Question about Troy Bilt 5.5hp Self Propelled Mower
WHERE IS THE KILL SWITCH ON A TROYBUILT SELF PROPELLED LAWNMOWER
  • Troy Master
  • 2,760 Answers
The switch is built right into the cover over the carb , there is a cable that runs right too it from operators handle
Posted on Sep 19, 2015
5 Suggested Answers
landsend
  • 1066 Answers
SOURCE: Troy Bilt Self Propelled Lawnmower drive belt
belts usually come off for a few reasons.
They become loose...stretch or the tensioner moves,  Make sure that none of the tightening bolds are slipping.  You can dab them with a bit of paint.
when the pulleys are not in alignment or crooked or bent.  Eyeball the path from one pulley to another, also make sure the tensioner is in alignment and there are no other obstructions.
good, high quality belts are required, and they must be real drive belts...not regular v belts.  If there is a way to watch the belt in operation you can usually see what's going wrong.
On my lawnmower I had to grind some metal away where the belt went from the motor to the transmission.  Good luck
Posted on Apr 18, 2009
vincob
  • 718 Answers
SOURCE: variable speed doesn't work troy bilt self propelled lawnmower
Cable could be stretched belt could be worn or old, if it has a gear box maybe it slipped a gear or lost some teeth. Do some investigation, Good Luck
Posted on Jul 26, 2010
eugbug
  • 479 Answers
SOURCE: The self propelled just quit working. The front
Drive cable or drive belt could have broken
Posted on Sep 04, 2010
  • 640 Answers
SOURCE: troybuilt self propelled mower will
The carburetor is dirty and/or the diaphram needs replaced.
Posted on Jul 28, 2011
What do I need to do next if the tension is gone on my craftsman self-propelled lawnmower.
The cable will need to be replaced. They tend to rust and become broken. The function of the cable is, it opens the kill switch and releases the engine break. Hopes this will help ya.
Jul 19, 2014 | Craftsman 190cc* 22" Front Drive...
Troybuilt self propelled mower will start but wont run
Jul 27, 2011 | Troy Bilt 5.5hp Self Propelled Mower
My 21" Mastercraft self-propelled, 3-in-1 mulching
There is a flywheel brake that is contolled by the safety bar of the handle. If the cable to the safety bar has broken or is no longer attached the the flywheel brake will be on. Not only that there is an ignition Kill switch as part of the flywheel brake. If the brake is on, the kill switch is activated.
Your mower needs some simple maintenence
1. Recoil assembly repaired or replaced.
2, Throttle cable and control repaired or replaced (Item 10 below link)
3. User Safety Bar cable adjustment or replacement. (Item 11 below link)
The above items are not a good reason to call your mower a parts source.
Without a model number I had to GUESS which model this was.
This is my best guess:
http://www.jackssmallengines.com/help.cfm#/MTD/125-478C054_(1995)/General_Assembly/0054900-E/00549000001
Thanks for choosing FixYa,
Kelly
Jun 07, 2011 | Briggs & Stratton Garden
Will not start
completly disconect self propled belt or gear should be able to mow til you fiigure out whats up with self pro some thing is jamming selfpro ps if you have to turn it upsidedown kill switch on
Apr 22, 2010 | Poulan Pro " Pro" Self Propelled Mower
Mower starts for 15 seconds then stops.
if it is still new. call troybuilt and ask who in your area does service work on troybuilt mowers, because it is still under warranty...good luck
Apr 07, 2010 | Troy Bilt 5.5hp Self Propelled Mower
How would I get an owner's manual for a Toro
go to www.troybuilt.com u can request one on line or can be advised where to pick one up
Mar 10, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 190cc Z-Start Model 12A-446A011 21"Inch Deck
You need to remove a pulley to put the new belt on.
Jim
Jun 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 5.5hp Self Propelled Mower Logo
119 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
