Question about Kohler 12hp Engine Es Cs Command Generator 4-11/32" Tapered Shaf_ Cs12stg-941516
Why kohler cs12stg engine surging - Kohler 12hp Engine Es Cs Command Generator 4-11/32" Tapered Shaf_ Cs12stg-941516
Was mowing fine then motor began surging and now blades will not engage or disengage
Because the mower began surging and now the blades do not work, I am thinking something electrical. The PTO and electric clutch would be where I would start. The clutch can be checked and should read 2 -4 Ohms.
May 13, 2016 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
HOW DO YOU REMOVE FULE FLOT BOWL KOHLER CONFIDANT 5 5CKM21
It is not a float issue because the motor cannot consume the entire contents of the gas chamber in one instance of a surge. This is a throttle issue.
Oct 05, 2015 | Kohler Electrical Supplies
I have a new bad boy mower with a 747 cc Kohler engine, the motor has 9 hours on it but the engine surges at anything but wide open
you need to adjust carb on the side of carb there is a mixture adjustment screw on slow slowly turn screw out until surging stops now go full throttle if die need rebuild carb if runs fine your done
Aug 10, 2014 | Garden
Kohler 18kw propane generator surging or hunting
The fuel mixture and or pressures are wrong
Aug 24, 2012 | Kohler Electrical Supplies
My Kohler lawnmower engine is surging and then shutting off. Is this a choke problem?
Hi, the carby needs to be stripped down and all jets cleaned out, regards Phil.
Jun 13, 2012 | Yard Man YardMan 11A41K3001 21Inch 173cc...
Kohler boat genny surges
Check fuel supply, carb etc
Feb 05, 2012 | Kohler Electrical Supplies
Kohler courge sv720-0010 on cub cadet
SOUNDS LIKE IT HAS SOME BAD GAS YOU MAY NEED TO CLEAN THE CARB AND IT MAY NEED A KIT
Oct 10, 2009 | Garden
DGS 6500 w/26hp Kohler Courage surging
i HAD SIMILAR ISSUES WITH MY 2500 SERIES CUB CADET....IT WAS THE CARB.....REPLACED, AND ALL HAS BEEN WELL...THINK IT WAS APROX 200.00
Jul 03, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Cub Cadet 2165 engine surges and eventually stalls
Replace the fuel cap!!! The problem is that hte fuel cap vents from it's underside. In so doing it sucks up all of the grass debris and dust that hte mower deck kicks up and the vents get clogged up. As the engine uses the gas, it builds up a vacuum in the tank and the gas can no longer flow from the tank to the engine.
Jun 15, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Kohler 12hp Engine Es Cs Command Generator 4-11/32" Tapered Shaf_ Cs12stg-941516 Logo
22 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Wayne McNeil
Craig Butler
Craig Butler
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
