Question about Birds
What bird is black and white with a red ******?
How to get rid of lice on small birds
No idea of your country but a 20Second google search revealed this;
To remove lice, it is recommended to use a mild pet insecticide, such as "Nuvan." After spraying the plumage, wait for 2 - 3 minutes and then gently ruffle the feathers over a white tray or plastic sheet to collect the lice which fall from the feathers.
I found that one great way to remove lice and mites from your birds is to sprinkle Sevin Garden dust under their wings and tail, and on the back. Check the birds the next day and if there are still lice present, repeat the process, as needed. I found Sevin dust [active ingredient: Carbaryl (1-napthyl N-methylcarbamate)] equally effective in getting rid of red mites.
Avian Insect Liquidator is another way to get rid of mites, lice and other insects in the birds' environment. This all-purpose insecticide from Vetafarm contains a water-based insecticide that is harmless to birds but effective against insects.
Prevention:
Sanitize and treat the birds' environment (cages, perches, aviaries, nesting areas, etc.). Secondly, allow your birds to bathe daily. Most birds enjoy doing so and if you provide them with a shallow clean dish, they will usually be happy to bathe without encouragement. Some birds like to be misted, or even sprayed. Sprinkling Sevin dust underneath nest bowls and around nests will eliminate all kinds of insects.
Aug 06, 2017 | Birds
A black head small Australian bird with a white patch on both sides of its head with a red beak
check the bird identification pictures but it sould like a black head finch
Mar 10, 2017 | Cars & Trucks
Is a bird i found in myporch,big red legs black and have like a mohak.do you think i can find what family is belong/?
I am sure that you can find out what this bird is. Contact a conservation officer or nature guardian to get the info. I am not sure what the bird is.
Oct 07, 2014 | Birkenstock Florida Loafers
Identify birds in indiana
Could be a tufted titmouse?
Jun 29, 2014 | Pets - Others
Bird identification by color
Is there a bird that is all red except for the white breast?
Jan 04, 2014 | Birds
Leviton three way has two red, one black plus ground. Old switch one each,white,black red. What goes where.
Typically in three way residential switching the Red and White are used as travelers from 3 way to 3 way. That in mind, connect the black to black, red to one red and the other red to the white. mark the white wire with black tape.
Mar 04, 2013 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
I have an outside light that I want this timer to control. The switch box has a black and a white going out to the light and a black and white with the electricity. The instructions show to hook the red...
You posted under ST01C timer which has 3 wires: black blue and red (no white wire)
Your description seems to say your timer has 3 wires: black white and red
These are two different timers
I'm going to give you two different instructions that are dead-accurate for both types of timers above:
1) Instructions for ST01C and EJ500 Intermatic timers with black blue and red
Lets do the black and white with electricity:
The black Hot wire connects to Timer-black-wire
The white Neutral wire connects to white wire going to Load (to lights)
Now the black and white to the Load (lights)
The black to Load (to light) connects to Timer-blue-wire
The white wires are connected together with wire nut
The red wire is capped off, and used only if you have 3-way switching.
Green connects to bare ground
2) Instructions for all in-wall timers with black, red and white wires (except Aube series timers)
Lets do the black and white from electricity
The white Neutral connects to Timer-white-wire and to white wire going to Load
The black wire to Load connects to Timer-red-wire
all three white wires are connected and covered with wire nut
DO NOT CONNECT RED TO WHITE with any model in-wall timer and then turn on power or it can blow out the timer >>> I just did that while experimenting with the Utilitec 0192773.
Red wire goes to Load on all timers, except with Intermatic ST01C and EJ500
Oct 17, 2010 | Intermatic Inc. ST01C Digital In-Wall...
JED8430BD Wiring
from supply
white, black - should be hot then ground
On cooktop
red, black - should be hot white - neutral then ground
If you have a volt meter measure
supply
between white - black 220v
between white or black - ground 110
cooktop
between red - black 220v
between red or black - ground or neutral 110
If the above is confirmed
connect
red (cooktop) to white(supply)
black (cooktop) to black(supply)
white (cooktop) to ground(supply)
Regards
Sep 06, 2008 | Jenn-Air JED8430 Electric Cooktop
Birds Logo
Top Birds Experts
Tom Chichester
Are you a Bird Expert? Answer questions, earn points and help others
