Question about Rotary Snow Blower Parts Replaces Ariens 02483851 02483859 Fits All Ariens Snow Blower From 60S Until Present. Used On Models 924080 924082 With 24 Auger. Also Fits Deere Bolens MTD Simplicity
How do you put it in neutral
Just got the snow blower and it will not move 1 wheel desendgages when pin is pulled
  • Tim Hofstetter
    Tim Hofstetter Jul 28, 2014
    What make and model is it?
  • 26 Answers
Does it have steering control triggers to turn it left or right...if so hold both at the same time with engine off and see if you can push it..Let me know if that works. Or let me know what kind of controls you have
Posted on Jan 05, 2015
My mtd yard machine snow blower gear turns freely, doesn't turn with the wheels. found problem when blower would not move
if u ck the pins in the center of your wheel hubs , you may see one or both missing , these pins are to allow one to free wheel the blower to "push " it easier , they do rust and break off over time
Dec 13, 2016 | Garden
How do I remove a wheel from my snow thrower
If it is the drive wheel you have to tap it out with a hammer and wood piece (to not damage it). It is pressed onto shaft.
Jan 29, 2015 | Garden
I HAVE A MTD SNOW BLOWER ICOULD TURN THE WHEELS BY HAND WHEN I PULL THE CABLE THE DONOT TURN THE BETS TURN
The cable may be rusted so when you pull the handle only the tension spring moves. Tilt the machine up onto its Auger and take the bottom cover off. See if anything is rusted and not moving when pressing the lever
Nov 03, 2014 | Garden
30 in craftsman snow thrower,model no.247.883960,pulls right contionusly while operating in any gear
Howdie ther is a Pin in the shaft of the wheels look to see if it is Broken and away ya go it is easy to see
Feb 07, 2014 | Craftsman Arnold Mtd Snow Thrower Blower...
30 in. craftsman snow thrower,model no. 247.883960,pulls to the right
If your blower uses the two wheels to drive which I think it does I would suggest that you have a shear pin on the right side that is broken. If that is the case you will have to pull the wheel off and replace the shear pin. You can tell if it's broken by lifting the right side and trying to turn the wheel by hand.If it turns easily its broken.
This is an idea only. You might want to check both wheels as I'm not sure as far as the steering is concerned.
Feb 07, 2014 | Craftsman 30 In 357cc* Dual-Stage...
When in gear right wheel drives left wheel is locked and will not move same when not engaged
Many snowblowers use pins (or bolts - see image below) that pass thru the shoulder of the rim of the tires thru a hole drilled thru the drive shaft. Removing both of the pins allows the tires to spin freely on the drive shaft and makes it much easier to push, pull and turn the snowblower. If they are not installed again, the machine will not "drive" and make clearing snow difficult to do. Installing only one will make the machine want to go in circles. Make sure you have these pins installed thru BOTH rim shoulders and drive shafts - locked in place. Other machines lock the tires in other ways - since it sounds like one side is working correctly - you should compare the two tires / rims and make them both look like the one that works properly. Good luck!
Jan 06, 2014 | Ariens 926054 Snow Blower 2 Stage 32 In
Honda hs55 when handle depressed blower fan moves at fast speedauger turns very slow.if auger makes contact with snow auger and blower fan stopsnew belt was installed no slippage of belt present
I suspect that all is needed is a little adjustment of the rod attached to the handle, which hooks on a lever at the bottom of the snow blower drive axle case. Try adjusting the nut two turns, that will pull the rod a little bit more and engage the rubber faced drive wheel, giving it a snugger connection. If this has been checked or still does not help, then I would check inside the case where the drive axle is located. There is a rubber faced drive wheel (as noted above), that runs against a smooth flat metal pulley. The rubber on the drive wheel could be worn out and not engaging properly. I would also check on the front of the case where you installed new belts to make sure that the brake shoe puck that connects to the auger pulley is not binding or perhaps has flipped out of its normal location.
Dec 05, 2013 | Honda Piston Rings Snow Blower Lawn Mower...
Snow Blower has no power moving forward and jerks
I am wondering if the shear pin is broken in the drive wheels. it could be broken but just grabbing enough to move the machine when not under load. i had a self propelled lawn mower that did that and had to replace the pin in my drive wheels.
Feb 02, 2018 | Garden
My poulan snow blower keeps breaking sheer pins in the wheels,
1)try replacing them with a heavy duty "roll-pin"
these are available from auto parts stores.
two types are available.
first is the "single-roll",second is the"multi-rolled"with many layers to it.
try both they're cheap.
2)try not hitting things with the blades
3)dont force the machine in heavy wet ,or frozen icy packed snow.
Dec 23, 2008 | Sport & Outdoor - Others
Rotary Snow Blower Parts Replaces Ariens 02483851 02483859 Fits All Ariens Snow Blower From 60S Until Present. Used On Models 924080 924082 With 24 Auger. Also Fits Deere Bolens MTD Simplicity Logo
351 people viewed this question
Top Rotary Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Rotary Garden Expert? Answer questions, earn points and help others
