Question about Titan Xt290 Reconditioned Airless Paint Sprayer, 3000 Psi Maximum
Titan Xt290 paint sprayer not picking up paint
  • 2,527 Answers
The lower valve is stunk do to inproper claening
Posted on Mar 09, 2015
3 Suggested Answers
SOURCE: I have a titan 400 i paint sprayer, won't prime..
sometimes the ballbearing in the shaft where you dip into the paint gets stuck .if you unscrew the end of the shaft and clean the ballbearing.then put back together and try prime again.
Posted on Apr 23, 2009
SOURCE: TITAN 440 PAINT SPRAYER: PUMP WILL NOT START,
how can i get the gun to spray it is just dribbling out
Posted on Mar 09, 2010
What would make a paint sprayer lose suction while beeing used
Wore out packings You have a little titan
Check to see if you have flat valves or balls flat valves are better but the packing kit is around 60.00 dollars also check the prime knob it also has seals .
The KEY is to always clean the mechine after use and oil the pistion with throught oil and it will last forever if you repack it every 2or 3 hundred gallons or so and use good tips
Mar 01, 2015 | Titan Advantage 100 Airless Paint Sprayer
Titan 640 keeps blowing 15amp fuse
It could be a short in the unit from getting wet, pump may be getting seized by dried paint in pump or your using too small of a extention cord
Aug 29, 2014 | Titan Impact 640 Skid Airless Paint...
How to repack the sprayer
The packings are static and self adjusting. The repack kit includes the piston so it replaces everything. Just buy the kit and follow the instructions. Try Scott at American Airless on 770 4771337.
Aug 25, 2014 | Titan Paint Sprayer. Advantage 200 Airless...
Does a titan airless paint sprayer require oil
Yes throught oil to be filled at the top of the pistion read on mechine ware
May 03, 2014 | Titan Paint Sprayer. Advantage 350 Airless...
Titan advantage sprayer stops pumping
Yes im sure you see you need to clean the mechine and all filters after each use if you ever want to work again
Apr 11, 2014 | Titan Advantage 100 Airless Paint Sprayer
My 640 titan run but will not prime it does not spray product
It is hard to follow your question....however; if the sprayer turns on and the paint fails to enter the nozzle, you may have a blockage. Take the spray nozzle apart and run hot water over it to clean it out. You may need a small brush or cu-tip to clean the inside of the barrel. Blow though it and see if air passes easily. reassemble and run as you normally do. Be certain the top is attached to the paint reserve tightly and securely. Any air leaks will prevent the sprayer from building up pressure within and thus no spay will be emitted.
Dec 19, 2013 | Titan 440 Impact Airless Paint Sprayer...
Pumps in up stroke but not in down stroke
Single stroking: You have something stuck in one of the valves, probably the inlet valve.
Sep 25, 2013 | Speeflo Titan PowrTwin 6900 Plus D.I....
Old Wangner Cap Sprayer & Compressor
The Wagner Capspray 9000 HVLP is about 20 years old, but you should be able to find parts, at least for the HVLP gun. The manual for the turbine is #0276989. If you are in the US try Scott at American Airless Wagner Titan Graco Paint Sprayers or in Europe try us at:
Home Lion Industries
Jul 28, 2013 | Wagner Spray Tech Cap Spray Paint Sprayer,...
Titan 640i wont prime
If you still have a problem with a Titan 640i please give us a call. We introduced this sprayer to the UK back in 1985. Lion Industries UK Ltd 01543 251 560
Dec 31, 2012 | Titan 440 Impact Airless Paint Sprayer...
Titan Xt290 Reconditioned Airless Paint Sprayer, 3000 Psi Maximum Logo
245 people viewed this question
Top Titan Air Tools & Compressors Experts
JOHN LAPIER
Steve Pack
Steve Pack
Vernon Taylor
Are you a Titan Air Tool and Compressor Expert? Answer questions, earn points and help others
