Question about Audiovox D1020 Car DVD Player
The monitor has jagged lines going through the picture in both units. These units are in the head rest of the car.
    President:
  • 1,114 Answers
Check the video module. Generally, it's under one of the seats since the cables are usually only 6' long. Check the video connections at the module. ( The box is usually 7"x7" and about an inch tall) If all your cables are tight and you can't get the dash unit out, to test the headrest monitors, if you've got a small tv with video input, plug it into the module, if it's the same, you know it's the module or the deck. Chances are it's a loose video connection on the input side of the module or a loose connection on the video output of the deck or DVD, whichever you have. Hope this helps
Posted on Jun 23, 2009
  • Chris Armstrong
    Chris Armstrong Mar 26, 2012
    Did this get fixed with just being a simple connection issue? I have the same problem. Only one monitor though.
How do we intall a aftermarket bluetooth
jaguar sell a kit which interfaces with the audio head unit not cheap but easy to fit and works with most phones the only snag is because it uses the d2b.fibre optic network the car has to go on jags diagnostic eqipment i.e ids or sdd to tel the head unit it as been fitted, its worth going down that road has i have seen many problems created by using cheaper aftermarket kits stopping the audio unit from working correctly etc.
Apr 01, 2013 | 2003 Jaguar X-Type
Limp mode why
Need more information to provide possible solutions. Jag is known for having multiple ECM's (Electronic Control Modules), it's what many will refer to as the computer control unit. It's a nice feature as most cars produced have a single unit that monitors and controls everything. The Jag's on the other hand have multiple dedicated units that monitor independent components. In a nutshell the car has received a signal from one of the units that is indicating a significant fault in one of the engine component systems and the ECU has put the car into limp mode to allow you to get it off the road if necessary but limit potential damage to the motor by continuing at full running capacity. It could be a variety of things ranging from low oil pressure to a transmission problem. Are you getting any other messages on the screen?
Feb 26, 2013 | Jaguar Cars & Trucks
Auto monitor will not turn on
it sounds like you are having a transformer failure of the unit itself. these parts are not even repaired by the manufacturer. unless you are an electronic whiz i think your only solution is to replace the monitor.
May 26, 2012 | Computers & Internet
Jagged edges going off and on
Go if model here is correct to menu and engage Convergence and advanced to pull up a grid of lines---are they 3d in some areas when this happens?
Apr 06, 2012 | Mitsubishi WS-55513 55" Rear Projection...
Monitor has cloloured lines or blank when turned on or resting
The picture board on your monitor is bad, since the power led or button is on and all connection are corrrect, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care
Jul 01, 2010 | X2Gen MV20TP Monitor
My laptop freezes with jagged diag lines showing on the monitor
try to re-install your video driver to its latest version.
Jul 01, 2009 | CMB T43 750 Notebook
Play while driving
in the USA that is ilegal but if you wanted some of my colleagues put the parking cable of the stereo to ground.Good luck
Apr 03, 2009 | Power Acoustik PTID8400 Car DVD Player
Jagged lines in draft mode
hi, it sounds like the head needs alignment. nLook in the manual, follow the proceedure outlined there and the problem should disappear
Feb 14, 2009 | HP Designjet 90 InkJet Printer
LCD screen dark and jagged lines
my nikon D80 did the same thing, had to replace the LCD. Their screens are very pedantic and screw up for no apparent reason, they also dont have as much shock resistance as the rest of the camera, as Ive learnt from expensive previous experiences....
Mar 27, 2008 | Nikon Cameras
Jagged horizontal blue lines everywhere
convergance amp ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Mar 10, 2007 | Mitsubishi VS-45609 TV
Audiovox D1020 Car DVD Player Logo
254 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Marvin
Marvin
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
