Question about FJC 53500: Power Inverter- 5000 watt
I need a manual for FJC 53500: Power Inverter- 5000 watt. Installation instructions. something
I'm trying to run a 750 watt whirlpool compact microwave with a 2500 watt Cobra inverter. The microwave runs normally, but it won't heat. If I plug it in at my house it heats fine. I'm stumped. I load...
I assume your not using a pure sine wave inverter. A lot of electronic devices won't work on a lower cost inverter (modified sine wave) that has a square sine wave, either invest in a true sine wave inverter or don't run sensitive electronic equipment, I'm somewhat surprised you didn't damage the circuit board in the microwave...Below is a link of a inverter that would work if you want to spend the money for one.
2500W 5000 Watt Power Inverter Pure Sine Wave 12V dc 110V 120V ac LCD...
Feb 05, 2018 | Electronics - Others
11Kw pioneer VF-5000 inverter
please send me the user manual for vf-5000(11Kw)?
Jun 23, 2014 | Black & Decker Vector Cable Kit for 1200...
How fix a inverter
Too vague, but look for bulging capacitors and replace them as needed.
JOAT
May 09, 2014 | AIMS 5000 Watt 12 Volt DC Power Inverter...
How do I remove olp message
Its an inverter DC to AC---what since I do not understand the described problem is the unit doing or not doing?
Dec 04, 2012 | Cobra Cpi 2575 5000-watt, 12-volt Dc To...
Can a 2500 watt inverter run a 5000 btu air condition?
5000 btu consumes about 500 - 700 W in cooling and obviously it should be running from 2500 W inverter.
It is obviously, but the conditioner has a compressor which needs some more (about 2, 3 times the rated) starting power, which is in it's bigger part reactive power which is not produced by the inverter and depends on the output condensers of the inverter.
It should be tested, and if the start is difficult some more condensers may be added.
Jul 17, 2010 | Cobra 2500w Power Inverter
Hi. I have a 5000 watt inverter in my truck. The alternator in the truck is a 150? amp alternator. I also have 3 deep cycle batteries (about 150 ah each) to run the inverter. Is this overkill for my...
A 5000 wat inverter is very large. Your alternator could not supply it alone without the batteries. The moderate to low usage is the key. Calculate the wattage of the load you want to connect. Depending on what else you're doing with the truck, lights, heater, air condition etc, you could probably draw somewhere between 1,0000-1500 watts on that alternator. Rember even if your alternator is rated for 150amps (large alt) it is not a 100% duty cycle. Alternators are usually around 50% duty cycle, so figure about 75amps continuous, or around 900 watts. That's considerably less than your 5,000 watt inverter. Buy a generator.
Jul 01, 2010 | Inverter Aims Pure Sine Wave Power...
I just bought a RoadPro 2500 and i want to buy like a dorm fridge how many watts or volts size would work??
If you are referring to the RoadPro RPPI-250
  • 2000 Watts Continuous Power
  • 2500 Watts Power Output @ 10 Minutes
  • 5000 Watts Peak Power Output.
  • A small fridge will use about 500 -700 watts, with startup wattage at around 2000watts.
  • So, a dorm fridge will work fine.
  • the RoadPro converts DC to AC voltage, so a regular 120 volt dorm fridge will work.
  • Jul 05, 2009 | RoadPro RPPI-2500W Inverter
    Aims 5000 watt inverter troubleshooting
    The amp meter on this unit measures the battery current. So if you have an 8 amp load at 120 vac you will draw more than 80 amps at 12 volts and 40 amps at 24 volts. While this may not explain the 180 amps that you are seeing -- it's possible that the dryer is drawing more than 8 amps.
    Dec 10, 2008 | Inverter Aims Pure Sine Wave Power...
    FJC 53500: Power Inverter- 5000 watt Logo
    26 people viewed this question
    Top FJC Electronics - Others Experts
    Are you a FJC Electronics - Other Expert? Answer questions, earn points and help others
