Question about Smart Pool Inc Dolphin Diagnostic Automatic Pool Cleaner Ne250
Dolphin pool vacuum gets stuck on main drain - Smart Pool Inc Dolphin Diagnostic Automatic Pool Cleaner Ne250
    Top Expert:
  • Smart Master
  • 8,471 Answers
Turn suction down on drain
Posted on Nov 23, 2017
If dolphin turns on its side against wall , will not flip back upright. Continues on its side and won't move
I am unsure of your question. Are you referring to an actual Dolphin or some sort of Toy?
May 16, 2017 | Dolphin Pool & Spa
My Hayward pool sweep gets stuck when it goes over the drain at the bottom of the pool
It could be worn shoes on your pool cleaner causing the problem, but it is most likely just that you need to get a ring drain cover to cover your anti-vortex drain. It creates a smoother surface and is designed specifically to work with in ground automatic pool cleaners that are getting stuck on the drain.
http://www.backyardcitypools.com/Automatic-Pool-Cleaners/NE290-Smart-Ring-Drain-Cover.htm
Mar 19, 2011 | Hayward Navigator Pool Cleaner
My barracuda gets stuck on pool's drain. This is annoying since I have to be around to watch it and pull it off. Valve to main drain is shut. What else should I do?
There is a ring that you can buy to go over anti-entrapment main drains that will prevent automatic pool cleaners from sticking on the drain. They are designed specifically for this purpose. If you are sure that the main drain in closed, this is going to be the best and cheapest solution.
Jan 28, 2011 | Zodiac Baracuda G4 Automatic Pool Cleaner...
The barracuda keeps getting stuck on the main drains. I have tried every different setting to even with no vac on the drains it still gets stuck what to do
Is your main drain closed completely? That is the first thing to check. If the main drain isnt completely closed, that is going to be your problem. If it is the pool cleaner that is causing the problem, there is a ring that you can buy that goes over the main drain to prevent automatic pool cleaners from sticking. You will need to install one of these and it should remedy the problem.
Jan 18, 2011 | Zodiac Baracuda G3 Automatic In Ground...
Our baricuda g3 often gets stuck on the main drains in our pool. we have the main drain lines shut off. cant figure out why the cleaner only gets srtuck in that one place
Since you have already verified that the main drain line is closed, it sounds like you need to install one of the smart ring drain covers below. They are made specifically to work with in ground pool cleaners to prevent them from becoming stuck on the main drain. They are easy to install and should eliminate the problem.
Nov 06, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
It gets stuck in the pool drain and wont move
If these pool cleaners are getting stuck on the main drain, it is probably an easy solution. First, make sure that your main drain in closed. Make sure the main drain grate is installed. If the main drain is not flush with the pool, you have an installation problem and you will need to consult with a pool builder about soultuions to fix it.
Aug 18, 2010 | Zodiac Baracuda G3 Automatic In Ground...
POOL CLEANER GETS STUCK ON THE MAIN DRAIN
If it's an older Navigator and it just recently started to hang up on the drain cover, replace the throat assembly, part 29. The lugs or hold offs on the bottom of the assembly have worn down and are not breaking the suction as the Navigator travels over the top of the domed drain cover. Replaced mine and no longer have the "my navigator gets stuck on the main drain" problem.
Aug 06, 2010 | Hayward Navigator Pool Cleaner
Is it safe for vacuum to be left in pool while superchlorinating?
Thank you for posting your question here on Fixya.com.
It will not directly affect the cleaner but may discolor (fade) the plastic. Since the cleaner should never be in the water when the pool is in use are you certain there is a need to disinfect the cleaner? You may be better off washing the filter bag on a sanitary cycle in a washing machine instead of running the unit in a high chlorine environment.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jul 12, 2010 | Dolphin Maytronics Diagnostic Robot...
Stuck barracuda
It is probably not a problem with the shoes. These pool cleaners (and automatic pool cleaners in general) often get stuck on the main drain since the implementation on the new anti-entrapment drains. There is a ring that you can buy that goes on the drain. It is designed specifically for preventing pool cleaners from getting caught on the main drain.
Jun 08, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
My dirt devil Rampage Robotic pool cleaner vacuum get stuck on the bottom drains
There is a ring that is designed to fit over bottom drains to prevent robotic pool cleaners from getting stuck. There are several different brands/kinds available and any of them should prevent the problem. Here is one example:
May 07, 2010 | Dirt Devil Rampage Robotic Pool Cleaner...
Smart Pool Inc Dolphin Diagnostic Automatic Pool Cleaner Ne250 Logo
162 people viewed this question
Top Smart Pool & Spa Experts
Thomas Perkins
Thomas Perkins
Robco Water
Robco Water
Bill Boyd
Are you a Smart Pool and Spa Expert? Answer questions, earn points and help others
