Question about Puma Air Tools & Compressors
Pop off on second cylinder
Keeps going off replaced but still goes off the others never do PUMA TN 5060VS
Paragon Popcorn Popper Thrifty Pop 4 OZ Parts
I run a part-time hot dog stand in Nashville, TN. I've bought parts from Fine Entertaining . I'm better sure they sell popcorn popper. Paragon Popcorn Popper Thrifty Pop - the manual is under the resource section.
May 25, 2012 | Paragon Theater Pop 4 Popcorn Maker
I want to buy a replacement watch strap for the Puma Drive Chronograph Watch PU111F20118032
On most watches, you can only get replacement bands that fit the style of watch through the original vendor. You will have to contact Puma and be ready with the case #s on the back of the watch. Good luck.
email: customerservice@puma.com or call 888-565-PUMA
Jul 19, 2010 | Puma Drive Chronograph Watch...
After getiing my puma back?the engine now smokes and there no compression in number 2 piston is my engine dead?
You have this listed under 2001 Ford Focus, but say it's a Puma and also reference the #2 piston. Based on that, I'm going to assume you mean an Arctic Cat Puma snowmobile. If so, Pop the head off (4 nuts) and if it's the gasket, you'll see where it's blown out. Get a new gasket, pop the head back on and tighten it back up. If it's the piston or rings, you'll be able to tell when you pull the head. If the piston has a hole or melted down from a lean condition, you'll see it. If the rings are shot, you may see some scoring on the cylinder wall. You might also be able to tell by the spark plug. Pull it and check for a silvery residue. If the piston burned, it will sometimes leave a silver (aluminum) film on the plug. A whiteish plug means lean which could cause the head gasket or piston problem as well. A dark (brownish, blackish) plug means it was running rich and your piston "should" be ok. Again, best bet would be to pull the head and check everything out.
Feb 15, 2010 | 2001 Ford Focus
I puug tn cord the green light goes off wont
check if the power ac adapter pin the goes to the side of the laptop is damage, if not then try connecting ac adapter with laptop to a diff power wall socket, if fails then replace the motherboard.
Oct 12, 2009 | Dell Inspiron 1501 Notebook
92 fxr installing new regulator....which breaker is 30 amp?
30Amp breaker is the Main Circuit Breaker. The blk wire goes from the copper stud on it to the starter. The TN goes from it and splits, one tail goes to post A on the ignition switch and the other to the starter relay. Another BK wire goes from the same post as the TN wire and it goes to the regulator.
Aug 26, 2009 | 1993 Harley Davidson FXR Super Glide
I have a ford puma, its really hard to go into 5 gear most of the time but every other gear is fine! There isnt a puma on the select car so put escort instead.
i belive that the syncrohnizers are going out of your transmission you could have it rebuilt. or you can keep driving it the way it is but it will keep getting harder and harder to shift
hope i helped you out
please rate my soloution
thank you
Apr 21, 2009 | Ford Escort Cars & Trucks
Ford Puma Cuts out...
There are 2 things that can go wrong one cheap and the other around $100-200. The first problem could be the fuel filter if it is getting plugged up it wont allow the fuel to flow through to your engine sufficiently, but at faster speed it will still allow the fuel to flow enough. The other problem could be the fuel pump, this is the more expenive route. This will have the same effect on a car as the fuel filter. If I were you I would try replacing the fuel filter first to see if that made a change, this should only cost you around $5-20.
Jan 22, 2009 | 1998 Ford Escort
Air Tools & Compressors Logo
23 people viewed this question
Top Puma Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Puma Air Tool and Compressor Expert? Answer questions, earn points and help others
