Question about Air Purifiers
Relevant diagram explain the impact of Radiation on atmospheric temperature
My thermostat showing on screen 76F when really room temperature is 70F and I HAVE MEASURED PROPER room sensor resistance OHMS to real room temperature. Why thermostat showing higher temperature and n
Where is the thermostat in relation to the return? Is there air flow or is the air stagnant in the area of the thermostat. Have you placed a thermometer in varios locations where the thermostat is located? Try these locations and see if the thermostat needs to be placed in a location better able to reflect room temperature. Also how long have you lived in the house? If it is a newer home I suggest that you contact the builder or the air conditioner/heater installer to see if they have a schematic of the placement of the thermostats.
Nov 25, 2014 | Honeywell TH8110U1003 VisionPRO 1H/1C...
Won't start
Check the fuse inside the unit, it is located where power cables hook up.
Aug 26, 2008 | Jet AFS-2000 Air Purifier
What refrigerant type is R22?
R22 is used in older air conditioners and commercial refrigeration.. It's not readily available and is expensive now. You cannot let it escape into the atmosphere, so it needs a recovery machine to remove any freon still in the system.
Aug 20, 2014 | Trane TFE235A9AH30 300-1800 CFM AIR...
Temperature Coulant Sensor
Under hood, driver side, upper engine area, mounted in end of cylinder head
Jul 15, 2013 | AM Auto Parts 2006 VW Touareg Mass Air...
Crown Capital save the earth management, what causes global warming?
Scientists think that Global Warming is caused by the gases produced when humans burn coal, oil, etc. These gases trap the sun's heat in the atmosphere. Carbon dioxide is made when these fuels are burned. Percentage of carbon dioxide in the atmosphere has been rising as result of human industries since the Industrial Revolution.
Heat absorbing gases are known as greenhouse gases. The warming of the atmosphere is called the greenhouse effect. Humans add extra greenhouse gases, which gains a bigger chance in the greenhouse effect. The increase causes global warming.
Apr 03, 2013 | Air Purifiers
I was given this product and don't know what it does.
I cannot understand the popularity of machines like this! They generate ozone, and here's what you need too know:  Ozone is an atmospheric pollutant (good news up in the stratosphere - bad news down here where we breathe it) and primary irritant of mammalian airways. It is a powerful oxidizer of organic matter, so it kills bacteria (mostly good news) and can adversely affect anything else organic that it comes into contact with - leather, rubber, plants, pets and you (really bad news).
Personally, writing as a qualified chemist and biologist, I would not want to be in the same house as an ozone generator, let alone be in the same room as one.
If you really feel the need to "purify" your air. Do it without generating a toxic impurity!
I value your feedback, so if this helps please rate me.
Apr 07, 2009 | Sharper Image Ionic Breeze GP SI720 Air...
Is the oreck xl professicnal air purifier a safe unit
...and so you should be! Worried, I mean. And not just about this particular machine. Ozone is an atmospheric pollutant (good news up in the stratosphere - bad news down here where we breathe it) and primary irritant of mammalian airways. It is a powerful oxidizer of organic matter, so it kills bacteria (good news) and can adversely affect anything else organic that it comes into contact with - leather, rubber, and you (bad news).
Mar 13, 2009 | Oreck XL Professional Air Purifier...
Question
Presumably it meets all relevant safety standards, otherwise it would not be permitted to be on the market in most civilized countries.  That said, it certainly produces ozone which, while a highly effective odor destroyer, is an environmental pollutant and causes upper respiratory tract irritation and other symptoms (check out ozone in wikipedia, and you won't want to be around it for long!).
Personally, writing as a qualified chemist and biologist, I would not want to be in the same room as a working ozone generator.
Does that help?
Mar 06, 2009 | Honeywell HFD-130 Air Purifier
User Manual
The only cartridge is the included 'stainless steel collector grid' (removable for cleaning with cloth, don't use vinegar), there's no air filters that need replacing.
According to the manual:
SIR setting (Super Ionic release) creates lots of negative ions which not only gives a prior-to-rainy-day fresh energetic atmosphere that relieves headaches, but also if comes into contact with dust, will attach to the dust and make them heavier to drop them out of the air.
SOS setting (Super Oxidating Sanitizer) turns oxygen O2 molecules to O3 molecules, which if comes into contact with odor or dust will discharge 1 O atom into the pollutant to neutralize it. Also, like SIR, it introduces negative ions that attach to dust and makes them fall to ground, but not as much,
Both settings tackle dust/pollen/smoke with SIR doing it faster. Only SOS can neutralize organic odors. I recommend SOS because if you leave it on long enough it can do the same job as SIR, as well as make the room smell fresh.
Oct 04, 2007 | Lentek IO10G Air Purifier
Air Purifiers Logo
Top Air Purifiers Experts
Are you an Air Purifier Expert? Answer questions, earn points and help others
