Question about Sportline Watches
Nirvana storm watch - Sportline Watches
How do you make bahama storm shutters?
They now make these in Plastic that will retail YEARS of service
Apr 11, 2013 | Watches
Set the time on a storm toywatch
be specific with your question
Jan 11, 2013 | Watches
I got a talking watch but no instructions. Super Storm Talking Alarm Watch. Please help
For Super Storm watch:
Click Mode (upper left) button until either current time blinks (1st click) or current alarm time blinks (2nd click).
Immediately (before the blinking stops, approx 3 seconds), click hours (lower left) and minutes (lower right) to set time. When you pause the clicking, time or alarm will be set.
Sep 01, 2010 | Watches
Need a user manual for the time magazine free chronograph watch
I have NO ideal what kind of watch it is so I am giving general chronograph instructions. You will have to use as it applies to the watch you were given.
These instructions are provided for users who are not familiar with using a mechanical/analog chronograph. The instructions may be applied to any chronograph that has a seconds counter, 30 minute counter, and hour counter.
Please refer to the instructions of the appropriate model to determine the location of each counter on the dial. Note: some of the features described here may not be available on your particular model. Again, refer to the specifications to see if they apply to your model.
Using the chronographe functions:
How to read the chronographe:
For a chronographe that has a center seconds register, a 30 minute register and an hour register. Example 1: If the hour register is between the 1 and 2, but closer to the 1, and the minute register is at 20, and the seconds register is at 35, then the elapsed time is 1 hour 20 minutes and 35 seconds. Example 2: If the hour register is between the 1 and 2, but closer to the 2, and the minute register is at 20, and the seconds register is at 35, then the elapsed time is 1 hour 50 minutes and 35 seconds.
How to read the tachymetre:
If you are driving and want to determine the speed of the car using your tachymetre, start your chronograph when you pass a mile marker, stop your chronographe when you pass the next mile marker. Look at the center seconds hand and read the number on the Tachymetre scale, this number will indicate the miles per hour that the vehicle is travelling.
How to read the pulsometer:
Some watches have a pulsometer instead of a tachymetre. Use it as follows: Start the chronographe and begin counting the pulse. When you have counted 30 beats, stop the chronographe. The number on the pulsometer scale will indicate the pulse rate per minute.
How to read the telemeter:
Some watches have a telemeter instead of a tachymetre or pulsometer. Here is an example of one use for a telemeter: Start the chronographe when you see lighting. Stop the chronographe when you hear the thunder. Read the center seconds hand on the Telemetric scale and the number will indicate the distance separating the observer from the place where the lighting struck. This can give you a good indication of how far off a storm might be.
The many uses of a chronographe:
A chronograph has many practical uses, from timing a plane flight, a car ride, or simply being curious. There are also some uses for the chronographe that may not be so obvious. For example, you can use the chronographe on your watch as a dual timezone indicator. This is done as follows: If it is currently 6 A.M. in your home location and it is 12 noon in London, start your chronograph at exactly 6 o'clock. The number of hours displayed on your chronographe hour register will then show you the current time in London. Of course, these are just some uses of a chronographe. There are hundreds of uses for chronographes.
Instructions: Astronic Chronograph Chronograph Chronometer Power Reserve Chronometer Astronic Chronometer World Time Chronometer Retro Alarm General Chronograph Common Q & A's
Aug 12, 2010 | Watches
Our clock reads Military time ever since a terrific rain storm, it didn't get wet. We set it at Mt time and it's OK until midnight and then it goes to Military time. Our manual got lost and don't know...
keep pushing the hour button through the 24th hour. Then it cycles into the 12 hour mode. If you keep pushing the hour button again through the am and pm it will cycle into the 24 hour mode again. Etc.
Feb 01, 2010 | Watches
I need instruction manuel for how to use a storm mk 2 circuit mirror watch
I went to the storm store and got a manual for free
Dec 04, 2008 | Watches
My watch face has steamed up after I went running in a heavy rain storm, any suggestions to get rid of condensation without taking the back off?
Why not put it on a heating pad with a "desicant" bag (moisture absorbing crystals) both on a terry cloth face cloth.
Low low setting on the heating pad or the watch oil will dry up and movement will be slowed down.
When I was a kid with a cheap timex, I tried the low elec oven or hair dryer with the casing exposed. To hot and too harsh air movement. Probably expanded the spring and lost its "spring".
It will be close to $100 for our PhD watch makers today. Oil and replace main spring. Ce'la gureer.
Jun 27, 2008 | Watches
Calvin Klein K7111 brown watch strap
try here: http://www.a1watchbands.com/ for example: http://www.a1watchbands.com/product_details.php?search=&id=712 or try on ebay, for example: http://search.stores.ebay.ie/calvin-klein-strap_Watch-Parts-Accessories_W0QQcatrefZC6QQsacatZ10324
Aug 17, 2006 | Calvin Klein K7111
Watches Logo
12 people viewed this question
Top Sportline Watches Experts
ray gallant
Tom Chichester
Bill Boyd
Are you a Sportline Watch Expert? Answer questions, earn points and help others
