Question about Solo Backpack Sprayer
Why am i losing pressure on my roll around sprayer?
Garden hand pump sprayer not presssurising
There is probably a leak somewhere in the hosing or gasket. As you try to pump it up, take some soapy water and pour it around sealed areas of the sprayer. Look for bubbles as the sprayer leaks air. Also check the nozzle of the sprayer for a clog. Rinse it thoroughly with hot water until it has cleared any blockage.
Feb 22, 2014 | WD-40 Foaming Bike Wash 1L With Sprayer
My sprayer is new, but does not keep the pressure, any idea's? It's a 2 gal, pump up type sprayer.
Check under the lid/cover for a rubber gasket. This may have gotten unseated when putting the sprayer top on. It must form a tight seal around the lip of the sprayer top in order to keep the pressure. Alternative: Put water in the sprayer leaving some air on top to build pressure. Put a few drops of dish soap inside and gently stir. Put the cover on, and tilt the sprayer to coat all areas at the top. Start pumping and see where the bubbles come out---there is your leak. If it is near where the sprayer hose enters, and it is a permanent mount, you may have a bad seal. If the sprayer hose unscrews, you may need a new rubber washer inside. If bubbles come out of the wand, or other plastic seams, you may have a crack in the plastic. Depending on the location, you could epoxy over the crack to seal it permanently. Good luck.
Aug 11, 2011 | Roundup 2 Gallon Pro Garden Poly Tank Pump...
My 2 gal yellow ortho lawn sprayer will not get pressure to spray when I pump it. What can I do to resolve the issue?
First Check the gasket around the lid, and the one around the pump housing for any kind of leaks. If this does not solve the the problem, check the sprayer to be sure it is not on all the time you are pumping.
After that you may need to invest in a new sprayer.
May 08, 2011 | Garden
It keeps losing pressure. No matter how hard I screw on top, I hear a hissing sound as the air leaks out.
Check and replace the o-ring or seal on the top and check all connections for tightness and dry rot. Good Luck...
May 06, 2011 | Solo 3 Gallon Pressure Sprayer
Trying to remove pressure tank from inside spray unit. trying to replace all seals.
dont !!!!! just buy a new one bout 100 bucks but if u want it comes out thru top but u have to take lose underneath
way too labor intensive for the price of new one
Dec 31, 2010 | Solo 475 Backpack Sprayer Back Pack...
No water flow in kitchen sink
Sorry to say, you will need to replace that faucet, and also when you are shopping for a replacement, inquire about a rosette to cover the hole left by the voided sprayer.
Good luck...
Feb 24, 2009 | Home
Sprayer wont spray or hold pressure
We use the both the 425 and 475 solo sprayers most days at work and when they start to lose pressure ( after 6 months of daily professional use) we purchase a complete seal kit and put it through them. The only part I can't work out how to remove is the inside cylinder, other than that everything else is easily removed and replaced.
Jan 14, 2009 | Solo Backpack Sprayer
Solo Backpack Sprayer Logo
51 people viewed this question
Top Solo Garden Experts
Colin Stickland
Colin Stickland
Ted Maxwell
Are you a Solo Garden Expert? Answer questions, earn points and help others
