Question about Mtd 19 In. 173 CC OHV 3-In-1
How to clean the carberator? - Mtd 19 In. 173 CC OHV 3-In-1
    Champion:
  • 279 Answers
Contact MTD if your manual doesn't cover this, or buy a shop manual, or go to the engine maker's website and look it up.
Posted on Dec 22, 2014
Breaks down middle to high revs
You should try cleaning the carberator. Start with The bowl and the main jet. 9 times out of 10 there is junk in it. Once cleaned properly it should run great. If not, be sure to check the float and the peckcock to make rue you're getting plenty of fuel to the carberator.
Apr 17, 2014 | 2001 Honda XR 250 R
Briggs & Stratton 4 cycle Lawnmower engine no fuel from carberator. Fuel is being supplied to carberator but only runs when starting fluid is used. Gas is new. What's clogged?
the float may be gummed up. or the needle is plugged up.
you need to clean the carburetor, old gas left in the carburetor turns
into shellac and gums up in side. you need to take it apart and clean it.
Jun 05, 2012 | Garden
Where is the primer ball
It may not have a primer ball. If it does, it would be attached to the carberator. If it starts, but won't stay running, that could mean your carberator needs to be cleaned/serviced.
May 29, 2012 | Mtd 22" Yard Machine Push Mower
Model 42a707 engine spitting gas out of carberator
Fuel needle leaking in the carb, remove the float bowl, check the float is moving freely, clean away any dirt, if no better replace the inlet needle.
May 06, 2012 | Yard Machines Garden
I have a 35cc 14in chain saw. It runs intermittenly. While running it's fine, but then stops and is difficult to restart
Check the air filter for debris, and clean it. If the saw has been stored with fuel in it, the carberator may be gummed from old gas. You can try some carberator cleaner spray , or the carb may need to be dissassembled and further cleaned out.
Aug 21, 2010 | McCulloch Garden
MOWER ONLY RUN WHEN U PUT GAS IN CAB WANT START
Ok, so your not getting gas to carberator, or thru the carberator. Disconnect gas line from carberator, if gas is present thru fuel line, you have a carberator problem. Your rather meger with your mower information so this is all i can tell you. Wish i could be of more help.
May 29, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I can not keep my mower running. It ran great before winter, now it acts like it is going to run.. but dies. I have new gas in it, new oil, and changed the spark plug. What else could it be? craftsman...
Hi, I would suggest taking the main jet out of the carberator and cleaning it with carb cleaner. If you did'nt drain the gas out of it before winter, the gas has gotten old and has plugged up your main jet in the carberator. It could also be that the needle has got **** on it and is stuck, I'd clean that also. Your problem is all in the carberator, and old stale gas sitting in it all winter is the reason.
May 08, 2010 | Craftsman 675 Torque 190cc 21" RearBag...
Wont start then it dose but is very low and cuts out after a few seconds
This would be a carberator problem. Clean, rebuild, or replace the carberator.
May 03, 2010 | Mtd 22" Yard Machine Push Mower
Engine cant run with air filter fitted, I have cleaned it .but the problem remains the same
This means that you are over fueling. There is more fuel going to the carberator than air. By removing the air filter you are allowing more air flow into the carberator, which is allowing the engine to run right. Natural gas and propane generator must have no more than 11 inches of water column. Gasoline engines should have no more than 3.5 psi out of the electric pump. If gasoline is gravity fed, then this means that you need to rebuild the carberator or purchase a new carberator, but try to adjust the flow valve on the bowl of carberator first.
May 19, 2009 | Kipor Parallel Wiring Kit, 30 amp...
Mtd 19 In. 173 CC OHV 3-In-1 Logo
198 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
