Question about Wasp Barcode Technologies Wasp 633808091002 Keyboard Wedge WCS 3900 Barcode Scanner
How to configure WCS3900
Cannot get the scanner to read bar codes
Why doesn't it scan?
usually you need to configure the reader to tell it what kind of barcodes you want it to read and how to interpret & output the codes to your computer (whether you need prefix or suffixes to your codes( for automation))
the user manual for the reader has some bar codes to configure the settings for the scanner.
Jan 27, 2016 | Zebra Symbol LS4278, Bluetooth, Blood Bank...
Tip
How do I add CR to Barcode Value?
<p>The primary purpose of bar codes is to encode the unique characteristics of numbers and letters can be in a format that machines can easily read. However, bar codes are read by people often also for this reason, the codes generally include both parties readable and legible. The most popular bar codes meet a standard called "Code 39". The latest version of the code with 39 additional characters called "Extended Code 39." Among other characters, Extended Code 39 allows users to include carriage returns (CR) in bar codes. <br /> <p><br /> <p>1. Setting the bar code scanner to read "Extended Code 39," Code 39 is not as common support CR. The details depend on the specific bar code scanning software is used, but you will usually find this option under "Tools" then "Options." <br /> <p><br /> <p>2. Configure the software to generate bar code to the "Extended Code 39" is also used. The details depend on the specific software to generate barcode is used, but you will usually find this option under "Tools" then "Options." <br /> <p><br /> <p>3. Type "M $" (without the quotes) at the point where you want the CR model is within the barcode. M $ gives a CR Extended Code 39. <br />
on Jun 26, 2011 | Computers & Internet
Why does Symbol LS 4000i put an X before data?
Someone mistakenly added a character before the data during the configuration.You may try factory default setting using configuration barcode.
Jul 07, 2014 | Symbol LS 4000i Handheld
Hello, I have the Motorola LS3478-FZ barcode reader and am having a strange problem. This is a wireless reader, and the cradle is plugged in via USB. The reader seems to scan any barcode I give it,...
Hello Mathew,
the USPS barcode is the GS1 128 (Code128) that will help you by activating accoring to the manual. Please be sure that you enable all lenghts of the Code128 barcode. That is probably the issue.
Aug 19, 2010 | Zebra LS3478-FZ Handheld Rugged Cordless...
Get usb device unreconized when I plug wcs3900 into usb port
1. Go to Start>> Right click My Computer>> Manage>> Device Manager 2. Expand the USB Controller section 3. Right click and Uninstall all of the listed USB devices 4. Reboot the system
Mar 05, 2010 | Wasp Nest WCS 3900 CCD Barcode Scanner...
HOW CONFIGURE SCANNER VOYAGER MS9540 TO READ BAR CODE 39
THE BAR CODE IS READ CODE BUT NOT WRITE THIS CODE IN THE COMPUTER FOR EX: WORLD
Oct 23, 2009 | Metrologic Instruments MS9540 Voyager...
When we scan it will read factories bar codes but no other bar codes does anyone know how to fix this problem?
What software are you using with the scanners as it can be configured to only read codses beginning in a certain number
Aug 07, 2009 | Symbol LS2208 Handheld
Intermec CK31 handheld - Configure to read bracket symbol
Here at Legacy Global we can help you. Call Diana at 1-847-750-9231.
Mar 10, 2008 | Intermec CK31 Portable Terminal
Scanner blocks when scanning a bar-code
the metrologic scanner you are talking about has a barcode in the maual under the keyboard wedge section it is called stand alone keyboard this will cure your problem when you scan it. the reason being it fools the scanner into thinking there is a keyboard connected. hope this helps Pete
Aug 16, 2007 | Metrologic Instruments 9520 Voyager
Bar code reader problem
In the user manual for this device there should be a code book (or code pages), These are a selection of barcodes which you use to configure the device. One of the settings is to omit the barcode header (which indicates a type of barcode for instance a PART number might begin with P or a Serial number might begin with an S) This barcode system may have been initially programmed to omit these code letters Gareth
Jul 04, 2007 | HHP IT3800 Handheld
Wasp Barcode Technologies Wasp 633808091002 Keyboard Wedge WCS 3900 Barcode Scanner Logo
Top Wasp Barcode Technologies Computers & Internet Experts
David Payne
David Payne
Are you a Wasp Barcode Technologies Computer and Internet Expert? Answer questions, earn points and help others
