Question about Honda 11 HP with Recoil Start GX340-QA2
Honda gx340 backfiring
Why is my honda gx340 backfiring
My Honda gx340 is revving high all the time Can some one tell me y thank you
should be an internal govenor on a plant unit like that
there is a thicker than normal metal rod running off the carby to the motor and that is where you adjust the govenor
cant find good instruction how that governor is adjusted ..if adjusted the wrong way it will rev out may even throw a piston
then check carby idle adjustment
should hunt (rev up and down only slightly )as load changes
you tube
11hp Honda GX340 cold start
https://www.youtube.com/watch?v=i3_v68__X5o
Honda GX340 HGI Partsf21c43c2-def4-46c5-9224-ed46701c0c01.jpghonda-gx340-revving-high-all-time-some-qkhmqzcwln4tohiil4ndbnz4-2-2.jpg
Jun 22, 2016 | Honda Gx340 Gas Engine 11hp Motor Pressure...
What RPMis the max torque
the chart shows figures of 10.7 hp-8.0kw with a torque of 19.5 ft/lbs- 26.4nm at 2500rpms ( max net torque)
the chart shows gx390 is 11.7hp (8.7kw) but the torque is the same as the gx340
you can get these figures from world. honda com or by going google and typing in--torque range of honda gx 340 motor at max rpms
10 hp engines running at 2500 rpms will be good for gensets of 5kw continuous out put as most makes run that size engine
Apr 20, 2016 | Honda Gx340 Gas Engine 11hp Motor Pressure...
Have honda gx340 11hp pressure washer and gas keeps going into oil?
Excessive fuel entering the inlet manifold, carby needle and seat not shutting of fuel flow , remove and clean fit new gaskets and needle and seat if worn.
Jul 02, 2015 | Honda Gx340 Gas Engine 11hp Motor Pressure...
Pressure washer rope recoils to quickly when pulling to start
I'm sorry if I'm not quite understanding the question.
Are you saying the rope MAY be too short and so the amount of pull available is also shortened?
Feb 23, 2015 | Honda Gx340 Gas Engine 11hp Motor Pressure...
I have a Honda EP5000 Generator set with GX340 engine, the problem is that too much oil is discharging from OHV cover into the Air Cleaner via that rubber pipe and spilling out from it. Engine also smokes...
Hi,the quick,but not final fix for this issue is to use a oil additive similar the one-s from the cars,but make sure you are using the one required by the fuel type.The engine is worn out,needs overhaul,soon or later.Good luck,regards
Nov 01, 2014 | Honda 6kw 120/240v, Gx340, Recoil Start...
How to replace valve timing gear in honda gx340 engine
Align crankshaft and balancer gear first. Rotate crankshaft and align timing gear. Alignment mark may be hard to see on crankshaft for timinig gear.
Jul 09, 2012 | Honda Gx340 Gas Engine 11hp Motor Pressure...
Service manual honda gx340
HONDA GX340 GX340K1 ENGINE SERVICE REPAIR PDF MANUAL DOWNLOAD 1991-2001
HONDA GX340 GX340K1 ENGINE SERVICE REPAIR PDF MANUAL DOWNLOAD 1991 2001...
YOU CAN GET THAT REPAIR DONE TODAY!
EVERY SERVICE AND REPAIR JOB IS COVERED!
CLICK ON THE DOWNLOAD NOW BUTTON!
FACTORY TYPE PDF SERVICE REPAIR MANUAL!
With this Professional Quality, highly detailed Service Repair Workshop Manual you will be able to work on your vehicle with the absolute best resources available, which will save you a lot of money in repair costs and will also help you to look after your vehicle.
Contains step by step instruction & highly detailed exploded pictures & diagrams to show you how to complete the required job correctly & efficiently.
Covers the entire vehicle from front to back, its the same type of Manual that is used by Professional Mechanics to service or repair your vehicle.
** An absolute wealth on information at your fingertips!
** This manual is very easy to use!
** Print what you need when you need it!
** The ONLY Service Repair Workshop Manual You Will Ever Need!
** All repair procedures are covered!
** PC & MAC Compatible PDF
Instant Download means there is NO shipping costs or waiting for a CD or paper manual to arrive in the mail! You will receive this manual TODAY via Instant Download.
Nov 20, 2011 | Honda Electrical Supplies
I have a Honda GX340 power washer and would like to know what types of oil and quantities I need for the engine and pump
The Honda engine will use standard 30W. the pump will use 30W non-detergent.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
Mar 09, 2011 | Honda Pressure Washer PSI 3000
Motorturns over hard with pullstarter on my gx340 pressurewasher
You have a nice setup, lots of power. The honda gx340 has a compression release built into the engine so it should be relatively easy to start. With the pressure pump under load however, it will be very hard to pull the rope. With water connected hold spray gun open so water is running out tip and pull rope to start (for easy start, remove tip from gun) . If it still feels very hard to pull rope while holding gun open, most likely problem with lubrication in pump or engine valves are not adjusted correctly preventing compression release. If you suspect problem, go to store where you purchased the unit or any store that sells gx340 and pull the rope to get a feel of what force is required to start engine and compare to yours. Good luck.
Feb 15, 2011 | Honda Pressure Washer PSI 3000
Honda 11 HP with Recoil Start GX340-QA2 Logo
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
