Question about Seville Classics MSC10166 Tower Fan
Works for 10 minutes then shuts off.
Works for about 10 minutes then shuts off
I have an older Guardian forced air heater. I can cross the red/white wires and it will run for 10 minutes then shut off and not start again. Is there a safety cut off in the furnace?
make sure you filter is clean and your blower works, a blocked filter will shut off system on high limit, and it will reset when furnace cools off
Dec 28, 2015 | Heating & Cooling
My ps4 is shutting down automatically after playing for 5/10 minutes. What to do?
it looks like it is heating up. heat fan replacement can solve the problem.
Mar 01, 2015 | Computers & Internet
Dx2300 shuts off after 10 minutes. Will turn back on. is heating
Sounds like a high limit temerature sensor. Could still have air flow blockage inside the dryer or faulty sensor.
Mar 05, 2013 | Dryers
Why does my HP dv6 shut down unexpectedly, even when it's charging?
Remove the battery and charger. set a timer for 3 minutes and hold down the power botton. this should take care of it.
May 30, 2012 | HP Computers & Internet
Dryer runs for 10 mins and shuts off.
Your dryer motor has a thermal overload built in to it. If your symptom is shutting down allow to cool and it works again for a few minutes the shuts down again.
http://www.on-timeappliance.com/dryerrepair.html
Mar 28, 2012 | Frigidaire Dryers
Have Fujitsu P42VHA 10/W. Works for a few minutes
its a power supply problem ..check for leaky capacitors and dry joints ..farr64[colin] good luck
Dec 29, 2009 | Fujitsu Plasmavision P42HHA10 42 in....
Mi T M Model CM-1250-A/C pressure washer shuts off after 10 minutes use. Wait 5 minutes and restart by pressing On/off switch. Shuts off again in 10 minutes. Works fine while on. Thoughts on problem?
I have one of these machines and it is VERY sensitive to line voltage. Be sure not to use an extension cord or the CM1250 will shut down. If you do use an extension cord use a very heavy one. The unit uses very close to the capacity of a 15A circuit. Good luck.
Nov 24, 2009 | Garden
2004 s40 volvo-ac works for 10 minutes then gets warm.
evaporator leaking or condensor fan inop
Jul 31, 2009 | 2004 Volvo S40
Magnavox 15
IT IS YOUR POWER SOURCE HAD SAME PROBLEM CHANGED POWER PLUG HAS HOT TURNED OFF SINCE
Oct 10, 2007 | Philips Magnavox 15MF400T 15 in. LCD...
Seville Classics MSC10166 Tower Fan Logo
Top Seville Classics Dryers Experts
Dan Webster
Dan Webster
Are you a Seville Classics Dryer Expert? Answer questions, earn points and help others
