Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Problems with riding Husq, When I engage the mower the engine stalls. What are some solutions to my problem?
  • 246 Answers
SOURCE: riding moweer wont charge the battery when mower
Hello davidturner:
>>From your Description it Sounds like the Stator/Charging Coils are Not Charging Correctly.
For Testing the Electrical (Charging) System on Mowers you can Use this Site Addy; http://faqs.custhelp.com/cgi-bin/faqs.cfg/php/enduser/std_adp.php?p_faqid=3438&p_created=1101706364&p_sid=4fQ1f8Xi&p_accessibility=0&p_redirect=&p_lva=3443&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NTEmcF9wcm9kcz0mcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1Wb2x0YWdlIGFuZCBTdGF0b3IgQ2hlY2s*&p_li=&p_topview=1 and Use the Link for AC Volts/DC Amps Meter Setting Chart. This is for Briggs Engines and Works Well for Kohler and Other Engine OEMs.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
Posted on Apr 21, 2009
  • 10 Answers
SOURCE: riding mower stalls when blades are engaged
If you bought this mower used and did not change the oil and air fillter or even looked too see what the oil and air filter looked like that could be part of your problem what ever you do when you buy a used mower always change the oil and air filter make sure you are lubed up good and the mower can breath then go from there to your spark plug if it is a used mower change it is better safe then sorry got to keep that sparky sparking. Then if the problem continues think could the lever for lowering and raising the blades sliping and causing the blades to get to close to the ground if not. After all of this it would be a good time to call you nearest pro for some advice not to fix it because if they are anything like the ones around where I live they will try to help you figure out what it is just by what you tell them over the phone before they will want to see it and charge you anything.Good luck.
Posted on May 08, 2010
  • 188 Answers
SOURCE: I have a husqvarna riding
Could be something jamming a blade or belt. With the engine OFF and the key OUT make sure the blades and belts all move freely by hand. Clear out all grass and c**p from the blade and belt areas. You may have to remove the blade deck to do this - instructions are in your manual or download a manual from the Husqvarna website. Good Luck!
Posted on Sep 10, 2010
  • 130 Answers
SOURCE: i have a yth18542 riding
Make sure the "engagement pulley" assy. is moving when the blades are engaged. This can sometimes "freeze" and not move to tighten the belt. You may also make sure the cable is intact as well. These have also been known to brake inside the housing and even though the lever moves, the cable does not pull. These are just a few of the common issues you may want to check. Hope it gets you in the right direction.
Posted on Mar 01, 2011
  • 32 Answers
SOURCE: Husq 2348 riding mower blades
Sounds like your PTO switch or clutch has gone bad. Unfortunately, it is usually the clutch.
Posted on Sep 21, 2011
I have a Husqvarna GT54LS riding mower with a B&S engine. It starts and runs well. When I engage either the mower deck or the differential lock, the engine stalls. What can be the problem?
occupant switch on seat thinks there's no operator in seat with blades engaged , so safety ckt shuts engine off
seat switches go bad sometimes
Sep 14, 2016 | Husqvarna Garden
Engine stalls
could be a stuck pulley or bearing, or debris in the cutting deck. make sure the blades turn freely with mower off and blades dissengaged. If they dont, remove the deck and check all of the pulleys for freeness.
Jun 02, 2014 | Craftsman Garden
Poulan riding mower stalls when I release the clutch
there is other safety switches on the pedal and on the pto
Apr 03, 2012 | Garden
Engine runs but stalls when engaged
This sounds like a micro switch, or relay issue, it is not stalling it is being switched off, if there are some relays on the back of the bulk head replace them, they are just a push fit.
Feb 26, 2012 | Garden
Husq 2348 riding mower blades engage, run for maybe 5 minutes, then disengage on their own
Sep 19, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
WHEN I ENGAGE BLADE MOWER STALLS
Stalling and cutting off could be two different problems so I will address both. If the engine is stalling or being bogged down, you could have a pulley frozen or something jammed that is not allowing the belt to turn and therefore bogs the engine down.
If the engine is cutting off, you could have a safety switch issue that is killing the ignition. You may want to check the seat switch and connector to make sure they are working properly. Hope this gets you in the right direction.
Feb 19, 2011 | Garden
John Deere CR125 hydrostatic mower, engine runs
sounds like you have carb problems
Sep 07, 2009 | Garden
Mower stalls when engaging blades
check the safety switch for engager could be bad,, hope this help,, good luck
Aug 08, 2009 | Garden
Mower wants to stall when blades are engaged on a Huskee 13hp 38'' cut Tecumseh engine 6 speed on the go shift
Usually when the motor stalls when blades are engaged on any mower it is the carb that needs cleaned and rebuilt. The motor isn't getting enough gas to handle the load.
Jun 23, 2009 | Garden
Engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
Apr 11, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
21 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
