Question about Sony PlayStation 2 Slimline Console
Broken AV port on back of Playstation 2
My AV port is broken which i know for a fact. no matter what i try to do to the wire i cant get it to work. i can somewhat see the game but it is black and white with grey stripes flowing up the screen. im really not sure what to do, is there a way to replace the AV port? or do i just have to get a new one? and, does GameStop buy broken ps2's?
Waggygee
  • 8 Answers
SOURCE: playstation 2 wont read games
I used to have a ps2 and experienced this exact problem. In my case the lense was dirty, I opened my ps2 and VERY carefuly wiped my lens with methelated spirit (becareful, some methelated spirits that contain oils ment to prevent their consumption, these must be avoided!)then blew out the whole system with a hair dryer. Reassembled it and VWALA! it worked like it was bran new or even better!
Posted on Apr 06, 2007
petraman7
  • 1175 Answers
SOURCE: PS2 No Sound No Picture
This sounds more like a catastrophic failure on the main board.
Barring replacing the whole thing, you may find someone selling another as parts
Posted on Mar 24, 2008
SOURCE: SCPH-50004 PS2 problem
**** it up
Posted on Aug 12, 2008
SOURCE: SCPH - 50004 Pal PS2 colour and reading problem
can you give me some cheats for dragonball z budokai tenkaichi 2
Posted on Oct 10, 2008
SOURCE: PS2 Slim AV/Display/Sound Problems
soo there are other ways to fix this, but its hard to find the parts and depending on your soldering skills may not help. fix one is replacing the av connector on the mother board. thisis not fun as its a very delicate un solder and re solder job. fix 2 just replace the wholemother board,easier but still hard to get parts for. hope this helps
Posted on Dec 10, 2008
How to setup online gamming
You need to have a wired connection. Plug one end of a ethernet (cat5/cat6) into one of your router's ports. Plug the other into the back of the PS2. You will have to sign up for a free Playstation Network account.
Oct 04, 2012 | Sony Playstation 2 Ps2 Slim System Console...
My psp cannot read memory stick duo
-try other memory card to know if the port is having a problem, if other memory card is working so the problem maybe is the other memory card...
-if the problem is memory card, try getting a card reader and try to format that in your PC.
-you just need to prove if the port is broken or the memory card itself is broken....
-if port is defective you have to bring it to Sony or to a local repair center.
Feb 22, 2011 | Sony PlayStation Portable (PSP) Console
Intermittent Sounds Problem on PS3
If you have verified the AV cable is not the issue, it's likely the AV port on the PS3 is the culprit.
Try your cable on another PS3 to be sure. Then try your PS3 and cable on another TV.
If it still misbehaving, send it back to Sony for repair.
Mar 26, 2010 | Sony Playstation 3 (PS3) Console
Both my joystick are not working
Try Other Games... If That Still Doesn't Work Loan An Additional Joystick Just To Check If It's Joysticks Fault, If The Additional Joystick Doesn't Work Then It Must Be A Broken Port Or Something...
Nov 21, 2009 | Sony PlayStation 2 (PS2) Console
Hd port on back broke need to reset video to use av cables any help???
Press the power on the PS3 for 5 seconds (in standby mode) till it beeps thing to reset the graphics output
May 29, 2009 | Sony Playstation 3 (PS3) Console
MY TV CONNECTOR AT THE BACK BROKEN OFF
you can hook it up thru av input..what i mean is the red white and yellow wires hook wires into the OUTPUT on box and the input on tv then change tv to the input u hooked them to..for example if u hooked them into av1 then turn tv to av or hiy input on remote
May 26, 2009 | Sharp 25N-S100 25" TV
My ps2 anolog dual shock controller wont work!
It could be the PS2 connector port.
1) Try cleaning it. Maybe used compressed air or just blow into the faulty connector port.
2) Something more challenging, is to maybe open up the PS2 and to search for any broken connections between the Ps2 controller port, and the Motherboard of the PS2. Use a phillips #0 or a phillips #1 screwdriver, flip the ps2, you will see all these tiny squares, pull them out using something sharp, and underneath them there will be the screws, also there are some screws located underneath the warranty sticker and another underneath the Info sticker, just probe the surface until you land upon a hole. there you will find the screws. Open the ps2 up and you will spot the connector and search for any broken connections. any broken links can be fixed just by using a soldering iron and some solder.( OPENING UP YOUR PLAYSTATION VOIDS YOUR WARRANTY).
3) IF your ps2 is still under warranty, you can send it back to sony, or one of their many repair centres around the nation( IF U ARE IN THE USA). If in another nation, you can visit sony.com and follow their instructions on how to go about with in warranty repairs
Dec 29, 2008 | Sony PS2 Dual Shock 2 Controller...
Sony Playstation 3, Pins to plugging in to console is broken. Would it be possible to fix it.
You mean the AV port?
If that is the issue use a HDMI cable.
The ports are part of the motherboard so you need to replace the whole thing.
Sep 02, 2008 | Sony Playstation 3 (PS3) Console
I can't see the ps2 in the tv
try a new cable. try it on a dif t.v
you might have broke the av port. or a bad solder
May 17, 2008 | Sony PlayStation 2 Slimline Console
Sony playstation 2
try jiggling the av connector at the back
my old friend had the same
problem back when i was
in grade 4
Jan 21, 2008 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 Slimline Console Logo
468 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
