting the screwdriver to immobilize the axle I was able to screw the new part and voila the blender is fixed!!!!
Apr 08, 2009 | Krups 239 Power X Plus Work Top Blender
I have a krups 574 blender. The male part of the
I carved off the rubber with a knife; inserted a flathead screwdriver throught the slot in the bottom to hold the gear in place; using pliers I unscrewed (COUNTERCLOCKWISE) the rubber gear.
Mar 28, 2009 | Krups 574 Power Xtreme VI Premium Work Top...
Need to order parts for food processor for stainless steel blende
Feb 20, 2009 | Ultrex 834-334 Die Cast Work Top Blender
Ed,
Nov 04, 2008 | Krups 239 Power X Plus Work Top Blender
Krups Type Blender 577
Mine did the same thing. I am ordering a new one from America for around $5.
http://www.abtecparts.com/index.htm
I am in Australia and they deliver worldwide.
Caz
Jun 12, 2008 | Krups 572 Power Xtreme VI Work Top Blender
Need new product
I have a brand new, never used (parts still in plastic, but no box) ULTREX Kitchen Preparation Center model 14008- Blender-Food Processor-Fruit Juicer that you could buy.
Nov 06, 2007 | Blenders
Blenders Logo
89 people viewed this question
Top Blenders Experts
eyecam
Are you a Blender Expert? Answer questions, earn points and help others
