Question about Viper Vehicle Parts & Accessories
Python alarm my car died and is not getting spark alarm wont sound off and red light is blinking on dash on 92 mustang gt
  • 34 Answers
SOURCE: alarm wont stop
press the lock/unlock button on the remote and sometimes the brake pedal as well then it should work.
Posted on Jan 09, 2009
blueextc3221
  • 15935 Answers
SOURCE: i have a python sst car alarm
usually a combination of 2 buttons so the car doesnt start accidentally.
Depending on the number of output channels - the installer could have installed on any of the channels and that would dictate which buttons to press.
if it is not set on the AUX (output 2) button, then try...
  1. Lock + unlock at the same time - output 3
  2. * + AUX at the same time - output 4
  3. Lock + Aux at the same time - output 5
  4. Lock + * at the same time - output 6
You have not given the model # of the unit - so these are viper's STANDARD remote controm configurations.
CLICK HERE to enter your correct model # and Download your instruction manual.
Hope this helps.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Posted on Mar 01, 2009
  • 740 Answers
SOURCE: alarm wont shut off and lights keep flashing
This can be very simple look for alarm brain and unplug the brain, this vehicle should start. if it doesn't the look for valet switch it usually mounted under dash or on kick panel next to hood lever or close to where clutch pedal will be, Turn Ignition ON and in ON position flip switch the led light should stay on steady then the vehicle will start. If None of this works then you will have to take panel under steering column down and disconnect complete alarm system. Disconnect wires one ar a time and re-join them with the correct ones. It's NOT hard to do, there will be spliced into ignition wires.To do this you should disconnect positive lead on battery pole to stop the annoying noise until you are done. Good luck and contact if you need more help. Thanks for using FIX YA
Posted on Mar 24, 2009
SOURCE: Need to Silence Python Car Alarm 'Chirps' Permanently
I had the same problem, then I downloaded the user manual from the Directed Electronics site. It seems with most of the remotes (1400xp included) all you have to do is press the AUX button and then the Lock/Unlock button. This puts it into Silent Mode and no more chirping late at night or early in the morning, but you still have the ability to have it chirp when you need to by only pressing the Lock/Unlock button. Hope that helps.
Posted on Jul 14, 2009
albaby6
  • 58 Answers
SOURCE: need to pair the remote with the alarm
If you know where your Valet switch is, turn the ignition on, push and release the valet switch once, then push and hold it, you should hear the siren chirp once, then while still holding the valet switch, push the #1 button on the remote, you should hear the siren chirp again. it is now programed. If you have the package that came with the remote, it should have a table on the back that tells you how many pushes of the valet for which feature you want to program. Most remotes are one push for all features, some are 7 or 8 pushes. So if it say auto learn is 7, turn the key on, push it 7 times, the push it again and hold it, the push #1 button, and it's programed. Hope this helps. If all else fails, take it to your nearest best buy, if they charge you to program it, it won't be much.
Posted on Aug 21, 2009
There is a blinking red led light under lower left side of driver and steering wheel attached to dash. It blinks ALWAYs!!!
This is most likely your "Valet" alarm disable switch. Use to disable your car alarm so you can keep your Alarm Fob and let a Valet, mechanic, friend etc. operate the car without the alarm being functional. If it is an after market alarm, consult the mfg's manual, if OEM contact dealer for operating instructions.
Jun 30, 2013 | 2004 Hyundai Tiburon
Red light blinking on dash
what is the shape of the red light,and it sounds the alarm is on
Oct 30, 2012 | 2011 Dodge Journey
What is blinking red light on top of dash board by wind shield and what is green light on rear view mirror for
The Green one on the rearview sounds like an autodimmer. (tints the rearview mirror from bright headlights behind you) & the Red one on the dash could be an alarm warning light
Feb 24, 2011 | 2003 Ford Explorer
The red lights blinks all the time on the dash an the remote wont start car or lock or unlock doors.
Sound like an security module problem; any aftermarker alarm there? I suggtes check wires, wiring or loss conecctions.
Jan 30, 2011 | 2005 Ford Escape
Hello, Please help! My 1996 Mustang Gt car alarm wont let the car start. any suggestions? Ericf
use the key to lock and then unlock the drivers door then try to start if it still doesnt start then go to pass/side door and lock and unlock it and then try to start the switch on the drivers door may be bad, if this is a factory alarm system, if its aftermarket then you will need to locate the reset button under the dash, this will be a small red push type button, you will have to turn key on and push button in four times quickly, also are you sure its the alarm? it may be a bad battery or starter but start with the directions i gave first and let me know if it doesnt work make sure to relist the problem. good luck.
Jan 20, 2011 | 1996 Ford Mustang
2006 Ford Mustang GT wont start. Passenger side lights always stay on. Keyless remote wont open doors, trunk or sound the alarm (I checked the keyless remote battery it still has juice) When I turn the...
From the clicking sound and the fact that alot of your cars systems are down i would say that your battery is dead, if not bad altogether, or a terminal is loose on the battery. Check the terminals on your battery (be careful with the + (red) side and do not touch anything else metal on the car or the - (black) pole while touching it or just disconnect the - (black) for safetys sake). Check the terminals for looseness or corrosion and repair as neccisary. Then try a jumpstart but do not let the car "click" too much or you will burn out your starter. If your car's battery is indeed dead/bad you will find out within the next few times you try to turn on your car (it simply wont turn on) take the battery to a auto parts store and ask them to do a test. If the battery is ok then you can have it recharged if its bad then you will need a new one.
Dec 20, 2010 | 2006 Ford Mustang
2003 Ford Expedition - What do blinking red lights signify?
Do you have an alarm system installed? These sound like the alarm indicator lights. They are supposed to deter theft and break ins.
Jul 24, 2010 | 2003 Ford Expedition
1998 cad alarm no start
Your GM product has a safety alarm, it shuts down the radio , or locks it.
I send ours to a GM dealer to get it unlocked. They don't give those codes out.
Jan 15, 2009 | 1998 Cadillac DeVille
While driving the engine dies
the problem is in the connections with the unit to the car. check all wires make sure tight and connected. if no problem then let me know.
Dec 28, 2008 | DEI Python 1400XP Remote Start/Keyless...
Car wont start alarm light is blinking
yes factory alarm. there is a smal switch hiden under dasch board find it and turn the alarm of by reseting the boutton you can also open the driver side of car witt your keys
Dec 14, 2008 | 1994 Toyota Camry
Vehicle Parts & Accessories Logo
11 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
Tre Elkins
Shehu Pro
Shehu Pro
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
