Question about Amana Heating & Cooling
Do you have a copy of the amana acd106r manual
Getting an E1 error message..wont start
1. Unplug unit. 2. Hold down power button while plugging in unit. It will do a short self-test and then beep. leaving unit off. 3. Release power button and unplug. 4. Plug in again and turn on normally. This should last for about 720 hours, at which point the E1 error will come back and you need to follow the procedure again. (You might as well clean the air filter at this point just in case it really needed it...)
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 03, 2011 | Amana ACD106R Wall/Window Air Conditioner
I have a E1 where the temp is and the air condition will not turn on
Hello, Here is a trouble shooting guide for you and some details of how to fix it based on your symptoms. Here is a link to go to and make sure you jump around the site, it will tell you the fix based on your problem off the trouble shooting table. Link is below , copy and paste in browser. If this helped you, please rate it and some kind words are nice. Thanks Mike
http://home.howstuffworks.com/home-improvement/heating-and-cooling/how-to-repair-room-air-conditioners1.htm
Aug 03, 2011 | Amana ACD106R Wall/Window Air Conditioner
When I turn my window unit off, the LED light is on with "E1" on it. It usually has no light on when we turn it off. What is this "E1" telling us?
Needs cleaning.
Jul 28, 2011 | Amana ACD106R Wall/Window Air Conditioner
Compressor will not shut when unit power is shut off.
Jul 21, 2011 | Amana ACD106R Wall/Window Air Conditioner
I cannot locate my operating manual for my 2 year old ACE 156E 15000BTU A/C from Amana. How can i get another copy of it?
The Amana website has manuals to download but when I put in Amana ACE156E they said I had the wrong model number.
Suggest you go onto the Amana website and plug in the model exactly has it says on your unit id plate.
Jun 03, 2011 | Heating & Cooling
We never received a manual and now need to replace the water filter. model no. ASD2522WRW03 - ser. no. S01831393. also how do we order a replacement manual
The direct link to the manual from Amana is http://www.kitchenaid.ca/assets/pdfs/literature/User%20Instructions%20-%20W10237701A.pdf . If the direct link doesn't work, start here: http://shop.amana.com/product_literature/search_results.jsp?searchTerm=ASD2522WRW03&siteCd=AMA&userType=Consumer . The manual is also available at Manage My Life: http://www.managemylife.com/mmh/owner_manuals/17324/AMANA-Side-by-Side-Refrigerator-L1002225?brand_name_search=ASD2522WRB03+AMANA .
The filter you need is T2RFWG2 and P2RFWG2 (part number 4396841) . The filter is in the base grill on the freezer side of the side by side. There is a cap over the filter. You need to push the release button on the cap to remove the cap and filter. Save the cap and put it on the new filter before replacing the filter. If you replace the cap, you can use the water and ice dispenser without the filter.
If you want a printed copy of the manual, you can order it from Sears Parts Direct. They also have the filter. See http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-ASD2522WRW03/1268/0165000/W1009009/00001?blt=06&prst=&shdMod= . The manual is part 1 ($5.99) and the filter is part 30 ($54.98). The filter is also available from Partstore.com http://www.partstore.com/Model/Maytag/Maytag/ASD2522WRW03.aspx for $37. Amana sells the filter here: http://www.amana.com/accessories/refrigerators/water_filters/refrigerator_water_filter___in_the_grille_fast_fill_push_button_4396841.pro?scr=category for $40. If you go here: http://www.amana.com/accessories/refrigerators/water_filters.cat , you can order several filters at once.
I hope this helps.
May 22, 2011 | Amana Refrigerators
Need On-Line Manual for Amama Portable A/C #APO95R
homeappliance.manualsonline.com/ex/thread/view/.../357803
Portables do not need venting.
Jul 07, 2009 | Amana AP073M 20" Portable Air Conditioner...
Central air condtioner making beeping noise!
it means it has a fault. try resetting unit by switching circuit breaker off and on it might go away
Jun 04, 2009 | Amana ACD106R Wall/Window Air Conditioner
Beeping Noise
when the air conditioning aircon is have niose get a more prion in the copper tube and you will see the effect
Jun 20, 2007 | Amana ACD106R Wall/Window Air Conditioner
Heating & Cooling Logo
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
