Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
ICS I was told to get rid of the red shadow on my screen was to ck the converg. ICS, I'm not sure what or where that is?
  • 1,694 Answers
Replace convergence IC's & check fuse devices....
Normally done by a skilled Sony tech.....
If you need step-by-step instructions, try to find a local tech
who will work with you....please comment....T.
Posted on Nov 04, 2007
0 characters
3 Points
How do I get rid of a red shadow in the upper left of the screen?
U can't tv have parts problems.Ur tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment anywhere in the picture,have picture colors shadows or 3D pictures look like.The tv have 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced on the tv convergence board to solved the tv convergence picture problems.The Shop,will cost u like $300-350 for parts and labors.
Oct 22, 2010 | Pioneer PRO-200 60" Rear Projection...
I have red letters on top of the letters that are on the screen and red shadows on the screen
Thats a convergence issue. You can get the convergence repair kit for your model at the kit contains the ICs , resistors and the CD with instructions.
Sep 22, 2010 | Panasonic PT-47WX49 47" Rear Projection...
My tv has lots of red and green. Faces are shadowed by a red outline. It occurs on all channels and dvd.
If problem does not fix by flash focus/ convergence adjustment in Menu then replace convergence output ICs on D board of tv that sounds defective and causing problem.
Comvergence output ICs replacement requires soldering work with proper tools and electronics knowledge/ experience, call local tech if you have no experience.
Jul 16, 2010 | Sony KP-51WS510 51" Rear Projection...
Red shadow
Ur tv have a convergence problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.All these parts must be change to solved convergence problems.The shop will cost U $300-350 for parts and labors.
May 26, 2010 | Sony KP-51HW40 51" Rear Projection...
Our Sony KP-46WT510 rear projection screen TV just
Convergence ICs, they are big black ICs will have part# on them if they are STK392-110s use 180s better ICs also CK pico fuses in front and behind ICs
they will look like resistors but will be Yellow or Green 5amps/6amp fuses
Mar 18, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
I have a sony projection tv KP-46WT500 and have red/green shadows around the people plus some double word image that are red & green. On the tv guide the station #'s are double and green and red.The...
Replace Both of your convergence ICs STK392-??? they are big black ICs will have part number on them also CK pico fuses they look like resistors but are fuses they will be yellow or green will be around ICs.
Aug 08, 2009 | Sony KP-46WT500 46" Rear Projection...
Fix it
Convergence ICs STK392-180s is what you need to upgrade too! They are big black ICs also CK green&yellow pico fuses.
Jun 23, 2009 | Sony Projection Televisions
Red shadow on all images
you will need to cahnge the Convergence Ics for sure and possibly the feed resistors. You will need two STK392-110 Convergence ICs and 1 JVC convergence resistor Kit #1 you can get the parts at the following link with free installation instructions with pictures. Heres the link.
Jan 22, 2009 | JVC AV-48WP74 48" Rear Projection...
Colored shadows on sides of subjects
Convergence problem... most likely caused by convergence ics
Jan 18, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
Top Sony Projection Televisions Experts
Steve Sweetleaf
Steve Sweetleaf
Jason Harris
Jason Harris
Are you a Sony Projection Television Expert? Answer questions, earn points and help others
